Search Forums | Classifieds (93) | Skins | Language
Questions about hydraulic pump to run a dump trailer cylinder
alebrenn
Posted 5/20/2012 23:37 (#2391084)
Subject: Questions about hydraulic pump to run a dump trailer cylinder
SW NE
We are looking at building custom silage trailers that sit on tri-axle manure tank chassis.  A local welding shop has built a few in the past and has used a variety of hydraulic cylinders.  So here goes the list of questions that hopefully a few of you can give advice about:
1.  We are thinking of using semi dump trailer hoists.  Could a hydraulic motor (operated by one of the tractor hydraulic remotes) turn a hydraulic pump to pump the oil into the cylinder.  We are thinking we would then need some type of hydraulic valve operated by another remote to allow the oil into the cylinder and then back to the tank after dumping the load.  Is this possible?
2.  If #1 wouldn't work, how about a PTO operated pump that is attached directly to the PTO, no shafts?  How much would one of these pumps cost?
3.  Are there any "scissor" type hoists available with 40 ton capacity that could simply be operated from the hydraulic remote?
funfarmr
Posted 5/20/2012 23:49 (#2391114 - in reply to #2391084)
Subject: Re: Questions about hydraulic pump to run a dump trailer cylinder
Ohio
Yes number one is possible. Neighbor bought a pump from a dump truck and spins the pump with a hydraulic motor driven by the tractor. Then he used a small 12 volt electric actuator to move the valve on the pump from raise to lower. The actuator runs off of the cigarette lighter plug in the tractor and has a switch to run the actuator in or out. I can try to get some pics if you'd like.
Big Ben
Posted 5/20/2012 23:54 (#2391121 - in reply to #2391084)
Subject: RE: Questions about hydraulic pump to run a dump trailer cylinder
Columbia Basin, Ephrata, WA
1. Yes.
2. #1 will work. I think I'd rather have a frame mounted pump with a pto shaft instead of a PTO mounted pump at 1000 rpm.
3. I don't know, but a 40 ton hoist would be a lot of oil leaving the tractor unless it was a two way cylinder, which it probably would not be.
alebrenn
Posted 5/20/2012 23:54 (#2391122 - in reply to #2391114)
SW NE
EAckerman.  Pics, and plenty of them would be fantastic!
Plow79
Posted 5/21/2012 00:01 (#2391137 - in reply to #2391084)
Chilliwack BC
#1 might work but it doesn't matter because #2 exists...
http://www.princehyd.com/Default.aspx?tabid=40
#2+#3 if it were me I would avoid and use an apron chain to unload instead. Our silage boxes have triaxle manure tanker running gears under them but if I had to do it from new I would NOT get tapered boxes. Lower profile tires and a full width box would unload better than a tapered box.
buggy
alebrenn
Posted 5/21/2012 00:18 (#2391159 - in reply to #2391137)
SW NE
Plow79...We were leaning towards dumps for simplicity compared to chains, shafts, sprockets. Also, We wanted the large tires and suspension for stability, safety and also speed in the field. Your thoughts on our thinking?
Old Pokey
Posted 5/21/2012 00:33 (#2391180 - in reply to #2391084)
 #1 would be very in-efficient. You can not run any more flow at pressure than the tractor has. In fact it will be slightly less. It would be better to run the cylinder with the tractor directly.
 #2 is a good system. You can buy the pumps in several configurations. 540 or 1,000 rpm pto shaft sizes, side ports or rear ports on some models from Prince. Various displacements. Cross has some that are a speed increaser that run on the shaft and increase the speed to run a smaller pump at a more efficient rpm.
Plow79
Posted 5/21/2012 00:34 (#2391184 - in reply to #2391159)
Chilliwack BC
Its probably a "here vs there" thing but all silage boxes here are apron chain. Our motors, shafts and sprockets are very low maintenance items. I guess I've heard too many stories of dump boxes tipping on their side to want to go that route, but understand your reasoning as well.
