Search Forums | Classifieds (38) | Skins | Language
Problems with 750 touch screen and calibration
jbweston
Posted 2/16/2011 08:52 (#1617052)
Subject: Problems with 750 touch screen and calibration
Central Ohio
So I got a brand new 750. When I try to navigate the screens and push the buttons on the screen, it won't do anything, or sometimes the wrong thing. I have to push to one side or the other of the button to make it work, but never know which side.
When I go to calibrate the touch screen, it says you have tried multiple times and failed to successfully calibrate. tough.
Anyone else have the problem? Solutions?
tedbear
Posted 2/16/2011 09:39 (#1617143 - in reply to #1617052)
Subject: RE: Problems with 750 touch screen and calibration
I have done a bit of testing with my own personal 750 and a couple at the store. I have not seen the problem that you describe. Hopefully yours is an isolated case.
40DODGE
Posted 2/16/2011 09:57 (#1617180 - in reply to #1617052)
There is an issue with some of the 750 displays as you have described.  Contact your dealer, they should be able to get you fixed up.
jbweston
Posted 2/16/2011 15:32 (#1617549 - in reply to #1617180)
Central Ohio
What does this fixing up involve?
40DODGE
Posted 2/16/2011 16:28 (#1617598 - in reply to #1617549)
I believe they are replacing the touch screens in them, will most likely have to be sent off to Ag Express.  Have you tried the 3 button reset?
jbweston
Posted 2/16/2011 19:28 (#1617840 - in reply to #1617598)
Central Ohio
no, how do you do that?
JDBrian
Posted 2/16/2011 20:15 (#1617919 - in reply to #1617840)
Dietrich, Idaho and Mountain Home, Idaho
SOFT RESET:
1. Power down the display and then power it on.
2. Wait until the status bar at the bottom of the second startup screen is over half full.
3. Press the power button and top brightness control button at the same time.
4. Hold the buttons down until the display beeps.
HARD RESET:
3. Press the power button and both brightness control buttons at the same time.
jbweston
Posted 2/16/2011 22:10 (#1618218 - in reply to #1617919)
Central Ohio
Thanks.
jbweston
Posted 2/16/2011 22:34 (#1618285 - in reply to #1617919)
Subject: mine wont even do that!
Central Ohio
Something must be seriously wrong with it. When I depress all 3 buttons as directed, it just boots on up normally in another split second.
I hope my dealer returns my call soon.
FWI
Posted 2/17/2011 05:04 (#1618625 - in reply to #1618285)
Subject: RE: mine wont even do that!
Ireland
jbweston - 2/17/2011 02:34 Something must be seriously wrong with it. When I depress all 3 buttons as directed, it just boots on up normally in another split second. I hope my dealer returns my call soon.
 A couple of points easily missed, when calibrating in a hurry it is easy to not hit the one of the points in the centre and you will find yourself starting over!
When doing a reset it is when the second progress bar is over half across that you press the buttons.
jbweston
Posted 2/17/2011 08:34 (#1618806 - in reply to #1618625)
Central Ohio
Thanks, but I have made sure I do both of those things, many times.
40DODGE
Posted 2/17/2011 09:34 (#1618932 - in reply to #1618806)
Subject: RE:You have e-mail...
I sent a step by step instruction sheet on how to do the reset....with pictures!!
Haywardmarl
Posted 2/17/2011 19:03 (#1619910 - in reply to #1617052)
I have a Case IH FM-750 same as a Trimble CFX 750. Mine has the same problem and it drives me crazy. I have not tried to re-calibrate it. Misery loves Company correct ??? Also no remote map switching yet. How Trimble could ommit that is sad. The claim they will fix that in the February oppss March oppsss when every they get around to it software upgrades.
7150
Posted 12/8/2020 00:20 (#8653591 - in reply to #1617052)
FM750 touchscreen 1
Edited by 7150 12/30/2020 21:36
GFarms88
Posted 1/5/2022 22:38 (#9421799 - in reply to #1617052)
I provide replacement touchscreens for broken or unresponsive to finger touch. These are brand new genuine oem replacement touchscreens for a Trimble 750 FM CFX Display. If you do not feel comfortable to perform the repair after reviewing my tutorial, I can perform the install for you. Turnaround time is roughly 1 week. Just pay shipping both ways.
I also supply other replacement touch screens for various other models such as the Trimble FMD, Ag leader Insight, Versa, Kinze Vision. The ad for these screens are listed here: Insight, FMD, Kinze Vision
I will provide some installation guidance below if needed.
Install time takes 20-35 minutes. (Depends how quick you can turn out torx screws)
Touch screen calibration is required after booting up the display in the settings menu.
Be sure that the display is at room temperature before doing the installation.
**Paypal account is required for sending payment**
Discounts are given with multiple quantity orders.
*#*Instructions*#*
T15 Torx bit
Phillip Screw driver
Flat Plade screw drivers
Take your flat blade screw driver and remove the rubber side guards as depicted. They pop right off with a little force. You will notice a torx screw is hidden underneath these rubber guards which needs to be removed.
Use torx T15 to remove all screws from the back
Remove this connector to to allow separation from the back enclosure.
1. Disconnect this ribbon cable circled in pink. This is the touch panel's ribbon cable
2. Remove all torx screws circled in yellow
3. Now lift the assembly away from the front bezel
4. Clean and wipe any dust and debris build up from the front bezel
5. Pry the defective touch panel evenly away from the LCD screen. Pry with gentle force. Take your time. Eventually the panel will peel and pop right off.
1. Lay the new touch panel onto the front bezel in the correct orientation so that the ribbon connector and be installed. Try to lay the touch panel onto the front bezel as square as possible.
2. Lay the LCD assembly on top of the touch panel while also keeping the torx screw holes lined up.
3. Evenly tighten torx screws in a criss-cross fashion. Do not over tighten!
4. Reconnect the Ribbon cable for the touch screen panel circled in pink from image above
5. Reconnect the Cable circled in yellow from image above
6. lay the back enclosure on top and fasten the remaining torx screws and press the side rubber guards in place.
7. Power on device and go into the calibration settings.
There is a short cut to get to the screen calibration by pressing and holding the power button and to top brightness button during the boot-up loading screen during the second loading progress bar once it reaches just passed 50%. This is considered a "Soft Reset"
Soft/Hard Reset
If you can't get the short cut to work, getting to the calibration menu can be a little tricky since the new touch screen won't be calibrated. You may have to press "blindly" around the screen until the touch screen can find the button you wish to press. Example: You may have to press an inch away to the left or right, above or below of the button you wish to press. You may want to use something more precise such as the end of a pencil eraser or a stylus pen during calibration. Once calibration is complete. It should be good as new.
This is my technique of replacing the touch screen. These instructions are here to help you build confidence in doing this task. However, I am not liable or responsible for the success of the installation.
A unique symptom of a faulty touchscreen is also when you initially bootup the display and you reach a screen "Finalizing firmware upgrade" "Please wait while the display finalizes the firmware upgrade. This process may take a few minutes." You then get to the point where your finger presses are also not recognized. The touchscreen has "shorted out" and caused a problem with the bootup sequence. A new touchscreen will also fix this problem.
Keywords: Trimble, cfx750, 750 CFX, 750-CFX, 750-FM, FM, FMX, FM1000, touchscreen, touch screen, digitizer, brand new trimble agriculture FM750, OEM, finalizing firmware upgrade, hourglass,
Email:[email protected]
Ph. (320)981-0405
To make a purchase visit My AgTalk Classifieds page
Edited by GFarms88 1/6/2022 11:01
