. | After waiting nearly 10 months, I finally took delivery on a Kubota RTV 900 with utility valve. Dealer had never sold one with the valve, and in trying to push things along, the district rep told me he had never heard of a farmer buying one. I can see it coming in extremely handy for brushing fence lines and clearing overhead limbs. The package adds speedometer, hand throttle, above box air cleaner, and hydraulic valve assembly. I did some research before ordering, and though Kubota sells Stanley hydraulic attachments, they want a small fortune. So I checked out ebay and bought both a used hydraulic chain saw and pole saw for way less. I'm still waiting for a windshield and roof that were ordered with the machine. The 10 year old Gator 6x4 left in trade, good machine, but it was time for an upgrade. I am really impressed by how well built this machine is. Lacy, my little assistant in the picture absolutely adores going for rides.
Edited by bshannon 8/28/2011 17:45
(Front view.jpg)
(Trusted assistant.jpg)
(RTV 900 rear.jpg)
(Hydraulic valve.jpg)
(hydraulic controls.jpg)
(saw motor.jpg)
(saw control.jpg)
(Gator (600 x 400).jpg)
Attachments ----------------
Front view.jpg (67KB - 991 downloads)
Trusted assistant.jpg (90KB - 978 downloads)
RTV 900 rear.jpg (68KB - 1239 downloads)
Hydraulic valve.jpg (65KB - 1039 downloads)
hydraulic controls.jpg (55KB - 1101 downloads)
saw motor.jpg (59KB - 1037 downloads)
saw control.jpg (70KB - 1127 downloads)
Gator (600 x 400).jpg (78KB - 968 downloads)
![](:beatdeadhorse5:)
| Interesting, thanks for the post. Can the hydraulics be used while driving the UTV? Like running a spray pump? |
NW central IL | so you have to cut tree limbs withing a few feet of the utv? huh |
![](/profile/get-photo.asp?memberid=5055&type=profile&rnd=447)
| What is the flow and pressure of the pump? |
| Now it is ready to pull a rake huh |
![](/profile/get-photo.asp?memberid=4185&type=profile&rnd=768)
| How hard would that roll-guard be to remove? Just in case someone didn't want it?
. | The hydraulic flow and specs seem to be a secret, I can't find them in the manual, online or in brochure. The chainsaw manual specs show psi of 1,000-2,000, and optimum of flow of 5-8 gpm. I will probably add or replace the pole saw hoses and make them longer, but these were the hoses it came with. The handthrottle only works when parked, but hydraulics can be run while machine is in motion. The roll cage isn't designed to be removed. I think a sawzall is the only way to take it off;( |
Flora IL | Congrats we nought one of these the first year they came out.. I pulled our 974 macdon on its header trailer after it sat out all winter.... its got power...... |
| Great little machines..... I've done lots of work with mine.I pull a 150 gallon sprayer and spray 300 X 2 acres each year. mine is an early model. I believe the new ones have an updated transmission. mine lacks a little power....... won't spin the wheels....... other than that no complaints |
Southeast Florida | Could you farm 25 acres with it? |
![](/profile/get-photo.asp?memberid=63&type=profile&rnd=911) Ashland County OH | No. This will only handle 22.5 acres. :) |
northwest tennessee | Not very hard with the right blade in a sawz all. |
| its actually very easy, they come into the dealership without them installed, part of pre-delivery is rops install |
![](/profile/get-photo.asp?memberid=18145&type=profile&rnd=361) waupun wisconsin | why the need for auxilary hydrolic valve? why not use the one that dumps the bed? just curious. we to like ours but it could go faster is our only complaint. |
Union Kentucky | I hope that the HYD pump is better in those than our Kubota zero turn mowers. |
![](/profile/get-photo.asp?memberid=5341&type=profile&rnd=488) Pine Island mn | friend on mine bought one. cab- ac - radio with cd player. he really likes it. |
. | Extra hydraulic tank, and hd oil cooler are added for continuous use. Stock hydraulic set up isn't designed for extended running time |
| Really happy to find your post as I am in the process of researching the Kubota RTV900xt Utility Vehicle specifically for utilizing the additional Hydaulic Valves. Have you used both chain saws and are you happy with their performance? Any helpful information you can give me regarding this vehicle and the additional Hydraulic Port? I am planning on using these valves to one cut wood and the other a wood splitter.
