Search Forums | Classifieds (160) | Skins | Language
How do you plant your corn fields?
Chris22
Posted 4/28/2012 14:10 (#2357921)
Subject: How do you plant your corn fields?
Wisconsin
This probably sounds like a funny question, but I'm just curious as to how you guys plant your fields and why you do it the way you do? Obviously you want to make it easy for the combine but do you do you plant your headlands first, then work from one side all the way across? Or does anyone outline their field and then end up with the uneven rows inside the field?
NEILFarmer
Posted 4/28/2012 14:28 (#2357945 - in reply to #2357921)
Subject: Re: How do you plant your corn fields?
Morris, IL
Go around field counter clockwise, then turn around and go clockwise 1 or 2 more times. Then start somewhere most likely on the strait side. I'm shooting to allow combine to go clockwise so it can dump on the go all around the endrows. Works pretty good, just have to sometimes butt into 6 more rows because i plant with 12 and combine 6 rows.
farmnmn
Posted 4/28/2012 14:32 (#2357951 - in reply to #2357945)
Walnut Grove, MN.
we plant the headlands on the front of the field first then head down the staight side of the field  then plant the headlands on the back side of the field them goen done the straight side again get my A B and plant the rest of the field.
steveMIfarmer
Posted 4/28/2012 14:45 (#2357968 - in reply to #2357921)
West Michigan
I plant what I call a "C" shape. Plant longest straight edge then the first portion of back end rows. That way there is never any outside corners. Also don't have your point rows out in the field. Puts the point rows at the edge where there may be trees or coons that tip it all over ect. Never cared for the two times around the field. Not sure if anyone plants the way I do?? Seems almost everyone around here plants the two times around. Because I hate the way swath pro shuts off rows if your boundry is not right. Everyone said just shut it off the first time around the field. I told them I dont plant all the way around the field and everyone looked at me like I was crazy.
Herdboar
Posted 4/28/2012 14:49 (#2357972 - in reply to #2357968)
Mankato MN; Casa Grande AZ
Put the odd rows in 24 rows with 12 row planter.
They are not so weedy there, and you can cultivate along the fencline.
cz4586
Posted 4/28/2012 15:19 (#2358007 - in reply to #2357921)
Subject: RE: How do you plant your corn fields?
NE Indiana
Some are harder than others to figure how to plant. Here's one of ours. It's about 35 acres.
(se.jpg)
Attachments se.jpg (23KB - 716 downloads)
IHboog
Posted 4/28/2012 15:35 (#2358023 - in reply to #2358007)
WCIN
That doesn't look that bad. I have an 8.5 acre field that has 17 sides on it. With a 40' planter I try to make 2 pass around the outside of the field, and then I come back in and fill in any holes. Usually I make 2 passes all the way around the field, and then start on the straightest longest side and work across the field. This also depends if the ground pounders are still in the field, or have moved on to the next field.
Mlebrun
Posted 4/28/2012 15:44 (#2358033 - in reply to #2358023)
SW MN and Gold Canyon AZ
Work in a C shape. I never go around the field planting corn then you will have odd rows when you get done. Start along the fence and work towards the middle. I go around the field planting beans because i make my tram lines with the left side of the planter. Go around counter clockwise then reverse direction for the trams.Then go up and down. 40 ft planter 80 ft sprayer. No foamer or GPS needed on the sprayer.I have a 16/31 Kinze and move 4 row units around to make tram lines
johndeere430u
Posted 4/28/2012 16:38 (#2358103 - in reply to #2358033)
Central, mn
Go around twice and go to a straight side and plant all the way across. This way I will only have 1 set of wedge rows
mcupps
Posted 4/28/2012 17:23 (#2358154 - in reply to #2357968)
Downtown Shell Knob MO Come Visit!
I also make a C Its not really much different than going two around, I don't know why I do it that way, I just like it better. No swath pro here, just markers. It seems like it takes for ever to go twice around but if you make a C and then turn around , you have headlands and are planting in no time at all. Its all in my head though.
1957farmer
Posted 4/28/2012 17:39 (#2358184 - in reply to #2357921)
We have terraces some fields I plant two rounds ( 8 row planter) some fields that have high angle point rows I'll plant three rounds around to give more room to turn with planter & 8 row combine. Then try to find the longest terrace & start. Always said if we had square flat fields we could cover twice the acres!!
plowman
Posted 4/28/2012 17:43 (#2358196 - in reply to #2358103)
streator illinois
First pack a cooler of Bud Light then Endrows weaving in and out of power poles and always backing up to them to get the most out of the land. Then give er hell. If the ditch is available ill use that to turn around and not use headlands. By this time I'm usually waisted and dont care how straight or were my point rows are. The sprayer guy loves it and come harvest it usually a blur so its just like planting it.
