Search Forums | Classifieds (28) | Skins | Language
hanging a wire on molboard plow
fordsrock
Posted 10/17/2011 11:40 (#2007693)
Subject: hanging a wire on molboard plow
Central Ohio
i have heard of people hanging 9 wire on each bottom some how to knock down tall weeds. does it work? how do you do it? does anyone have pictures? the plow is a white 588
headerpuncher
Posted 10/17/2011 12:08 (#2007719 - in reply to #2007693)
Subject: Re: hanging a wire on molboard plow
Ea. Washington
Plowed many an acre with a wire hanging off the plow beam of each bottom. Fasten it about 2-3 feet ahead of the curve in the plow beam and long enough to drag about 2 ft into the furrow at the RH side of the share. workes best to turn to the right and leave the plow in the ground or at least be turning to the right when you drop the plow. Turned a lot of acres of 6' sweet clover under with a set up like that , won't help much in short trash and is kind of a PITA but you can git it done.
JohnW
Posted 10/17/2011 12:25 (#2007741 - in reply to #2007693)
Subject: RE: hanging a wire on molboard plow
NW Washington
Here is a picture of a "weed hook" on a small mounted plow from years gone by which might be less of a hassle than dragging wires.
(Plow with weed hooks.jpg)
Attachments Plow with weed hooks.jpg (24KB - 249 downloads)
detroitdiesel
Posted 10/17/2011 12:31 (#2007748 - in reply to #2007693)
Chillicothe, Missouri
I do not have any experiance in plowing with the wire in tall trash, but I have discussed it with individuals before.
-I was told it was best to attach the wire to the rolling cutter mount, and then trail by the moldboard that the cutter is for.
-Also I believe that the wire would be best if trailing past the moldboard approx. 5 feet
-I was told that it was best to use heavy wire, approx 1/8" in diameter
Edit:
each moldboard would have a wire on it.
example: three bottom plow would have three wires, one for each molboard
Edited by detroitdiesel 10/17/2011 12:40
In plain view
Posted 10/17/2011 13:06 (#2007782 - in reply to #2007693)
I can remember plowing soybeans under with a number 9 wire attached to each coulter --this was in the sixties (man am I getting old). This had something to do with some sort of government program that Dad was enrolled in. This was with a three bottom pull type plow that had a trip rope--ah, for the good old days!!!
braidy
Posted 10/17/2011 17:15 (#2007922 - in reply to #2007782)
NW Minnesota
Yep we've tied 1/8" wire onto the beam between the bottoms and left it 6' or so long. Worked pretty good in 5'-6' sweet clover that got away from us one wet summer.
GregWCIL
Posted 10/17/2011 19:10 (#2008001 - in reply to #2007693)
Subject: Is there anything you guys don't know?
West Central Illinois
Not trying to steal the thread here, but I never cease to be impressed with the broad base knowledge shared here. Has anyone ever asked a question that someone didn't know the answer to?
Beefmn
Posted 10/17/2011 19:27 (#2008017 - in reply to #2008001)
Subject: RE: Is there anything you guys don't know?
Blue Earth, MN
Nope, you'll always get an answer. Might not be the one you were looking for and it might start a flame war, but you'll get an answer. :)
Skipper
Posted 10/17/2011 19:54 (#2008049 - in reply to #2007693)
Yep like others said. It will really tuck the tall stuff under.
Assuming you are in the process if you have trouble with grassy stuff "hairpinning" around the standard (is that the right word?) you can move the coulter in line with the land side of the moldboard rather than offset a little as they are usually set.
FlyLow
Posted 10/17/2011 20:37 (#2008134 - in reply to #2007748)
Subject: You've got it.
South Texas
  Yes, that's what my dad did for years in cornstalks and sometimes other trashy plowing.  I'd suggest a little longer, though, if it's really tall stuff you're trying to keep down.  And 1/8" is sure minimum.  Others suggest #8 or 9 and that sounds better to me.  He fastened the wires to each coulter, at the bearing area.  The technique is really effective.
Take care.  Stetts
Tim in WI
Posted 10/17/2011 20:53 (#2008182 - in reply to #2008017)
Embarrass WI
You'll probably get at least a couple answers, and one of them might even be right!
Posted 10/17/2011 21:22 (#2008241 - in reply to #2007748)
Yes, that's the way we did it. Each plow carried a roll of #9 wire on it for replacement. They'd wear off or sometimes the tail wheel would run over the rear-most wire  & tear it off. The wire would fasten fairly high on the rolling-coulter shank. One for each bottom. I think we used to cut the wires about 6' long.
RecreationalTillage
Posted 10/28/2026 15:57 (#11788097 - in reply to #2007693)
West Central MN
Learned something new today.  Having plowed a 1,000 plus acres a year for decades, never heard of a attaching wires to bury trash.  Found this from 1927 talking about wires and controlling corn borer of all things.
https://sanweb.lib.msu.edu/DMC/Ag.%20Ext.%202007-Chelsie/PDF/e55.pdf
To help bury cornstalks, our IH plows had steel trashboards and then somewhere around the late 1970s? switched them out for the new plastic version that soil didn't stick to as bad.
Edited by RecreationalTillage 10/28/2026 16:02
(IHtrashboard (full).png)
(IHplastictrashboard (full).png)
Attachments IHtrashboard (full).png (42KB - 3 downloads)
Attachments IHplastictrashboard (full).png (24KB - 4 downloads)
