JD Conservation planter vs. regular
beef farmer
Posted 12/16/2011 18:57 (#2107163)
Subject: JD Conservation planter vs. regular
Northwest Illinois
I am looking at John Deere planters (7200 6-30) and run across Conservation planters and "plain jane" planters. Could someone tell me the difference between the two. Thanks
Red/Green
Posted 12/16/2011 19:11 (#2107196 - in reply to #2107163)
Subject: Re: JD Conservation planter vs. regular
Elizabethtown,KY
Conservation has a frame that is an inch or more bigger, and they have a cylinder on each wheel to raise the planter where the regular planter might just have one cylinder on the middle of the frame like a 7000. There are some other differences, I had a conservation 7200 that I bought new back in 1992, was a very good planter for me.
HRF
Posted 12/16/2011 19:26 (#2107229 - in reply to #2107196)
Eastern Iowa
I have the 1760 conservation planter, the frame is heavier, it has air bags for down pressure, the guides are heavier and have a ram on each side. If you're going to no-till, it's a must.
SD-455
Posted 12/16/2011 20:24 (#2107354 - in reply to #2107163)
Subject: RE: JD Conservation planter vs. regular
Northeast Indiana (Auburn)
The 7200 Conservation planter will have a 7"X7" mainframe instead of a 5"X7" and the fertilizer bar is 3"X3". The marker arms will have a cylinder on each and the sliding part of the marker arm will be solid steel instead of tube steel. And each wheel will have a lift cylinder.