I know what you are saying about the large tires. Ours have 28L26's on them. I think Houle offers some that have a lower profile but are a bit wider to still give a large footprint on the ground, but the box wouldnt sit as high. The Houle website isn't co-operating right now to try to find them. Good luck on your project.
silagehauler
Posted 5/21/2012 00:52 (#2391200 - in reply to #2391084)
Harsh does make a big hoist for such an application, not sure it will do 40 tons, that is a hell of a load, but they will do 30 tons no problem.
countryman
Posted 5/21/2012 03:23 (#2391245 - in reply to #2391184)
Germany
Krampe Bandit and Push Off Trailers    (Fliegl and others) avoid the hassle with tipping, and esp. the Bandit does not consume any oil from the tractor.
Nothing to be built on the farm but nice...
mmaddox
Posted 5/21/2012 09:06 (#2391450 - in reply to #2391200)
Semi's using dump trailers are commonly set up with Commercial Shearing C101 pumps, 30 GPM with 30 to 50 gallon tanks (a 40' trailer will need almost 50 gallons to extend the cylinder). Do have one tractor that has a long two stage, one way cylinder used with it that we added an additional storage tank to provide enough oil, but don't think that is a good option for your application. Your request of a 40 ton hoist has me wondering what kind of gross weight you are considering? There are many States that are pressing to place the same weight limits on farm equipment that apply to over the road equipment. If this happens, the carrying capacity is going to be severely curtailed when a 30,000 pound tractor with a 10,000 trailer is capped at 80,000 pounds.
Gerald J.
Posted 5/21/2012 11:59 (#2391581 - in reply to #2391084)
#2 will need a valve. You don't want to just put the PTO out of gear and let the box fall uncontrolled. And it will need a significant reservoir to hold the oil for a single acting cylinder. It will need a reservoir for a double acting cylinder too, though only a bit more than the volume of the lift cylinder piston rod. And the reservoir also acts as an oil cooler.
There is a flow control valve from Cross with a micrometer adjustment that includes a check valve so it flows free in one direction and restricted the other. Trouble is you'd like to let the trailer bed down fast but slow it near the bottom of the stroke and that's not a handy valve for that. Sold by Northern Tool, Surplus Center, Baum Hydraulics, and Force. The PTO pumps are available from the same sources and maybe TSC and Farm/Fleet stores.
I don't see a benefit to #1 except in fuel consumption where its beneficial to your fuel supplier, not you.
Gerald J.
Edited by Gerald J. 5/21/2012 12:02
tx68
Posted 5/21/2012 21:05 (#2392107 - in reply to #2391084)
Ontario
This may interest you.
We made a dump wagon from an old dump truck.
The original truck pump set up to run on a hydraulic motor.
The interesting bit was we put tiny hydraulic cylinder to pull and push the linkage to the up down valve.
When the hydraulic lever in the tractor is moved the motor turns to lift and the cylinder extends.
They are plumbed together.
When the lever is moved the other way the motor turns backwards for a second till the cylinder retracts
pulling the linkage to let the box down. As soon as the box starts lowering the lever is released and the box
comes down.
One set of remotes does both tasks.
parkbench
Posted 9/19/2013 04:55 (#3336360 - in reply to #2392107)
Australia
tx68, any chance of getting some pictures of your setup? This is exactly what I have been trying to do on a trailer so that raising and lowering can be done from the one set of remotes.
tx68
Posted 9/19/2013 07:07 (#3336519 - in reply to #2391084)
Ontario
Ok Ill get some pics and post them here later today or tomorrow.
wffoker
Posted 9/19/2013 20:42 (#3337856 - in reply to #2391084)
Ohio City Ohio
Guys that chop for us built there own trailers, they use telescoping cylinders, dump a 40 ish ft box, I have seen 36 ton load, ( 130K gross) through tractor remote, they use a T in the hydraulic line and use two tractor remotes to be able to dump faster, but no extra oil tanks that I can see. pull with jcb 8250 I think
tx68
Posted 9/19/2013 21:17 (#3337991 - in reply to #2391084)
Ontario
http://smtp.ciaccess.com/users/[email protected]/Dump%20trailer...
Having trouble with camera-computer cable so I drew up a Schematic and put it at the above link
