Search Forums | Classifieds (37) | Skins | Language
Best performing manure spreader?
granto
Posted 12/30/2010 23:02 (#1516663)
Subject: Best performing manure spreader?
18c ditch system, winthrop Mn
We had a deere 450 hydro-push that worked well for years, other than the fact that it dumped manure in piles. Before that we had a few deere 34 that did a better job of spreading but had the chain issues.
ilikemysteak
Posted 12/30/2010 23:06 (#1516674 - in reply to #1516663)
Subject: Re: Best performing manure spreader?
Baden, Ontario
Hagedorn 245. Spreads beautiful. Built very heavy. Replaced a few bearings and that is all. Probably will break down next week!
granto
Posted 12/30/2010 23:17 (#1516702 - in reply to #1516674)
where is that spreader made, wow it is really big!
bullhauler
Posted 12/30/2010 23:32 (#1516720 - in reply to #1516674)
Denhoff,ND right in the center of the State
We run a 3550 Myers, been a real good spreader, it is 550 bushel and spreads real nice, takes at least 150hp minimum tractor, not hp just a good heavy tractor to pull it, if there is snow or ice it wants to push the tractor around.
Kooiker
Posted 12/31/2010 01:04 (#1516842 - in reply to #1516663)
I used a Kuhn 600 bu? vertical beater spreader this fall.
Awesome job of spreading. Takes a good sized tractor, weight and HP.
I had it behind a 2-155 White with weights on the front and duals on the back. I wouldn't have wanted a smaller tractor or a bigger spreader.
If I had a lot of manure to spread I'd have a vertical beater spreader of one brand or another.
briggsfm
Posted 12/31/2010 05:40 (#1516930 - in reply to #1516663)
Subject: Hagedorn
Scottville, 49454 Northwest Michigan
Forty-plus years of manure spreading, the Hagedorn hydra-push spreader was the best for us. We now use an Artex spreader. It holds about three times what the largest Hagedorn would hold at the time we bought the Artex. The Artex box has been good to us. The undercarriage, not so much. As I understand it, Artex is now building their own undercarriages. I suspect that's probably a good thing.
Good luck with your decision, gordon
Edited by briggsfm 12/31/2010 05:40
4960
Posted 12/31/2010 06:21 (#1516940 - in reply to #1516663)
wi
Hagedorn 277
tonesaguy
Posted 12/31/2010 07:09 (#1516958 - in reply to #1516930)
Chilliwack, British Columbia
Gordon,
I can't remember, did you get your box made in Canada, or was it an early American version? Apparently the American company uses cheaper steel in the undercarriage (on the smaller boxes anyway) and guys here are having trouble with them.
As for the original question, I think the Hagedoorn is also a good spreader. We bought a Leon, very similar to the Hagedoorn, but seems to be built a big cheaper. lighter steel, less hardware where there should be more. Does a decent job, but I would prefer vertical beaters or spinners.
Glenn
rctesch
Posted 12/31/2010 07:46 (#1516994 - in reply to #1516663)
Subject: RE: Best performing manure spreader?
South Central MN
We have had a Kuhn/Knight Hydrapush 2054 Verti-Spread for a few years now. Pull it with an IH 5488 MFD. You do know it is back there. Excellent spread pattern. Once the cylinder has compressed the manure in the spreader it is a constant spread all the way until empty. No piles. It sure beats dealing with apron issues. We are just east of you granto, by Henderson.
ilikemysteak
Posted 12/31/2010 07:55 (#1517000 - in reply to #1516702)
Baden, Ontario
Oops, I said 245, I meant 225. Not a huge spreader but a nice size for our beef feedlot. You can really heap them with pen pack. These spreaders are made in Paisley, Ontario. Their Dealer Network is not huge but their spreaders are very popular here. Have a friend in Wisconsin who came up and hauled his own down about 2 or 3 years ago. Saved alot of money because of the dollar, not sure if the savings would be as good now. I can try and get you a Phone # if you need.
agboy
Posted 12/31/2010 09:08 (#1517100 - in reply to #1516663)
Flandreau, SD
No Questions, hands down.
