Search Forums | Classifieds (93) | Skins | Language
How much hp to pull 30' Great Plains Turbo Till?
Tractorman4840
Posted 11/20/2011 23:06 (#2060009)
Subject: How much hp to pull 30' Great Plains Turbo Till?
SE VA
Flat ground, clay and sandy loam soils. 8950 mfd is biggest tractor we have. Thanks for any info.
packerfan
Posted 11/20/2011 23:33 (#2060067 - in reply to #2060009)
Subject: RE: How much hp to pull 30' Great Plains Turbo Till?
Western illinois
just demoed a 24'. put it on a 7240 mfwd and couldn't pull it
like i wanted. 10th gear and not deep enough to cut stalks well.
i would say 300 hp for a 30' at least. they pull hard.
Tractorman4840
Posted 11/21/2011 00:02 (#2060105 - in reply to #2060067)
SE VA
Thats kinda what i figured. I just noticed that you can buy a 30ft used cheaper than a more narrow one. Thanks.
buenymayor
Posted 11/21/2011 00:09 (#2060112 - in reply to #2060009)
Subject: Re: How much hp to pull 30' Great Plains Turbo Till?
WC Franklin Co., In.
We sometimes rent a 12' TT. We've got it on a 160HP 2WD tractor. It' pulls it fine, but it knows it's back there. I'd say Bill is pretty close.... 300HP and 8 wheels pulling it.
Silver Shoes
Posted 11/21/2011 03:59 (#2060206 - in reply to #2060009)
Seneca Kansas 66538
We have pullled ours with a dt200A, and noticed a neighbor pulling one with a 9190 granted you cant pull it quite as fast as 350 hp but you can pull it.
Gunner
Posted 11/21/2011 06:59 (#2060244 - in reply to #2060009)
Modena, Wisconsin
General rule is 10 HP per foot here and then you need enough weight also. A 4020 turning 120 would not have the weight to pull a 12 footer unless dead level and it had duals and weights.
Edited by Gunner 11/21/2011 08:23
FarmerEric
Posted 11/21/2011 07:32 (#2060284 - in reply to #2060009)
Union Kentucky
An 18ft pulls our Deere 8235R really hard in the rolling hills, we thought that it would pull really easy but it turns out to take a lot of hp.
ahay68979
Posted 11/21/2011 08:29 (#2060375 - in reply to #2060284)
Saronville NE
Neighbor has a 30ft on a 8320R with front duals and say they wouldnt want any less tractor to pull it at the speed you are supposed to run em at 8+ mph. I ran a 22ft on a 8245R 2 yrs ago, it wasnt big enuff, was ok on flat, but any hills at all you were at 5.5 or less.
skicker
Posted 11/21/2011 09:02 (#2060430 - in reply to #2060009)
CNY
10 hp/ft sounds right. I can pull a 20'with a 7810 but it will churn on a grade unless conditions just right. No duals. Prefer to use 4960 w/ duals if it's available.
screamin9860974
Posted 11/21/2011 09:50 (#2060513 - in reply to #2060009)
CMS
Our 30 ft will make our 8320R's cry at 8mph, the 8360R will pull it as fast you want. It doesn't look like it would be a hard pull, but it is a load
Edited by screamin9860974 11/21/2011 10:40
andie
Posted 11/21/2011 09:53 (#2060514 - in reply to #2060513)
Buy the 30' and remove couple of outside shanks. Spare parts for later.
bharzman
Posted 11/21/2011 10:30 (#2060560 - in reply to #2060430)
North Central Kansas
the 10hp per foot would be more for the landalls and such
our 30 foot TT we were told around 8 per foot
have a 230 hp 846 Versi pulls easy!
Farms With CASE
Posted 11/21/2011 20:56 (#2061312 - in reply to #2060206)
North Liberty and South Bend, Indiana
Is that a CaseIH 9190?
poor loser
Posted 11/21/2011 21:21 (#2061389 - in reply to #2060514)
north central ky
the turbo till will pull harder than a landoll or a case 330. our neighbors had a 30 footer and they said it gutted their 305 magnum. they got a case 330 and said it pulls it good. we tried a 24 footer on our 8110 with a 30% chip and it wasn't enough power for the hills.
