Search Forums | Classifieds (40) | Skins | Language
What is the good and bad about a Agco/Allis 8610 FWD ?
dieselartie
Posted 9/8/2012 16:01 (#2581683)
Subject: What is the good and bad about a Agco/Allis 8610 FWD ?
northern chester county PA
Know were one is that I may take a closer look at
Looking for a hay making tractor . Run 11ft discbine and twin rotarty rake . All JD here .
How do they hold up with a loader ? Would need to move 3/3 big sq's .
smilin jack
Posted 9/8/2012 22:32 (#2582235 - in reply to #2581683)
Subject: Re: What is the good and bad about a Agco/Allis 8610 FWD ?
SW North Dakota
Other than that, how did you like it?
John In Ontario
Posted 9/8/2012 23:02 (#2582304 - in reply to #2581683)
Ripley, Ontario Canada
The good they are worth $200 a ton plus the tires here, the bad, well I had a 6105 white which is pretty much the same only liquid cooled. I had a shaft seize in the transmission, the transmission housing bolts break, and coolant in the motor in about 2000 hours. The heater wasn't enough to keep the windows clear in winter. Was nice enough to drive, just couldn't keep it running. I would keep looking for something else. I replaced with an 8785 Agco Allis and it has been a good tractor.
EquipmentUser
Posted 9/8/2012 23:29 (#2582344 - in reply to #2582304)
KY
The 8610/30 are SAME tractors I believe out of Italy. I have worked one one but don't know enough about them to say if they are good or bad. Parts availability and cost would be the major issue and would be enough to make me walk away.
dougpettman
Posted 9/9/2012 09:07 (#2582643 - in reply to #2582344)
Tillsonburg Ont
My 8610 was a great tractor.Very stingy on fuel. I had the 36 speed tranny and the creepers worked well in vegetables.I have heard parts can be a problem.There is a place in England that has the corner on parts.
Gpurrs
Posted 9/9/2012 09:10 (#2582645 - in reply to #2581683)
SEIL
Run Forest Run !
