Search Forums | Classifieds (54) | Skins | Language
My Air-seeder
Posted 3/18/2012 23:16 (#2294555)
Subject: My Air-seeder
In contrast to last year's late spring, things are markedly different this year. Celebrated St. Pat's day in the MT this year. Still a few wet spots that would have made big problems for anything other than this rig.
MT & Concord
MT & Concord
mikejd4020
Posted 3/18/2012 23:20 (#2294572 - in reply to #2294555)
Subject: RE: My Air-seeder
Bainville, MT
what kind of monitor
LOWRIDER
Posted 3/18/2012 23:34 (#2294601 - in reply to #2294555)
Subject: Re: My Air-seeder
Ed, what openers are you running and any disc levelers ?
wheaties
Posted 3/18/2012 23:44 (#2294635 - in reply to #2294555)
very nice!!
Posted 3/18/2012 23:47 (#2294639 - in reply to #2294601)
Farmland SB2 seed boots and McKay 5" sweeps on the plain C-shanks. The tool had disk levelers but I took them off and have them in a pile waiting for someone to buy them. I'm seeding at 4.5 MPH so the levelers aren't necessary to keep from stair-stepping.
Posted 3/18/2012 23:49 (#2294645 - in reply to #2294572)
I don't have any run blockage monitors. The setup came with an Agtron monitor to keep track of shaft speed, fan speed, and tank levels. I found the seed flow sensors to be unreliable so replaced them with an in-tank camera.
Posted 3/18/2012 23:55 (#2294658 - in reply to #2294555)
Subject: And a short YouTube
2:33 minute video. Not the best quality but it gives an idea.
http://youtu.be/4OEXv3vuWIE
Primer
Posted 3/19/2012 00:34 (#2294735 - in reply to #2294555)
Radville, SK
What is your normal seeding date?
We're about 150 miles north of you, and still over a month away from seeding.
Edited by Primer 3/19/2012 00:34
Matts
Posted 3/19/2012 01:53 (#2294790 - in reply to #2294555)
50 miles west Stockholm , Sweden
Is it a early year at your place?
It is early here to, but 2 weeks from seeding!
Matts
trakman
Posted 3/19/2012 06:33 (#2294836 - in reply to #2294555)
Central Kansas
2 minutes and 33 seconds and you never turned around...................is the field MORE than a mile long?
snowcone
Posted 3/19/2012 06:44 (#2294843 - in reply to #2294555)
Great Southern, Western Australia
It seems quite loud in the cab?
Old Pokey
Posted 3/19/2012 08:03 (#2294947 - in reply to #2294658)
Subject: RE: And a short YouTube
 No run monitor? Cool........sign me up.
 Thanks for the pictures and video Ed.
Posted 3/19/2012 08:50 (#2295027 - in reply to #2294790)
Subject: Seeding date
Hi Matts, Yes it is very early to be starting. The first year I farmed on my own, I started Mar. 25 1970. Unlike this year, that spring had very dry & dusty ground. We didn't get much rain throughout the growing season and the crop showed it too. Then that fall, the price of wheat fell to $1 a bushel. What a way to start a farming career!
This year, the ground is very wet and the price looks to be much better too so we're hoping for much better results.
Posted 3/19/2012 08:56 (#2295036 - in reply to #2294836)
Subject: Long ways from end to end
The field is over a mile and a quarter long. I have the Operator Alive time limit on the Guidance set as high as it allows (15 minutes) and it beeps & requires input before the rig makes it from end to end.
Posted 3/19/2012 09:32 (#2295076 - in reply to #2294735)
Subject: Normal start date
I usually try to start seeding April 15 or thereabouts.
Big winter storm to our west this AM. Might be a while before I finish this field if it makes it this far east.
Posted 3/19/2012 09:36 (#2295085 - in reply to #2294947)
Might not be quite accurate to say I have no "run" monitor. Every couple passes, I get out of the tractor, run back to the cart, give the feed handle a crank or two,  check that stuff is coming out of all the openers, and run back to the tractor.
