Search Forums | Classifieds (41) | Skins | Language
Problem with Bourgault Aircart Monitor
paulmac
Posted 2/29/2012 08:54 (#2258696)
Subject: Problem with Bourgault Aircart Monitor
Australia
I was trying to help a mate setup a Bourgault Deluxe Air seeder monitor (491) on his 5295 cart. Monitor won't find any of the sensors.  Unplugged all sensors except ground speed as directed in the manual, then turned on the monitor. Selected Discover Sensors from the menu as instructed. It should then discover the speed sensor, beep twice and then wait for the next sensor to be plugged in, but just sits waiting for  the speed sensor to be plugged in, even though it is. There's a red light flashing slowly on the speed sensor, so it's got power, but that's it.
Bourgault in Australia don't really seem to care too much, as he's rung 4 or 5 times and they say someone will ring back, but of course nobody does. Any idea's what to try next? It's a 2003 model and was 'working'  with the previous owner. I've checked the wiring harness and can't find any faults, but told him to take the plugs apart and check terminals, just to be sure. I assume as they call them 'smart' sensors, they're using a canbus system, as there's only 3 wires going to all the sensors.
rodd
Posted 2/29/2012 09:17 (#2258741 - in reply to #2258696)
Subject: Re: Problem with Bourgault Aircart Monitor
Check the back of the monitor. Make sure wires are hooked to the correct ports.
mralleyoop
Posted 2/29/2012 15:59 (#2259370 - in reply to #2258696)
Subject: RE: Problem with Bourgault Aircart Monitor
South Dakota
Maybe check the harness connectors again. If someone treated them with dielectric grease or something similiar the female part can expand as the grease is pushed in when reconecting and lose contact.
paulmac
Posted 3/1/2012 06:15 (#2260594 - in reply to #2258696)
Australia
Yep, fixed! He took the plugs apart as suggested and found the green signal wire had pulled out of the terminal, just annoying that the other 2 were ok, making the light on the sensor work.
