Search Forums | Classifieds (27) | Skins | Language
John Deere or MacDon draper head?
SFO
Posted 11/11/2011 05:33 (#2044717)
Subject: John Deere or MacDon draper head?
Findlay, Ohio
Has anybody tried the new John Deere draper head that are running MacDon now? How did they compare? We are thinking of going draper next year and don't know if we trust Deere to having the bugs out of theirs. Would we be better off staying with a proven draper like MacDon?
DeereRunner
Posted 11/11/2011 08:07 (#2044854 - in reply to #2044717)
Subject: Re: John Deere or MacDon draper head?
I have seen both run and both seem like a pretty good head. The one thing I did like more about the Deere is it does have a lot more flex to it in bigger slopes. With it being split into two belt sections on each side it can really "dip" and get a lower cut on the beans. People also talk about the gap between the belt sections on the head causing beans to be lost. We ran a S660 and 635 FD for two days demoing it and I did not see any beans at all falling out of there. Just my opinion.
dmax08
Posted 11/11/2011 11:18 (#2045132 - in reply to #2044717)
Are you wanting a flexdraper? My dad looked at one and said he would rather have our FD70, which we have had no issues with it. And if Deere doesnt make somethin work to put the new drapers on the old machines, the only person thats gonna buy that header when your done with it is someone with a new S series, and the guys who buy those have the money to buy a new one.......I'd go look at one, from experience I can tell you that you wont be dissappointed in the MacDon.
sparky9860
Posted 11/11/2011 11:34 (#2045152 - in reply to #2045132)
Burnettsville, Indiana
They can be ran on 70 series combines.
seedcleaner
Posted 11/11/2011 13:07 (#2045227 - in reply to #2044717)
Mid-Missouri
Taken from thecombineforum.com...
Well, on the 640FD versus MacDon, if you really want to know... I'll setup the situation a little. No-till soybeans into 225 bu corn stalks. High yielding, narrow row, 210K plant population, irrigated soybeans that were tall, green stem, and lodged. Admittedly tough cutting and tough feeding conditions. Dealer response was "can we wait till these dry a little", but the beans themselves were 10% - already too dry. In the span of four days, I cut 102 acres. The combine was short on power, which I covered in a previous post; but the head was the killer. In those four days, I made it across the field exactly 6 times without having to stop to either: cut the stems off the reel from reel wrap, unplug the center feed belt, unplug the side drapers, back the feederhouse up because the feed drum wouldn't feed (this was public enemy #1), or replace sickle sections. I'm sure some are saying "it worked great for us", or "why in the world did you fight it that hard". I will admit, the no-till cornstalks were a brutal problem, and caused many of the other problems. The sickle and guard combination did not do a superb job cutting. The plants would want to push in front of the cutterbar. I know, I know, too low of HydraFlex pressure. If you ran the pressure high enough to where they wouldn't push, the flex quality wasn't very good. As a result, if you ran the reel low enough to get them to feed, the green stem soybeans almost created a haybale around the reel in one pass. If you ran the reel high enough so it wouldn't wrap, then the plants wouldn't feed onto the draper very well and would come in in clumps. The clumps would hit the feed drum, and the slip clutch would go off. Hit the reverser to back up the feed drum, a corn stalk butt would wedge between the cutter bar and the center draper and it would plug. I could go on and on. The side drapers would stall because a corn stalk butt would get wedged between the belt and the undercarriage. And, oh by the way, broke the sickle where the double knife overlaps... Meanwhile the MacDon's handled these same conditions without issue. On a 135 acre pivot, the two 9870/FD70 combos would get 120 acres while I limped along and hoped to get 15. I kept fighting the fight because I was convinced that Deere would not have released something this awful. I will admit that we were the local dealers first experience with the 640FD on soybeans, which is why we had it soooo long relative to other demos. On the last field, I did get to where I could run the head long enough to where we could test the combine (S680). The 9870s got 95 acres and I managed to about double my productivity to 30 acres - wooo-hooo. I do know of other local people who got along good with the head in non no-till, non lodged soybeans. Would love to have hooked up one of the MacDons to the 680 and see what I could do, but that wasn't going to happen. OK, everyone else who loved it can have at me, but that's my two cents.
The whole story here, with some comedy...
http://www.thecombineforum.com/forums/4-john-deere/30672-s670-demo-...
Local MacDon dealer told me a new deere 35 ft draper demo ran in the same field with another deere combine on a 35ft FD70. The FD followed the Deere on some terraces and picked up some beans left behind. Thats all I know.
x5farmer
Posted 11/11/2011 14:45 (#2045328 - in reply to #2045227)
SC MN
Have any of U looked at AGCO's flex draper --- I was told they are sold out for more than two years proiduction -- MacDon is running scared!!!
CaseFarmer
Posted 11/11/2011 15:51 (#2045387 - in reply to #2045328)
Flora IL
Now if someone knew where to find a agco dealer.. :)
Jacob Bolson
Posted 11/11/2011 19:17 (#2045587 - in reply to #2045387)
Iowa
CaseFarmer - 11/11/2011 15:51
Can they be purchased in Challenger colors from a CAT dealer?
CRJ
Posted 11/11/2011 19:37 (#2045628 - in reply to #2045328)
NEIN
I doubt that. I could have a new Agco tomorrow if I had wanted it and that is even with the required Bish adapter. There is huge difference btween a flex draper, ie Md70, and a flexable cutterbar draper ie. JD or the coming Fiat. One will do better on small dips and lateral running furrows and the other will do better following major changes in ground contours. For me it was the latter. And the flex draper looks like it will have far less maintance because there is no "floating" cutter bar. jmho
CaseFarmer
Posted 11/11/2011 20:04 (#2045679 - in reply to #2045628)
Flora IL
Ya ur riht on conditions... Honestly id be scared to buy any draper head thats only been out for a bit...macdon has a ton of experience if i was u and spending the money on a draper id go macdon for that reason alone..
nbfarms
Posted 11/12/2011 00:01 (#2046150 - in reply to #2044717)
the fd70's hold their value pretty good, id go with a macdon for now, in a couple years if john deere still looks like a good flexdraper and not 100% satisfied with it, trade for a john deere! imo
