Search Forums | Classifieds (137) | Skins | Language
Help good bad and ugly of John Deere 500 and 510 Round Balers
rudolphus
Posted 8/3/2012 15:36 (#2520452)
Subject: Help good bad and ugly of John Deere 500 and 510 Round Balers
South East MN
Hey just lookin for the good and bad of John Deere 500 and 510 round balers. Lookin into one for baling 30 acres just tired of horse trading with the neighbor and would like one of my own. Any help you can give would be great! Thanks!
tbeck
Posted 8/3/2012 15:52 (#2520480 - in reply to #2520452)
Subject: RE: Help good bad and ugly of John Deere 500 and 510 Round Balers
Culbertson, MT
The 510 was as good as most at the time. We had one for quite a few years, and liked it OK. But, I wouldn't have it back! If you have JD on the brain, step up to a 530. Advances aside, they are the predecesor to the current JD line and would serve you well.
farmerpete2400
Posted 8/3/2012 15:56 (#2520483 - in reply to #2520452)
West Central, IL
Everyone one here will run them down. I have a 510 that I rent to a friend. He said that they work better in a long stem grass, and not so much in short loose stuff (but he doesn't mind running it). I put new upper belts on it and painted it this year. I would like to sell it and maybe get a net wrap one. If your interested, I don't think you will find one much nicer then mine.
rudolphus
Posted 8/3/2012 16:01 (#2520488 - in reply to #2520452)
Subject: Re: Help good bad and ugly of John Deere 500 and 510 Round Balers
South East MN
Pete how much u askin for yours? any pics?
Tim(nj)
Posted 8/3/2012 16:09 (#2520495 - in reply to #2520452)
Pittstown, NJ
Remember that it won't like high-moisture material for wrapping. In dry hay, it should do the job on 30 acres. I use an old Hesston 5500 on about as many acres. Sometimes when you ask a question like this on NAT, you will be overwhelmingly advised that you need the biggest, most expensive overkill you can find to do it 'right'. Or the other favorite line 'just hire it done'.
farmerpete2400
Posted 8/3/2012 16:27 (#2520521 - in reply to #2520488)
West Central, IL
Send me an email and we can talk.
[email protected]
whitey
Posted 8/3/2012 18:24 (#2520662 - in reply to #2520495)
SW Kansas
+1! Either would be just fine for 30 acres.
German Shepherd
Posted 8/3/2012 19:43 (#2520750 - in reply to #2520452)
I had an uncle that had a 510 and a friend that had a 500.  The biggest complaint I heard from both was that pickup sorta ran down hill towards the front, so you had ZERO floatation when you hit a rock.
I always thought the bottom floor belt on a 500 was kinda Mickey Mousey, but it seemed to work.
macjac
Posted 8/3/2012 20:45 (#2520826 - in reply to #2520750)
PEEDEEinSC
Find yourself a 435 or a 535 cheap and good balers
mac4440
Posted 8/4/2012 00:53 (#2521235 - in reply to #2520495)
If you can afford it, 530 or 535's are getting cheap, and be way better than a 510. 510 had 4" belts that like to get twisted if you didn't feed it just right. If you get a 510, hopefully it will have the wide belts on the outside.
Edited by mac4440 8/4/2012 00:55
