Search Forums | Classifieds (67) | Skins | Language
Putting the C15 back together...need some help
IH-Harvester
Posted 3/17/2011 21:20 (#1675798)
Subject: Putting the C15 back together...need some help
I'm installing new liners in my C-15. Pinhole in #1 cylinder. Had a few questions. I didn't pay attention when we pulled the rods out. They are labeled with the cylinder numbers scratched into one side of the rod by the bolt. Does it matter which way they are installed? The guy helping me said the numbers usually go towards the oil cooler on a Detroit.
Also-
What are the torque specs for the
Headbolts
mains
rods
oil pump
Thanks
CATGUY
Posted 3/17/2011 21:28 (#1675814 - in reply to #1675798)
Subject: Serial number, please or at least the "prefix"
Iowa
This has more to do with the rod bolts(different styles)
CATGUY
Posted 3/17/2011 21:35 (#1675834 - in reply to #1675798)
Subject: cylinder head specs
Iowa
View Image
Illustration 1g01025099
The bolts that are marked "X" are 216 mm (8.5 inch) long. The lengths of the remaining bolts are 194 mm (7.6 inch) long.
Apply 6V-4876 Lubricant to the bolt threads and both sides of the washers. Tighten the bolts in the following step sequence:
  1. In a numerical sequence, tighten bolts 1 through 26.
    Torque for bolts ... 270 ± 15 N·m (200 ± 11 lb ft)
    Torque for bolts ... 450 ± 15 N·m (330 ± 11 lb ft)
  1. In a numerical sequence, again tighten bolts 1 through 26.
CATGUY
Posted 3/17/2011 21:38 (#1675846 - in reply to #1675798)
Subject: main bolt spec and spray jets spec
Iowa
Illustration 4g00635502
Front view
(8) Dimension from the centerline of the crankshaft bearing bore to the top of the cylinder block
New ... 425.45 ± 0.15 mm (16.750 ± 0.006 inch)
Minimum ... 425.02 mm (16.733 inch)
Note: The total flatness of the top contact surface of the cylinder block must be within 0.10 mm (0.004 inch). The flatness must also be within 0.05 mm (0.002 inch) for any 177.5 mm (6.99 inch) section of the surface.
(9) Bore in the cylinder block for the main bearings
(10) Main bearing cap
Main bearing cap width ... 215.900 ± 0.025 mm (8.5000 ± 0.0010 inch)
Width of the cylinder block for the main bearing cap ... 215.900 ± 0.013 mm (8.5000 ± 0.0005 inch)
(11) New dimension from the centerline of the crankshaft bearing bore to the bottom of the cylinder block pan rails ... 165.10 ± 0.10 mm (6.500 ± 0.004 inch)
(12) Main bearing cap bolts
View Image
Illustration 5g00562863
Torque-turn tightening method for main bearing cap bolts
Use the following procedure in order to tighten the main bearing cap bolts:
  1. Apply clean engine oil to the threads of the bolts.
  1. Tighten the bolts first on the bearing tab side (1) of the cap.
    Torque for bolts ... 260 ± 14 N·m (190 ± 10 lb ft)
  1. Tighten the bolts on the opposite side (2) .
  1. Put a mark on each bolt and each cap.
  1. Tighten the bolts on the opposite side (3) from the mark to angle (A) .
    Angle (A) ... 120 ± 5 degrees (2 flats)
  1. Tighten the bolts on the bearing tab side (4) of the cap from the mark to the following value.
View Image
Illustration 6g00285129
Right side view
(13) Pipe plug
Apply 5P-3413 Pipe Sealant on the threads of the pipe plugs before installation in the cylinder block.
(14) Piston cooling jet
To prevent damage to the piston cooling jets during service, the piston cooling jets must be removed.
Tighten the bolts that hold the piston cooling jets to the following torque. ... 40 ± 8 N·m (30 ± 6 lb ft)
Minimum permissible clearance between the piston, the piston cooling jet, and the crankshaft ... 0.63 mm (0.025 inch)
<form action="/sisweb/sisweb/common/image_viewer_page.jsp" accept-charset="UNKNOWN" enctype="application/x-www-form-urlencoded" method="get"> <form action="/sisweb/sisweb/common/image_viewer_page.jsp" accept-charset="UNKNOWN" enctype="application/x-www-form-urlencoded" method="get">
IH-Harvester
Posted 3/17/2011 21:39 (#1675848 - in reply to #1675798)
Subject: Re: Putting the C15 back together...need some help
I'm sorry I forgot that 6NZ11733
Thanks for the quick response CATGUY
IH-Harvester
Posted 3/17/2011 21:44 (#1675858 - in reply to #1675798)
Does it matter which way the rods go in.....?
