Search Forums | Classifieds (163) | Skins | Language
Urea lbs per acre?
TLSJR
Posted 4/22/2012 14:39 (#2348650)
Subject: Urea lbs per acre?
central Minnesota
How many lbs per acre of urea do you broadcast for corn. Some acres are corn on corn and some were beans last year. I am also putting on 200 lbs of 10-12 24 dry fert on with the planter. Putting the urea on with a pull behind broadcast spreader. south central minnesota, good ground and not irrigated. Hope thats enough info. Thanks for the help Tom
neks
Posted 4/22/2012 17:44 (#2348913 - in reply to #2348650)
Subject: Re: Urea lbs per acre?
Riley County Kansas
What is your yield goal? If it were me in our part of the country, I would probably broadcast 325-350# that would give you a total of approx. 170#-181# of N total including your starter. I would also use Agrotain and maybe include some ESN as part of your program. Remember that is for this part of the country where good ground might make 180 on a good year but more like a 150 normally.
iseedit
Posted 4/22/2012 20:15 (#2349177 - in reply to #2348650)
Subject: RE: Urea lbs per acre?
central - east central Minnesota -
TLSJR - 4/22/2012 13:39 How many lbs per acre of urea do you broadcast for corn. Some acres are corn on corn and some were beans last year. I am also putting on 200 lbs of 10-12 24 dry fert on with the planter. Putting the urea on with a pull behind broadcast spreader. south central minnesota, good ground and not irrigated. Hope thats enough info. Thanks for the help Tom
As you know, the CoC will require a bit more N then the bean ground - due to residue break down.
Figure about one pound of N per bushel of corn you want . . . Don't forget some AMS for sulfer. On CoC maybe consider a strong pound of N per yeild goal bushel, w/AMS. . . . .
Iowa Ag
Posted 4/23/2012 10:47 (#2350170 - in reply to #2348650)
You do need to know your yield goal to determine the rate of urea per acre, but there is another option that mixes and protects the nitrogen by adding only one product to your urea and that is NZone Max. A new product that is very safe to you, your crop and the environment while feeding more nitrogen to the corn plant. An excellent product that brings more dollars to your bottom line.
jackrabbitag
Posted 4/23/2012 11:28 (#2350213 - in reply to #2348650)
SC MN
In your location in MN, I'd look at 100# AMS for sure and for bean ground I shoot for 140-150# N for sure, and corn on corn I add another 40-50# N for a total about about 180-190# actual N.
cottonhauler
Posted 4/23/2012 12:48 (#2350270 - in reply to #2348650)
Zabcikville, TX
"Here" the general rule is 1 "unit" per bushel. What is your yield goal? Its about 120 here, about the most we can make with conditions perfect. 46 units/100# of product (urea). Just depends on your yield goal.
TLSJR
Posted 4/23/2012 13:10 (#2350291 - in reply to #2350270)
central Minnesota
200 bushel is my yield goal, so 350 on bean gound and 400 on coc. ams is ammonium sulfate correct? thx
