Search Forums | Classifieds (3) | Skins | Language
Bleeding brakes on a C-60 chevy
TD15
Posted 7/25/2011 23:55 (#1880075)
Subject: Bleeding brakes on a C-60 chevy
I am trying to bleed the brakes after replacing a couple of brake lines and there seems to be some air left in it. I started at the master cylinder, then the hydo-vac then all four corners. It still seems to have air in the system because it takes several pumps to get a hard pedal. Does anyone have any tips ?
Pofarmer
Posted 7/26/2011 00:08 (#1880095 - in reply to #1880075)
Subject: Re: Bleeding brakes on a C-60 chevy
Those are a booger to blead. A power bleeder really helps. You could try gravity bleeding it, but, i've never had much luck with that.
silverluv75
Posted 7/26/2011 00:09 (#1880096 - in reply to #1880075)
SE North Dakota
Make sure the brake shoes are set up properly there is a top and bottom adjusting star and just keep bleeding.
headerpuncher
Posted 7/26/2011 01:49 (#1880187 - in reply to #1880096)
Ea. Washington
Did you bleed BOTH bleeders on the Hydrovac? Top one first
Edited by headerpuncher 7/26/2011 01:49
dieselade
Posted 7/26/2011 05:26 (#1880225 - in reply to #1880075)
wc in
try leaving one bleeder valve opened at the back tires and go do other chores for awhile. i did that to an old chevy pu. in an hour i had a stream of brake fluid and no air.
OHKen
Posted 7/26/2011 06:46 (#1880245 - in reply to #1880075)
Ohio
You will have to use a power bleeder. If you don't have one , find a mechanic that does. Even with a power bleeder they can be a real pain.
TD15
Posted 7/26/2011 07:33 (#1880286 - in reply to #1880187)
I didn't see a second bleeder there. I will look again.
spr352
Posted 7/26/2011 08:06 (#1880332 - in reply to #1880245)
ECIL
I'll tell you what works. Get a Mityvac hand vacuum pump kit. Ask for it by name. You basically hook it to the bleeder fitting, pump up the pump, open valve, push down on brake peddle, and then close valve. Don't let the pump loose vacuum. It pulls air and brake fluid thru the system. The kit will include instructions. I see on there web site, Mityvac has several different kinds. I think mine is the silverline. This should work for you, it has for me, and as I said.....keep the vacuum pump, pumped up!
wilddog
Posted 7/26/2011 08:21 (#1880359 - in reply to #1880075)
The only way I have been able to bleed these things is with a pressure bleeder on top of the master cly, Wasted hours trying to bleed like a normal truck, pressure bleeder makes it quick and easy. I have a C-65 and the shop manual says a pressure bleeder has to be used.
Edited by wilddog 7/26/2011 08:24
lylefarm
Posted 7/26/2011 08:36 (#1880385 - in reply to #1880075)
East of Dowagiac Michigan
The truck needs to be running to bleed a hydra-vac system by pumping the petal and opening bleeders.
ccjersey
Posted 7/26/2011 15:56 (#1880823 - in reply to #1880075)
Faunsdale, AL
If you have to pump it a couple times and then get a hard pedal, I think your problem is the adjustment on the shoes. Take a couple of strokes from the master cylinder to push them out to the drums and then when you let off, the springs pull the shoes back in and there you go.......... two pumps to get a hard pedal again.
Never had a pressure bleeder here and have worked on several hydrovac brake trucks over the years. It can be done.
Had one old truck the brake hoses were completely plugged/swollen shut on. That caused some head scratching!
bobcan
Posted 7/26/2011 17:41 (#1880935 - in reply to #1880332)
SK.. in Frozen Cold Western Canada
Yup.. MityVac Silverline is a VERY useful tool, if you value YOUR time at all.. Best $70 spent once you've used one.. =-)
Website : http://www.mityvac.com/pages/products_hvpk.asp
Amazon : http://www.amazon.com/Mityvac-Mity-Vac-Mv8500/dp/B002B4LOC6/ref=dp_...
Edited by bobcan 7/26/2011 17:43
TD15
Posted 7/26/2011 19:59 (#1881089 - in reply to #1880075)
Subject: RE: Bleeding brakes on a C-60 chevy
Thanks for the replies. I'm pretty sure we have more problems than just air at this point. I think the brakes are going have to come apart and give it a brake job and free up the adjusters. I only wanted this truck to haul scrap so I think I'm going to post it for sale and go a different route.
mailman13
Posted 9/18/2022 22:25 (#9850576 - in reply to #1881089)
West Central Iowa