CATGUY
Posted 3/17/2011 21:45 (#1675865 - in reply to #1675848)
Subject: C15 "6NZ" rod bolt spec
Iowa
Illustration 1g01431986
(A) Bore in connecting rod for the piston pin bearing ... 59.640 ± 0.013 mm (2.3480 ± 0.0005 inch)
Note: The connecting rod must be heated for the installation of the piston pin bearing. Do not use a torch.
(B) The connecting rod must be heated from 175 to 260 °C (347 to 468 °F) for the installation of the piston pin bearing. Maximum distance for heating the connecting rod ... 85.0 mm (3.35 inch)
(C) Diameter for the bearing of the piston pin ... 55.035 ± 0.008 mm (2.1667 ± 0.0003 inch)
Thoroughly lubricate the piston pin with clean engine oil prior to assembly of the piston and the connecting rod.
(1) The bearing joint must be within ± 5 degrees at either location.
(D) Distance between the centers of bearings ... 261.62 ± 0.05 mm (10.300 ± 0.002 inch)
(2) Etch the cylinder number on the connecting rod and the cap in this location. Mark the connecting rod and the cap with a number 1 through 6. Mark the numbers on the same side of the connecting rod as the bearing tab slots.
(3) Connecting rod bolts
Use the following procedure in order to tighten the connecting rod bolts.
    View Image
    Illustration 2g01431988
    Torque-turn tightening method for connecting rod cap bolts
  1. Lubricate the bolt threads and the seating faces of the caps with 4C-5593 Anti-Seize Compound .
  1. Tighten the connecting rod bolts.
    Torque for bolts ... 90 ± 8 N·m (65 ± 6 lb ft)
  1. Tighten each bolt from the mark to angle (A) .
    Angle (F) ... 90 ± 5 degrees (1/4 turn)
(E) Bore in the connecting rod for the bearing for the crankshaft connecting rod journal ... 96.200 ± 0.013 mm (3.7874 ± 0.0005 inch)
CATGUY
Posted 3/17/2011 21:52 (#1675887 - in reply to #1675858)
Iowa
If you have the connecting rods, with two dowel pins and holes(between cap and rod), THEN the dowels go to the front of the engine.
CATGUY
Posted 3/17/2011 22:02 (#1675915 - in reply to #1675798)
Subject: oil pump mounting bolt spec
Iowa
This is just std spec for 3/8" NC bolt = ( 35  +/-  7  ft lbs)
TxPope
Posted 3/17/2011 22:04 (#1675918 - in reply to #1675887)
Abilene, Texas
CatGuy, you are a real asset to this group. My thanks to you for being so willing to help others out.
IH-Harvester
Posted 3/17/2011 22:08 (#1675928 - in reply to #1675798)
Thank you CATGUY for being so fast.
I don't have the rods in front of me, but I can't remember a dowel on the rods or caps. I am 180 miles away from them right now.
CATGUY
Posted 3/17/2011 22:10 (#1675935 - in reply to #1675865)
Subject: RE: C15 "6NZ" rod bolt spec
Iowa
If you read #2, on this rod bolt spec page, it says the "rod numbers" SHOULD BE on the side with the bearing tabs(tangs) , IF that is correct, then the tangs/tabs/numbers should be on the oil cooler side.
The old 3406 engine "rule of thumb" was rod bearing tangs OPPOSITE the camshaft.
(oil cooler is opposite the cam, too)=== ( bearing tangs on oil cooler side)
CATGUY
Posted 3/17/2011 22:24 (#1675976 - in reply to #1675918)
Iowa
Thank goodness, for "Copy and Paste", otherwise I could see myself getting burned out, sometimes.
Gotta remember, I glean info from this board too.  John Deere stuff, planter stuff, crop stuff, precision stuff(just trying to learn more about precision ag)