JDBrian
Posted 3/19/2012 10:46 (#2295167 - in reply to #2295085)
Dietrich, Idaho and Mountain Home, Idaho
That is a good way to get your exercise!! Nice video(finally got high speed internet so I can view videos now) and pics. Looks like a very nice rig you have there. Is the rtk working well for you? Looks like it is kind of dry there. Was the same way here until a few days ago. Now we don't dare go into the fields or we won't get out for a while! Sure has been a different winter here. Good luck this year.
Primer
Posted 3/19/2012 11:44 (#2295218 - in reply to #2294836)
Radville, SK
I have one field that is 1.75 miles long and 1 mile wide :)
1156versatile
Posted 3/19/2012 12:54 (#2295282 - in reply to #2295085)
Strathcona, mn
That's my run monitor on my concord too.... LOL! it is a lot more reliable and gives me less headaches than the kind with all the wires. Those concords are pretty darn ahd to beat in my opinion. I use the same 60' as you and then I have a 40' that I use as a cultivator/fertilizer applicator in front of the planter.
Posted 3/19/2012 13:09 (#2295300 - in reply to #2295167)
Subject: RTK Working?
Yes, it's all that I expected and more. My farthest field from the radio tower is 3 3/4 miles. I've been using a Honda 4-wheeler for surveying with the radio antenna mounted on the front rack. Still had good signal @ 4 miles away. I'd expect even better range with the antenna mounted on the roof of the tractor. The advantages of flat, treeless farm location.
Matts
Posted 3/19/2012 13:24 (#2295321 - in reply to #2295027)
Allways good to be out early seeding springwheat insted of late seeding!
Good luck Ed!
mennoboy
Posted 3/19/2012 13:52 (#2295363 - in reply to #2295085)
Rivers, MB
Ed, you need to let our neighbor now about your blockage monitor. Our neighbors hired man seeded 500 ac with 1/6th of the drill plugged! That was not a good situation.
Chad H
Posted 3/19/2012 13:56 (#2295369 - in reply to #2295085)
NE SD
For years we only had a blockage monitor that had one sensor for every tower. Every hour or two we would do like you did. Have you ever just stopped, picked the drill up, and drove forward a few feet when you get to the end? Works the same way but saves having to spend the time cranking on the cart drive.
wheaties
Posted 3/19/2012 22:51 (#2296340 - in reply to #2294555)
Was that summerfallowed last year?
Posted 3/19/2012 22:57 (#2296360 - in reply to #2296340)
Yes it was fallowed last year. All of the field was chem fallowed and some had a pass or two of mechanical tillage. We were extremely wet last spring and early summer so lots of stuff was done in a different way than usual for me.
LOWRIDER
Posted 3/26/2012 10:33 (#2306951 - in reply to #2294555)
Ed, could you explain your in tank camera set up ? Hard wired--wireless?? mounted in the cover or down by the meter ? Picture quality ?? we would be putting them in a steel cart (concord)
Thanks
Posted 3/26/2012 11:20 (#2306985 - in reply to #2306951)
It's a wired system that I bought from this outfit: http://www.ebay.com/itm/7-REAR-VIEW-BACK-UP-CAMERA-SYSTEM-REVERSE-TRUCK-SAFETY-/260746847656?pt=LH_DefaultDomain_0&hash=item3cb5b925a8
I mounted my camera on the center divider inside the tank -- as high as I could get it and pointed at the feed roller. The IR LEDs in the camera illuminate the product so you can see inside the tank when the lid is sealed. When the tank is full you can see a ring of white blur. As it empties, focus improves so you can see the product and also the ladder rungs as a guide to how full the tank is. When the tank empties, you can see the roller turning and the individual flutes that expose themselves more and more as more product empties out.
I don't think a wireless camera would transmit very well from inside a metal tank but since any camera needs power anyways, the signal cable also has power wires and it's no extra work to run the combined power/signal wire. I routed the cable through the same place that the tank level sensor entered the tank. On my Fargo-Aire cart, that happened to be through the tank pressurization tube.
