Search Forums | Classifieds (27) | Skins | Language
John Deere 995 switch plow
12th Man
Posted 1/3/2012 22:18 (#2141702)
Subject: John Deere 995 switch plow
Does anyone on here know where any good used 8 bottom plows are that can be bought reasonably
farmerboy50
Posted 1/3/2012 22:25 (#2141720 - in reply to #2141702)
Subject: Good luck!
West Texas
Had a friend looking for one and basically decided on a 7 because the only way he was getting an 8 was to order it. A few guys run them but break pins and can't pull them deep
WTXCottonguy
Posted 1/4/2012 00:23 (#2141969 - in reply to #2141720)
Subject: RE: Good luck!
Lorenzo, tx
Jeremy Ive heard that an odd number bottom plow will do a better job than a even number of bottoms. Any truth to that?
Badger
Posted 1/4/2012 07:07 (#2142098 - in reply to #2141969)
Subject: Re: John Deere 995 switch plow
Huntley Montana
I bought a new 8 bottom last fall, ordered another 1 for next fall. The 3 problems I had with the 1st 1 are shear bolts don't last, (went through 300&), & the center hitch pin & rear gauge wheel are JUNK. Replaced the center pin with a grade 8 bolt & bought a wheel from GENSCO for the rear. Have a idea for the shear bolts to grind a little where the bolt goes through to get them to be "more over center" to make them harder to shear..
Was supprised on how easy the 8410 pulled the 8 bottom. I farm every thing from blow sand to some gumbo that weighs 50 oz to the pound.
azcutter
Posted 1/4/2012 11:10 (#2142529 - in reply to #2141702)
Subject: RE: John Deere 995 switch plow
Casa Grande,AZ
B E implement Lamesa,tx has a 7 bottom 995
Hay Hud Ohio
Posted 1/4/2012 11:34 (#2142584 - in reply to #2142098)
SW Ohio
50 ounces to the pound? that is some tight dirt, ours only goes 35 ounces in the bad spots!!
farmerboy50
Posted 1/4/2012 14:19 (#2142798 - in reply to #2141969)
West Texas
6 bottoms seem to be a little more difficult with a guidance, but it can be done. 7 bottoms are fairly easy and I'm told 8 bottoms are easyto set using guidance. But I've put lots of time in on a 965 6 bottom and it would level and be straight as a string.
