Search Forums | Classifieds (13) | Skins | Language
Vermeer R 2300 rake?
derby
Posted 5/15/2012 21:07 (#2384042)
Subject: Vermeer R 2300 rake?
What is the pros and cons of a R2300 rake. Was  looking at a wheel rake but these look better for moving and picking up hay, but more money then a wheel rake.
mad cow
Posted 5/15/2012 22:04 (#2384149 - in reply to #2384042)
Subject: RE: Vermeer R 2300 rake?
Alhambra Il.
All pro's very good rake I'm on my 2nd rake.
wayneNWAR
Posted 5/15/2012 22:05 (#2384152 - in reply to #2384042)
north west arkansas
I dont know about a 2300 but my old r23 has been indestructable. I bought it used in 1998 and have raked several and I mean several thousand acres with it and have done virtually nothing to it. We also have a 8 wheel rake on a caddy, and this year we bought a 10 wheel hi-capacity rake but they are not near the rake that the old r 23 is. The thing I always liked about it was it didn't matter who was running it the windrows were always perfect.
Campbell Farms
Posted 5/15/2012 22:18 (#2384200 - in reply to #2384152)
Subject: Re: Vermeer R 2300 rake?
Sw Mo
If set properly a basket style rake ( new holland side delivery or Vermeer) will make a beautiful windrow, putting most of the green hay on top and the dry on bottom, square on top and sides, making a joy to bale hay. You might not be able to drive 10 mph with one and do such a good job but unlike wheel takes they won't swirl the hay into a screw configuration so to speak. Also won't drag rocks or clods of dirt in windrow because they aren't dragging on ground, if you bale much alfalfa they seem a lot more gentle on the leaves also.
Went from 3 past weel rakes to the r23 manual everything to a 2800 now. Wouldn't ever go back to a wheel style rake, granted they have there place, central ks in prarie hay infront of a 4x4 square a wheel rake might be better, otherwise doubtful.
derby
Posted 5/15/2012 22:48 (#2384275 - in reply to #2384200)
what would a ball park price be on a brand new R2300 rake?
Big Square
Posted 5/15/2012 23:32 (#2384389 - in reply to #2384275)
Eastern Half of Kansas
Don't hold me to it but about 15k.
yallardeere
Posted 5/16/2012 17:13 (#2385195 - in reply to #2384152)
Does your 23 have old style bearings .....or new 1 piece........I changed mine to 1 piece, stopped greasing 24 fittings...just changed them when old ones went out....will fit in same place but use a 3/4 x 4 fine thread bolt...in 7 or 8 years only changed out 3 bearings and mine sits outside all the time...
