Search Forums | Classifieds (15) | Skins | Language
Vermeer baler belts
poorfarmer36
Posted 2/15/2012 11:05 (#2229971)
Subject: Vermeer baler belts
Central Iowa
I have to put new belts on my 605M Vermeer baler. I bale a lot of cornstalks. I am not happy with the alligator splices. Where can I buy some other type of belt with a different splice that holds up better at a reasonable price. I think the last time I went to the dealer he charged me close to $400 per belt.
ccjersey
Posted 2/15/2012 14:15 (#2230238 - in reply to #2229971)
Subject: Re: Vermeer baler belts
Faunsdale, AL
I would call Hammond Equipment 334-627-3348. They're a Vermeer dealer and also a belting dealer. Should be able to advise you about the different splices and belts as well as quote you a set of belts if you want. Several years running, Don has sold more belts than any other dealer in the United States, so he knows a thing or two.
swmnhay
Posted 2/15/2012 16:16 (#2230385 - in reply to #2229971)
Reading Mn
What actually failed on the splice?I've never had a Alligator splice fail.
poorfarmer36
Posted 2/15/2012 17:02 (#2230455 - in reply to #2230385)
Central Iowa
They tear loose where they are riveted to the belt.
swmnhay
Posted 2/15/2012 17:39 (#2230512 - in reply to #2230455)
Reading Mn
Have you replaced the pins in the lacing?Perhaps a pin wore threw and not pulling on entire lacing.
Have you replaced a belt?They need to all be same length.Old one will be stretched.
feelnrite
Posted 2/15/2012 17:53 (#2230536 - in reply to #2230512)
northwest tennessee
Speaking of replacing the pins what is the most simple way to do that? I have a 535 that I need to do this year.
swmnhay
Posted 2/15/2012 19:14 (#2230707 - in reply to #2230536)
Reading Mn
Take tension of of belts.Put vise grip on one end of pin and pull out 1/2 way then start new pin from other side.Work new pin in as you pull out old pin.
KS Prairiefarmer
Posted 2/15/2012 20:55 (#2230954 - in reply to #2230707)
South central KS
How old is your baler mine is a 2011 had bad belts vermeer took care of it pulling out at lace
poorfarmer36
Posted 2/15/2012 22:24 (#2231260 - in reply to #2230954)
Central Iowa
I replaced two belts last fall. They all are going to be replaced very soon. I did replace all of the pins last fall too. The baler is a 2008 model.
rhandlos
Posted 2/16/2012 05:04 (#2231643 - in reply to #2229971)
WC Iowa
Do you have a M or Super M. I have a set for the SM that I may part wiith . Im over by Carroll. Or, if your belts arn't totally shot, take them down to Ag Belt in Des Moines and have them relaced. They are the people that Deere and Vermeer were getting them from. Call down and ask for Jon. He has been there the longest and knows his stuff.
poorfarmer36
Posted 2/16/2012 06:47 (#2231675 - in reply to #2231643)
Central Iowa
I have the 605M not the Super M.
rhandlos
Posted 2/16/2012 11:35 (#2232186 - in reply to #2231675)
WC Iowa
I have 3 of the 522 inch belts and 1 of the 533 inch belts if you are interested and some good used ones, but I wouldn't mix them if it was me.
poorfarmer36
Posted 2/17/2012 08:22 (#2233975 - in reply to #2232186)
Central Iowa
Go ahead and email me info about them rhandlos. I just made my e-mail public on my profile.
Hay DR
Posted 4/3/2013 08:53 (#3010148 - in reply to #2229971)
Subject: RE: Vermeer baler belts
Johnson City, TN
poorfarmer36 - 2/15/2012 13:05 I have to put new belts on my 605M Vermeer baler. I bale a lot of cornstalks. I am not happy with the alligator splices. Where can I buy some other type of belt with a different splice that holds up better at a reasonable price. I think the last time I went to the dealer he charged me close to $400 per belt.
GoodYear has developed a belt for corn stalk operators that have Vermeer balers. The belt is called the 315 Rock. It is designed for the 604 & 605 Super M balers and currently the OEM supplied belt.  The USA made Flexco Alligator lacing only cost $20 per belt for a dealer. Most dealers will charge around $50 per belt. You can use the MATO lacing like John Deere does but the lacing is made in Germany and is more expensive.
