Good and bad of Black Machine
Bristol Hillbilly
Posted 12/11/2010 16:42 (#1480411)
Subject: Good and bad of Black Machine
Palestine, IL 62451
Looking at 6-13 Black Machine with flat fold markers and middle flex with Kinze units. What is the good and bad of these planters? Looks extremely well built.
Thanks Steve
Brassring
Posted 12/11/2010 17:43 (#1480498 - in reply to #1480411)
Subject: Re: Good and bad of Black Machine
St.Clair Co. IL.
we have one use it mostly for 15" beans, work ok for us, it's kind of a pain to load and work one with the units behind each other like they are but plants good, now ya know the flex frame does not work when it's folded in for narrow rows right? all and all it works for us and not a lot of money invested. bad; like all 7000 type planters, closing wheel, press wheel, and gauge wheels like to eat bearings but thats nothing new to anyone that has or had one. Bob
Brassring
Posted 12/11/2010 17:45 (#1480501 - in reply to #1480411)
St.Clair Co. IL.
forgot, you do mean 12/13 right? 12 row 30" corn and 13 15" bean.
BLTFARMS
Posted 12/11/2010 18:22 (#1480550 - in reply to #1480501)
Elizabethtown, ky
TOO WIDE. they are 17.5 feet wide. we had one, the roads we travel are busy 2 lane roads, for an area where the roads are not an issue they are great. folding is simple, markers are stronger than the markers on our 16 row, never had any problems out of it, ours was a 12/13 with white units. the flex only works with 30 inch rows, not on the 15 inch row mode. we pulled our machine with a 2wd 4250 john deere for 2 years, no trouble.
pointrow
Posted 12/11/2010 18:49 (#1480582 - in reply to #1480411)
Central Il Morton
They have their place. Mine allowed me to have one piece of equipment instead of 2 but that means planting one crop at a time.
Frame is built heavy but kind of crude. Filling boxes when folded can be a challenge as was stated before.
Changing from 30" to 15" setup takes some time and is hard to do alone.
Having to get off the tractor to fold and unfold can be a problem for some.
good luck
pointrow
nitram
Posted 12/11/2010 19:02 (#1480601 - in reply to #1480411)
wc mo
Wheel bearings are too small for the weight of the machine
redfarmer72
Posted 12/11/2010 19:08 (#1480612 - in reply to #1480411)
Subject: RE: Good and bad of Black Machine
Southern IL.
I have a Black Machine with Flex frame, flat fold markers, and contact drive wheels. This planter has a population monitor it also has Case IH row units and cyclo box central fill. Great bean planter. Will no-till unbelievably without coulters. If interested let me know.
Edited by redfarmer72 12/11/2010 19:10
CW IL
Posted 12/11/2010 20:54 (#1480782 - in reply to #1480411)
Effingham, IL
Very good planters, but going from a 30' swath in corn to 16.25' in beans is harsh. Mine turned blue and says Kinze on the side. As stated above takes some time to change from corn to beans and transport width at 17.5' are negatives, but they are getting cheap. Lots of planter for the money and will plant as good as a new one if kept in condition! Craig
Illini Fan
Posted 12/11/2010 21:52 (#1480883 - in reply to #1480411)
Greene County, Illinois
Frame is weak in the middle. Several that I know of have broken in the middle. Of course they don't break in the winter when you can repair them, they break right in the middle of planting season. There aren't any around here anymore.
Bristol Hillbilly
Posted 12/11/2010 23:14 (#1481040 - in reply to #1480411)
Palestine, IL 62451
Thanks for all the feedback. Yes I misstated it is a 12-13. I would continue to drill my beans but it extra help presented itself I could plant beans with both. CW IL did you mean it is harsh because going down to such a small swath? Illini where about is the frame weak? Compared to my late 70's 7000 series JD this thing looks like it could withstand about anything. Redfarmer my email is in my profile.
Edited by Bristol Hillbilly 12/11/2010 23:15
r75
Posted 12/12/2010 00:27 (#1481124 - in reply to #1481040)
I have one for sale in se mn. It is a white with liquid fert and Dawn whipper/coulter combo. 507-298-0150
barren
Posted 12/12/2010 08:26 (#1481277 - in reply to #1480612)
Glasgow, Ky
Might be interested in your Black Machine with the IH units.  Please email me if you are interested in selling it and we can discuss. My email is [email protected].
Edited by howmuchisenough 12/13/2010 05:59
rednick
Posted 12/12/2010 14:02 (#1481790 - in reply to #1481124)
west of DSM, Iowa
Somethings you just have to watch: bearings in the seed transmission, have an extra contact tire and tubes on hand, keep wheel bearings adjusted and greased, good markers but watch for broken welds and cracks, mines leaking hydrolic oil out of valve box but can't find leak. Once in awhile it doesn't lift evenly across the bar. Mine also settles on the right side. It's not super convenent but it works for my 700 acres. My biggest complaint is the negative tongue weight when raised and folded for beans. I run a dualed 2wd and get stuck once in awhile. If it's been cared for and you are willing to love it, go for it.
pointrow
Posted 12/12/2010 17:14 (#1482107 - in reply to #1481277)
Subject: Redneck
Central Il Morton
I never had transmission tire problems until the last couple of years. Seems no one makes good quality tires any more. Some just leak out the side walls. Have you found something that works?
thanks
pointrow
