Search Forums | Classifieds (114) | Skins | Language
CaseIH MXM 190 tractor, any good?
PiperPA-11
Posted 3/2/2012 18:08 (#2263614)
Subject: CaseIH MXM 190 tractor, any good?
We have the opportunity to purchase a low hour, excellent condition MXM 190 for a fair price and have never owned a Case tractor before.
1586
Posted 3/2/2012 18:20 (#2263633 - in reply to #2263614)
Subject: Re: CaseIH MXM 190 tractor, any good?
I think I would rather own a Case tractor than a CaseIH MXM.
hagey01
Posted 3/2/2012 19:47 (#2263822 - in reply to #2263614)
oshawa, ontario
We had a MXM155 and I wouldn't take it back if the dealer gave it to me. Another piece of case equipement New Holland got there hands up and screwed up big time. Terrible motor, terrible cab, terrible controls, get the point.....
cwjones
Posted 3/2/2012 20:22 (#2263919 - in reply to #2263614)
Southern Indiana
A friend of mine had a mxm 175 (basically the same tractor) and he said it was a gutless wonder. No low end power so you had to keep it would up all the time. Hydraulics and the cab were ok and it never overheated but it always had its tongue hanging out. He said it would be an awesome hay/cattleman tractor. He couldnt have said it any better.
Ltfire
Posted 3/2/2012 23:20 (#2264304 - in reply to #2263614)
Subject: RE: CaseIH MXM 190 tractor, any good?
North Central Iowa
I talked myself into one a couple years ago.  There's a reason that they are cheaper than other tractors the same size and age.
Mike
silverluv75
Posted 3/3/2012 00:56 (#2264433 - in reply to #2264304)
SE North Dakota
We have a MXM 190 with 2400 hrs on it and really like the tractor. Had some sensor issues with it at first but haven't done anything to it since then. Good tractor shifts nice too when calibrated, book tells you how to do it.
JHEnt
Posted 3/3/2012 07:13 (#2264522 - in reply to #2263614)
Southern Illinois
The MXM series is a NH TM series tractor. The MXM 175/190 have electronic controlled fuel pumps. If there is any lack of power it would be based on the electronics. Probabliy the emmissions controls limiting response based on turbo pressure. The engine is a 7.5L Genesis engine. That same engine in a CR940 combine will pull a sustained 300HP load. Combine has different injectors and a P series pump. Other than that it is the same engine.
When the merger of NH and CaseIH took place CNH went and respec'ed all of the electrical sensors and sending units, to a cheaper supplier. There were alot of issues with failed pressure warning switches, oil seeping from pressure warning switches ect. If they haven't failed by now you should be good to go. That is the main complain Case guys had about them. They always blamed NH but NH had no trouble with the tractors untill the merger took place. Corperate accountants were the problem not the design.
NodakSE
Posted 2/26/2018 21:23 (#6607383 - in reply to #2264433)
Still Like that tractor, im in the market for a new one and a mxm 190 with 4600 hours is on the market just wanted to know your thoughts and what to look for.
Lauritsenag
Posted 2/27/2018 13:04 (#6608460 - in reply to #2263614)
Had a mxm 140 for a short time. Decent tractor for loader work, but I hated the transmission. You have to go thru all the gears when you shift up or down. In a field situation that would be ok, but personally I didn't like it.