(IMG_3371.jpg)
Attachments IMG_3371.jpg (54KB - 1088 downloads)
RickB
Posted 12/31/2010 09:28 (#1517131 - in reply to #1516663)
Lincoln County. NC
If all your box spreader experience was with Deere, you never had a decent one, let alone a good one. The only spreaders worse than Deere were IH.
sprayerguy
Posted 12/31/2010 10:36 (#1517263 - in reply to #1516663)
Fullarton Ontario
Check out Bunning. They well spread dry litter or remove the rear doors to spread muck. http://www.gtbunning.co.uk/widebody.htm
ge jr
Posted 12/31/2010 10:42 (#1517275 - in reply to #1517100)
algona iowa
I second that.
easymoney
Posted 12/31/2010 10:45 (#1517287 - in reply to #1516663)
ecmn
hagadorn has treated us unbeleivably well for pen pack or sloppy manure. if a box spreader is what your looking at i couldnt say enough good about it. rent a knight chain to spread fly ash or lime. the hagadorn wont push that stuff out. but the chain spreader reminds me of how nice the hagadorn is!!
2+2, MN
Posted 12/31/2010 11:58 (#1517426 - in reply to #1517000)
New Ulm, MN
Miller Sellner in SE sells them. Ill post a vid from work later when im in the house. Theres is a early one with the numbet welded on the hitch.
2+2, MN
Posted 12/31/2010 13:29 (#1517594 - in reply to #1516663)
Subject: RE: Hagedron video for Granto
New Ulm, MN
http://www.youtube.com/watch?v=a0Zon26CR68
spreading at work with the 8970 last march. theve owned the spreader for over 10 years, bought it from paynesville MN when i worked at another farm over 8 years ago they wanted a new spreader, Feed mixer guy suggesting calling these guys couse he was impressed with the spreader. They bought one. there we hauled semi liquid outs the tie stall ( barn cleaner into a manure augar with finely chooped straw bedding) to penpack with cemnet chunks ( guy was cleaning in winter and seems old cement was froze to manure but busted up cracked ect) Worked well, also at Del MOnte they got 2 with verticle beaters, been cleaning out the ponds so they been spreading Sloppy mud with them. Miller Sellner been selling them for the pst 8 years at least.
Edited by 2+2, MN 12/31/2010 13:32
(163489_10150116874353974_566743973_7667782_7390852_n.jpg)
Attachments 163489_10150116874353974_566743973_7667782_7390852_n.jpg (70KB - 1162 downloads)
kylosabe
Posted 12/31/2010 16:32 (#1517863 - in reply to #1516663)
NCNE, OM ~ 1.5, CEC ~ 9.0
After reading every manure spreader thread on AgTalk and speaking with the major commercial spreader in our area, I purchased a used SpreadAll spreader which is manufactured by West Point Manufacturing in West Point, NE.  Basically, I can't imagine anyone being harder on their equipment than these commercial guys and while they are always fixing leaf springs and attending to their trucks, they seldom have issues with the spreaders and we've always been satisfied with the performance.
Since my only experience is with this machine, I can't compare and contrast to others but I've been happy so far.
(JD 8300 and Spreader - sm.JPG)
Attachments JD 8300 and Spreader - sm.JPG (38KB - 1001 downloads)
dykstra
Posted 12/31/2010 16:57 (#1517905 - in reply to #1517863)
SW MI
I vote for the meyer V-max spreaders we haul turkey and dairy with it and average about 3 loads per day with for 7 years now original chains and replaced one bearing good spreader.
briggsfm
Posted 1/1/2011 07:09 (#1518673 - in reply to #1516958)
Hi Glenn,
After Artex was sold, (brain fart, can't remember who bought them) the new company had a hard time figuring out what undercarriage we have on our Artex. They've concluded it is an undercarriage made in Italy. I guess towards the end of Artex's "days", they were getting undercarriages from a few different sources. Which is something I wouldn't think is very good to efficiently manage. Oh well.
You mentioned beaters. We have a vertical beater currently on our Artex. But initially we had their horizontal beater until the vertical was built. The vertical can bust up whatever product we put in the spreader better than the horizontal. I think the vertical beater will have less maintenance cost relative to the horizontal. However, the horizontal gave us a much better spread pattern with our sawdust manure. Since sawdust manure is ninety-five percent of what we handle, if I had it over to do again, I think I would have purchased the horizontal beater. The horizontal was less cost than the vertical too. Oh well.
take care Glenn, hope you have a great 2011, gordon
tonesaguy
Posted 1/1/2011 07:18 (#1518679 - in reply to #1518673)
Thanks for the reply Gordon.
I think you are the first guy I have heard who mentions that he would rather have the horizontal beaters! But if that is what works better...
From watching our neighbours, I do know not to use the beaters to pull the spreader out of the mud, they now have spinners!
Happy New Year to you as welll! Stay warm!
GLenn
plowboy
Posted 1/1/2011 13:03 (#1519351 - in reply to #1517275)
Brazilton KS
I don't see how anything could compare with the job a Tebbe will do.
Now cost....well, that's another story!
