Search Forums | Classifieds (150) | Skins | Language
john deere 4955 mfwd good bad and ugly?
4640
Posted 6/2/2012 08:19 (#2410297)
Subject: john deere 4955 mfwd good bad and ugly?
south central kansas
can you all tell me the good bad and ugly on these tractors? talk me out of buying one. thanks 4640
BSchroeder
Posted 6/2/2012 08:39 (#2410323 - in reply to #2410297)
Subject: Re: john deere 4955 mfwd good bad and ugly?
Devils Lake, ND
4955's and 60's get a lot of praise on this board. Cab comfort and visibility out the front get knocked, but they're way better for seeing behind if you're going down rows.
Cross Country
Posted 6/2/2012 08:48 (#2410341 - in reply to #2410297)
Subject: RE: john deere 4955 mfwd good bad and ugly?
Ottawa, Ontario
We just got one this spring with over 6000 hours on it. Turned it up to 220hp and it ran like a champ all spring. The wife hauled a 30 foot, 6 bar cultivator with it and it never heated up once. There are a few shifts on the power shift that are a little rough but beyond that they are a very solid tractor. If you have found a good one, buy it.
(IMG_1162.jpg)
Attachments IMG_1162.jpg (61KB - 1490 downloads)
sf 1066
Posted 6/2/2012 08:54 (#2410353 - in reply to #2410297)
thumb of mi
We have had 3 at different times. The mfwd can leak but there is a new seal set up that helps. When new they used some oil due to ring style. For the age it's a good tractor
JK SCLA
Posted 6/2/2012 09:56 (#2410446 - in reply to #2410297)
Brake packs every 7K hours, hyd pumps every 3-3500 hrs. Good tractors, but not great tractors. Had enough of them to form a solid opinion on the matter.
High Cotton
Posted 6/2/2012 13:18 (#2410683 - in reply to #2410297)
Southern Illinois
Bought one new in 1991, still got it.  One of the best riding and simple tractors made.  Plan on keeping it forever.
deereman05
Posted 6/2/2012 13:42 (#2410709 - in reply to #2410297)
Your moms house
Got to run one on the wheat harvest and was one of the best tractors I've ever ran, of course it was turned all the way up. :)))))
dual wheels
Posted 6/2/2012 15:04 (#2410787 - in reply to #2410297)
West Central Ohio,Shelby County
Dad bought one new in 1990.Kept it till 2006.Needed more hyd power for 1790 planter.Overall good tractor,some have a problem with seal leaking engine oil into tranny,which happened to ours.Not good for tranny.May want to check any service records for this.Also weep hole in water pump needs checked.Dutch on here had good luck with them.
cowgirl182030
Posted 6/2/2012 15:49 (#2410823 - in reply to #2410297)
michigan
well for fuel economy you cant beat them, did a fuel comparisiion chisel plowing 4760 used 6 gal/hour WOT, 8320 used 9.5 cruise down to 2000rpm, same JD chisel plow. thats 50 % less same speed
limi
Posted 6/2/2012 17:10 (#2410886 - in reply to #2410297)
Subject: Had a 4755 MFWD...
IN
Check where the front axle pivots. Especially the front side.
If it has a a lot of wear and the grease channels get worn down the grease will squirt out the bottom side while the pin wears thru the bushing and into the casting. It will be behind a big washer and you won't notice it. The casting that is the front end of the tractor. Not good. But can be fixed.
JD said you are supposed to jack the front end up when you grease it to take the pressure off the top side.
Watch the water pump.
The door never did shut tight or right. All glass, no frame.
Was a good high hp tractor with a smooth power shift.
boetboer
Posted 6/2/2012 18:02 (#2410926 - in reply to #2410297)
South Africa
We've got a 4955 with about 14k hours, mostly in heavy tillage and airseeder work. Did the front axle pivot, three hydraulic pumps and one set of injector tips. Other than that, it's been almost perfect. I asked the same question here a few years ago when we bought it and we've never looked back. Powershift is rough, but you get used to it.
Crocket99
Posted 6/2/2012 18:06 (#2410935 - in reply to #2410297)
Edwardsville, IL
We've got a 4960. The only major issue was the a seal that leaked engine oil into the tranny at around 4000hrs. The ride is great. I'd rather run it than our 9330 Case IH. Cab is a little on the small side.
IADAVE
Posted 6/2/2012 18:12 (#2410944 - in reply to #2410935)
I ran one for a friend. I thought it was a dog for power. We were hauling in corn so might not notice as much in the field. I would guess it was turning 225 . It just wasn't snappy like our 4450.
dutch
Posted 6/2/2012 21:39 (#2411173 - in reply to #2410446)
West Texas
What were you doing with them for the hyd pumps to fail and the brake packs?
We had 6 of them in the late 90's and never had too many problems with with hyd pump and never had any brake packs go out. When we traded them all of them had well over 10.000 hrs on them. And all of ours had the pressure turned up to be able to lift up peanut diggers.
DixieDeere
Posted 6/2/2012 23:02 (#2411316 - in reply to #2410297)
Jackson County, AL
One of my all time favorite tractors. Spent a lot of time on two of them, one with 38" rubber and one with 42" rubber. Taller rubber was faster but the shorter rubber pulled better. One was the first one to show up at the dealer at series change, along with Dad's 4255. Another was the last dealer sold before the 60 series. All three were good machines and I loved spending long days in those cabs as long as the A/C was working. They pulled good, drove good, and did what they were supposed to.
retento
Posted 6/3/2012 03:42 (#2411530 - in reply to #2411316)
Eastern North Carolina
4955... All good..!!
