AgTalk Home | ||
Forums List -> Crop Talk | Message format |
Jon S![]() |
This was posted last year by Hay Wilson in TX. In light of the recent energetic discussions about liming soils I thought it might be prudent to resurrect this article: | |||
cotncrzy![]() |
PROSPECT, TENNESSEE | Lots of people will use the pellet ed lime with their nitrogen to reduce the lowering of the soils PH value. I know of some that hasn't used AG lime in 6 or 8 years PH still good. I have been running some numbers, almost makes since. | ||
bigmoe![]() |
ecmn | So mixing some pel lime in with my starter for corn 2x2 isn't doing me any good then. Is there any good uses for pel lime? Maybe a couple hundred pounds to get a crop through a year or two while the ag lime is being incorporated?? | ||
soil-life![]() |
North Central Ohio, across the Corn belt ! | bigmoe - 1/12/2011 09:55 So mixing some pel lime in with my starter for corn 2x2 isn't doing me any good then. Is there any good uses for pel lime? Maybe a couple hundred pounds to get a crop through a year or two while the ag lime is being incorporated?? Your Fine ground Ag lime should be available to an extent as soon as it is applied and comes in contact with the soil, or soon after. and continues to slowley release for years to come. soil Moisture soil temperature soil biological activity will determin the time and effect of any applied Nutrient. even Pell lime | ||
bigmoe![]() |
ecmn | So what it comes down to is your better off spending the money on ag lime instead of limping along with pel lime. Ag lime is $20-22/ ton applied and pel lime is $200/ ton applied. | ||
soil-life![]() |
North Central Ohio, across the Corn belt ! | bigmoe - 1/12/2011 10:18 So what it comes down to is your better off spending the money on ag lime instead of limping along with pel lime. Ag lime is $20-22/ ton applied and pel lime is $200/ ton applied. That is My Oppinion Now if I were the manager of the Local co-op ? I could make the argument the other way also. But for YOUR best interest as a Farmer. Your end results, Profit Get the proper Bulk Lime on and be done with it. | ||
Nichols![]() |
You answered your own question with those numbers. IMO. | |||
martin![]() |
I would "third" that opinion. I have read some of these posts on Pell Lime, and I come down on the side on Jon S. The only value that pell lime provides is the ease of spreading, since it is a pelleted form. However, when you look at the economics, the proper ag lime is a better value, even on rented acres. | |||
Briarpatch![]() |
S MN | Used aglime for the first time last fall. Here it's about $50 ton plus application. Could live with that if we didn't have a constant 20-25 MPH wind when coop is putting it on with a spreader. Doesn't do much good when it's blowing past the spreader and not hitting the ground. I'm a bit skeptical, but new to this liming issue also. (Grid sampled fields 2.5 acre grids range 5.6-8.0 PH) At least pell lime hits the ground, even if a bit windy when coop pulls onto your farm | ||
soil-life![]() |
North Central Ohio, across the Corn belt ! | Briarpatch - 1/12/2011 12:16 Used aglime for the first time last fall. Here it's about $50 ton plus application. Could live with that if we didn't have a constant 20-25 MPH wind when coop is putting it on with a spreader. Doesn't do much good when it's blowing past the spreader and not hitting the ground. I'm a bit skeptical, but new to this liming issue also. (Grid sampled fields 2.5 acre grids range 5.6-8.0 PH) At least pell lime hits the ground, even if a bit windy when coop pulls onto your farm Sounds Like You need to have a visit with your applicator Managing How and when any nutrient is applied is a Big part of the farmers Managment Job | ||
Briarpatch![]() |
S MN | Agreed soil life- told them to move on down the road to somebody else's farm when only half done. They obliged and no good will was damaged (I hope). My point is, if you are located in an area where the wind always blows it can be very difficult to get the ag lime applied correctly. Very few days under 15 mph. Luck of the draw really. A guy hates to be overly fussy, generally you can't predict when a nice calm day will come along. Just saying "here" it can be kind of tricky. | ||
soil-life![]() |
North Central Ohio, across the Corn belt ! | Briarpatch - 1/12/2011 13:24 Agreed soil life- told them to move on down the road to somebody else's farm when only half done. They obliged and no good will was damaged (I hope). My point is, if you are located in an area where the wind always blows it can be very difficult to get the ag lime applied correctly. Very few days under 15 mph. Luck of the draw really. A guy hates to be overly fussy, generally you can't predict when a nice calm day will come along. Just saying "here" it can be kind of tricky. understand well. some of My clients spread at night. just for that reason. I think they Like the quiet solitude also ??? Hehehe | ||
martin![]() |
depending on the size of your operation, there is where it might pay to own your own spreader*... and then you can afford to be fussy.
*- or maybe own one with a couple of neighbors that you can share it with. OR own one, and rent it out when you are not using it..... | |||
steiner43511![]() |
Northern Ohio Grain | I picked up a few fields for 2011 that had been religously applied with pellet lime over the past decade. Soil samples showed low 4's to low 5's on the pH. I hate to think how much money was spent on pellet lime over those years, and how much better a few tons of ag lime would have been. | ||
soil-life![]() |
North Central Ohio, across the Corn belt ! | steiner43511 - 1/12/2011 17:12 I picked up a few fields for 2011 that had been religously applied with pellet lime over the past decade. Soil samples showed low 4's to low 5's on the pH. I hate to think how much money was spent on pellet lime over those years, and how much better a few tons of ag lime would have been. well steiner, You can guess who, said, Go ahead, Just add a few Hundred Pounds to each acre and You will be fine ??
(Delete cookies) | |
