Search Forums | Classifieds (25) | Skins | Language
Teflon tape on diesel fuel fittings
RBH
Posted 7/5/2012 14:35 (#2468106)
Subject: Teflon tape on diesel fuel fittings
nw mb
Had a small leak in fuel tank decided to pull all the fittings apart etc, the connection between the 2 tanks there is npt threaded pipe and elbow and nipple on the end. Looks like who ever did it used teflon tape (there isnt much left) on all fittings, im wondering if there is a better solution then regular old white teflon tape? Thanks in advance!!
77 Farmer
Posted 7/5/2012 14:37 (#2468113 - in reply to #2468106)
Subject: Re: Teflon tape on diesel fuel fittings
Southeastern, IL
sometimes we use teflon tape and teflon paste. The local FS does that on all of their NH3 fittings.
crow
Posted 7/5/2012 14:53 (#2468131 - in reply to #2468106)
Subject: RE: Teflon tape on diesel fuel fittings
East central Alberta
I was told in college to never use Teflon tape on the diesel fuel system. Paste is fine. The strings of tape will go into the pump and injectors and cause sticking and binding. But the paste will pass through without a problem. But close to the tank it would get caught in a filter first.
As for something better I can't really help you there. Paste always works for me.
Bern
Posted 7/5/2012 15:42 (#2468203 - in reply to #2468131)
Mount Vernon, WA
Tape is just fine if you keep it away from the edges of the threads. I have used tape exclusively throughout my career. Two wraps, and have never had a leak or an issue.
It's like anything else, you gotta know what you're doing.
zeamax
Posted 7/5/2012 16:01 (#2468230 - in reply to #2468106)
There are different colors of teflon tape for different materials. Yellow tape is double density and for fuel and gas lines is what I have read. Go to
Fastenal or somewhere similar to find it.
Surbo
Posted 7/5/2012 18:17 (#2468428 - in reply to #2468106)
Here is a table that will help decide what to use. These are good products. Take a look.
http://www.gasoila.com/support/sealantapplicationguide.html
Surbo
mai-ag
Posted 7/5/2012 19:02 (#2468508 - in reply to #2468106)
West ky
x1 on the yellow teflon.
sparkplug67
Posted 7/5/2012 19:41 (#2468572 - in reply to #2468106)
EC Ind
Try bluemonster tape from menards we use it on everything no leaks it is at least twice as heavy as any white teflon tape and way stronger
pistons
Posted 7/5/2012 22:42 (#2468939 - in reply to #2468106)
I call teflon tape "The devils toilet paper" nuff said.
lincmercguy
Posted 7/5/2012 23:44 (#2469093 - in reply to #2468106)
CO, NE
I use paste and I'm always careful to make sure it doesn't get on the inside of the lines/pipes/etc. Mainly this means only putting it on the male side of the fitting and making sure none gets on the inside. (usually stay a couple threads away anyway.
blue8870
Posted 7/6/2012 00:15 (#2469136 - in reply to #2468106)
NE SD
aviation permatex
Offroadnt
Posted 7/6/2012 08:05 (#2469338 - in reply to #2468106)
Southern Alberta Canada
Loctite 567...
Rawleigh
Posted 7/6/2012 17:43 (#2470113 - in reply to #2469338)
White Stone, Virginia
Leak lock is the best out there. I get at my local HVAC warehouse.
http://www.highsidechem.com/leaklock.html