Just haveing fun on a cold gloomy day. I plant headlands then whatever is best for that field most of us have a good understanding for our groun
gleanerman
Posted 4/28/2012 17:52 (#2358212 - in reply to #2358196)
NE Indiana
plowman - 4/28/2012 17:43
the planter I getttt theeeeeeeeeeeeeee drunker aaai straight!
Posted 4/28/2012 19:47 (#2358413 - in reply to #2357921)
Subject: Some of you guys make it sound
so easy. I must be doing something wrong.
(untitled-1-17 (Large).jpg)
(untitled-1-18 (Large).jpg)
Attachments untitled-1-17 (Large).jpg (37KB - 709 downloads)
Attachments untitled-1-18 (Large).jpg (37KB - 729 downloads)
Gerard
Posted 4/28/2012 20:41 (#2358528 - in reply to #2357921)
Woodham, Ontario
I like to go twice around with the 16-row, but if it is 100+ acre field, the field cultivators may still be in there too and I may have to do a C-patern for the headlands and finish the headlands once the C is filled in. Row shutoffs are amazing, first year with them.
starvation
Posted 4/28/2012 20:46 (#2358539 - in reply to #2358528)
mn
I do nothing fancy, I just use a corn planter
DixieDeere
Posted 4/28/2012 23:05 (#2358827 - in reply to #2357921)
Jackson County, AL
Dad likes us to go around everything at least twice since he does the spraying. We plant with a 12 row and he sprays with a 90 ft boom. With 60 ft all the way around he has that outside through to drive in vs. just aiming the sprayer across whatever rows happen to be in the way. If we must only plant one through next to a thicket he likes us to at least drop a marker for him to use when spraying.
cr39
Posted 4/28/2012 23:20 (#2358864 - in reply to #2358033)
Northeast ks
If you plant in a C- shape, you end up running over corn with the combine unless you have room to turn around in the corners outside of the field.
Around here, most everyone plants two or three times around a field because there are a lot of trees or fence rows. The rows are planted with the straightest side of the field, which is usually by the roads. Terraced ground most people plant with the terraces, although some go over them in straight lines.
M & G
Posted 4/29/2012 00:09 (#2358949 - in reply to #2357921)
I'm not following, someone explain the "C" shape to me.
Posted 4/29/2012 00:34 (#2358965 - in reply to #2358949)
Me too, kinda. I try to plant things so the next sprayer and sidedress pass have an easier time getting clear around the field and knowing where they are. Next consideration is making it so the cart and combine can work. If that takes a couple extra minutes with the planter I will do it.
Big Ben
Posted 4/29/2012 01:28 (#2359003 - in reply to #2358413)
Subject: RE: Some of you guys make it sound
Columbia Basin, Ephrata, WA
Holy cow. So that's why row shutoffs were invented.
Our fields are mostly circles, so there are almost always dry corners to turn around on. It makes planting and harvest WAY easier.
OntariOtis
Posted 4/29/2012 08:15 (#2359134 - in reply to #2357968)
Ilderton, Ontario
I plant 2x around field so that the sprayer operator has rows to follow to keep the boom out of the fence, trees, etc. then I go to the longest straightest side and start.
1DH
Posted 4/29/2012 11:52 (#2359580 - in reply to #2358965)
swia
I just know everyone else's planted field looks like a picture an mine looks like a puzzle. Seems to all get combined. Ran two this last week, one with all bells and whistles, one with out. You have to be pretty alert to catch right line with auto steer. Going around corners on a steep side hill( I don't mean 90's) the old sf2 doesn't quite do the job, you can really watch your planter better with auto steer, if your not on the phone. I guess the best thing about auto steer is no marker tracks to wash out.
Technology is nice , Im not sure it is going to be the deciding factor if a farm prospers or not.
obie_iaffa
Posted 4/29/2012 11:54 (#2359585 - in reply to #2357921)
NE Iowa
2 rounds with the 16 row first, then some fields we start in the middle, some we start next to a terrace, and some are next to the fence. Then we usually go over here and go this way for awhile, then head to the other end and go that way for awhile, and then fill in the rest of the field going toe other way. All of this while trying to stay on the contour. My uncles farm sqaure 80's and 160's in central Iowa and always shake and ask, "how in the grawlix do you know where to start when you plant these fields?" Here's what alot of our fields look like. Makes me appreciate the precious few acres we have that I can set an AB line on.
Edited by obie_iaffa 4/29/2012 11:58
(Home Place-Grid Location-400.jpg)
Attachments Home Place-Grid Location-400.jpg (15KB - 774 downloads)
