Search Forums | Classifieds (82) | Skins | Language
9530 vs. 9630
TMAXX32
Posted 12/20/2011 00:36 (#2113554)
Subject: 9530 vs. 9630
SW, Manitoba
Looking into purchasing a John Deere 9630. Then got looking at some of the pricing on a 9530. Wondering if I could chip a 9530 to get the power up to or over the 500hp mark, and is this safe? I believe the block and planetary drives are the same, so should be safe on drivetrain? Anybody have any experience with this let me know. Thanks.
mshaw
Posted 12/20/2011 06:37 (#2113650 - in reply to #2113554)
Subject: Re: 9530 vs. 9630
Thumb of Mi.
Use a steinbauer chip and you will be amazed at how the 9530 does, well over 500 hp. Been using them for about 3 years and have them on 3 tractors, no problems, no regrets.
thekcirp
Posted 12/20/2011 08:23 (#2113750 - in reply to #2113650)
NEMO
Can I get one for my D-17? I'm gonna try and get 700 acres in one day spraying this year and thought the extra power would help the "nurse tractor" in the soft spots. NT
Jari
Posted 12/20/2011 08:35 (#2113766 - in reply to #2113554)
Subject: RE: 9530 vs. 9630
You can bump a 9530 up to 9630 specs with no issues. You are correct in that the engine and drivetrain is largely the same with both models. For your interest, here's a dyno chart showing before and after results for a 9430.
http://www.ekotuning.com/html5uploader/files/John%20Deere%209430.pdf
  Similar results can be expected for a 9530.  Here's a short video showing a dyno pull for 9330: http://www.youtube.com/watch?v=nzHIeD9ZFqk
As others have said, chipping is one option but if you're interested to know more about reprogramming, please email me.
*full disclosure in profile*
TMAXX32
Posted 12/20/2011 10:23 (#2113965 - in reply to #2113650)
SW, Manitoba
Have you used them on a 9530 or just a 30 series tractor? I would be worried about using it on a 9630, but for an engine and drivetrain that are already tuned down, figured this would be an option at least.
TMAXX32
Posted 12/20/2011 10:30 (#2113979 - in reply to #2113766)
SW, Manitoba
We chipped our sprayer and after two weeks, I had ruined an injector, but we had chipped a 9300 years back and had no problem. Is that what most programs or chips are doing, just pumping out more fuel through the injector which is now putting out even higher pressure on it? Heard stories of injectors wearing holes in piston and side wall of blocks.
4020R
Posted 12/20/2011 12:02 (#2114105 - in reply to #2113554)
Tell me why you could get a 9530 in a scraper special but not a 9630
mshaw
Posted 12/20/2011 12:33 (#2114144 - in reply to #2113965)
Thumb of Mi.
been using them on 9530's, 9420's 9320's 9300's so far, neighbor using one on a 9330.
TMAXX32
Posted 12/20/2011 12:46 (#2114162 - in reply to #2114105)
SW, Manitoba
That is interesting... I would like to know too. You got any ideas?
Jari
Posted 12/20/2011 16:50 (#2114468 - in reply to #2113979)
I can't speak for all "chips" or "power modules" but a vast majority of them make power by increasing fuel pressure. Injector problems are the result but as you mentioned, worst case scenerio is a hole in the piston due to excessive heat. Steinbauer apparently is able to fool the computer to adjust more then just rail pressure and I'm sure there is someone here who can describe how they work better then I can. Your sprayer injector problem may or may not have been caused by the chip, but it's safe to say that by raising rail pressure beyond oem specs, things will wear out quicker. A good programming tune does not alter any values beyond oem specs (ie. if you want a 9530 programmed to 9630 specs then rail pressure along with injection timing + a few other variables will be exactly at 9630 OEM specs). Programming makes it possible to tailor make the upgrade to suit your needs, or if you prefer you can purchase your own hand held programmer which stores several different tunes allowing you to program your ecm for the power needs of the day. This is pretty popular with the large frame tractors since they don't need huge power for every job, but a couple times a year its nice to have 550 or 600 hp. In the event you want your tractor returned to stock its just a matter of hooking up to the diagnostic port inside the cab and pressing a few buttons. Very common in the pickup truck tuning world. Your choice depends on your needs. Check out the options and which one suits your needs the best. Just be careful of the inexpensive products because in my view, the old saying still holds true. You get what you pay for.
1GREENACRESFARM
Posted 12/20/2011 17:04 (#2114498 - in reply to #2114105)
south Central La between Alexandria and Lafayette
9630 does indeed come in scraper versions
Jari
Posted 12/20/2011 17:30 (#2114540 - in reply to #2114498)
http://www.deere.com/wps/dcom/en_US/products/equipment/scraper_trac...
S.C.B. Farms
Posted 12/20/2011 17:52 (#2114581 - in reply to #2114468)
Southeast Iowa
Has anyone ever had any expericence with chipping a 9630 ?
4020R
Posted 12/21/2011 01:33 (#2115597 - in reply to #2113554)
Sorry about that. The earlier 9520 vs 9620 series I think only where scraper available in the 9520 series
