Search Forums | Classifieds (9) | Skins | Language
Front boom or Rear boom self propelled sprayers
averagejoe
Posted 12/8/2010 13:00 (#1474690)
Subject: Front boom or Rear boom self propelled sprayers
Minnesota
I know there are pros and cons to each. Has anyone bought a front boom sprayer and have you been disappointed with it. I have hesitations about a front boom machine, chemical on the windows, stairs, and rest of machine. Turning around corners being different? Road visibility?
Any input?
sprayertech
Posted 12/8/2010 13:04 (#1474696 - in reply to #1474690)
Subject: Re: Front boom or Rear boom self propelled sprayers
Belwood, Ontario
like you say what ever you spray is on your whole machine, boom visibility in field is great
averagejoe
Posted 12/8/2010 13:30 (#1474721 - in reply to #1474690)
Minnesota
I have heard very good things about the case spx sprayers. Have all models been good? Row crop visibility is a concern of mine to drive between 22" rows, is there a trick to doing this without being able to see your front tires?
sprayertech
Posted 12/8/2010 13:48 (#1474744 - in reply to #1474721)
Belwood, Ontario
Friend of mine runs spx's but on 30' rows, they jus put the hood emblem over there centre row and go.
Also staring to see some people driving across the rows insted of trying to follow them
Rhino
Posted 12/8/2010 14:14 (#1474767 - in reply to #1474690)
Subject: RE: Front boom or Rear boom self propelled sprayers
Central Iowa
I was dead set on a front boom but for some reason I bought a 4920 with a 120ft booms and wouldent even consider a front boom today
P. Huffman
Posted 12/8/2010 14:21 (#1474778 - in reply to #1474690)
SW OH
We have run front booms since 1994 and would not consider anything else. visability is second to none, you can see your tips, control boom height better, and you can pull into corners, back out and on your way again. I don't understand how guys get material all over their machine, we may get some on the wheels, but very very seldom do we get any on the machine, but we don't spray in 20 mph winds either.
IN Grain Farmer
Posted 12/8/2010 14:29 (#1474789 - in reply to #1474778)
SE Wisconsin
The only thing we have seen around us is what I call "Hagie Tracks" or trails of weeds in the wheel tracks. Of course there are pros and cons for each. I think the major thing for us is the service we get more than anything. All sprayers will do the job, but if you break down, how fast you are back up and running can make a big difference.
agboy
Posted 12/8/2010 14:38 (#1474797 - in reply to #1474778)
Flandreau, SD
exactly what you said.
Only thing I can think of is if they are running the boom too high.
Edited by agboy 12/8/2010 14:47
(IMAGE_243.jpg)
(IMAGE_244.jpg)
Attachments IMAGE_243.jpg (99KB - 762 downloads)
Attachments IMAGE_244.jpg (79KB - 700 downloads)
agboy
Posted 12/8/2010 14:39 (#1474798 - in reply to #1474789)
Flandreau, SD
we can still have wheel tracks, but I would say for sure it is alot less than when we had rear booms.
Buster 50
Posted 12/8/2010 14:41 (#1474801 - in reply to #1474789)
North West IA/western AZ
My Hagie (and all that I looked at while in the market) has spray tips behind the rear wheels. The only time I've gotten spray on the upper structure was when I accidently turned a boom on while it was folded. Spraying tall corn might get spray on the machine but then you can't spray tall corn with the rear boom sprayers, can you. Road visibility is the only drawback with my front boom.
Ed Snyder
Posted 12/8/2010 15:47 (#1474849 - in reply to #1474690)
Mount Joy, PA
I didn't read the other replies, I owned & operated a Miller Nitro 220Ht with a front mount boom. There were more things I did not like about it than liked. It was hard to keep the liquid fert & chemical off the rest of the sprayer. It was much nicer for sidedressing corn with drop tubes
Boulevard
Posted 12/8/2010 17:00 (#1474908 - in reply to #1474690)
Southern Alberta
For those dead set against the front boom, who have experience only with the rear boom sprayers, I wonder...how many of you would lick the door handle of your Deere, Patriot, or Gator?
The benefits of front boom are huge. Never having to look back. Being able to see every nozzle, and see if you've got one that's plugged. Steering the boom around obstacles is so much easier when its out front. Just from the ease of use for an operator, the front boom sprayers like the Nitro makes so much sense to me.
Most people who talk negative about the front boom do so based not on fact, but perception and misinformation. The majority of chemical contamination that gets in any cab, front or rear boom, comes in on the operator himself.
Curt Keiser
Posted 12/8/2010 17:11 (#1474918 - in reply to #1474696)
Beresford SD
If you are getting spray all over your sprayer you are running the booms to high, wrong tips, higher pressure than needed.
Newguy
Posted 12/8/2010 17:21 (#1474928 - in reply to #1474690)
WC MN
Booms on Hagies or Nitro's when spraying are now about 4 feet below the cab.    Of course a front mount will get more chem on the sprayer itself.......
4 minutes with a fire hose tipped 2" hose on the water tender at the end of the day will do more than a rear mount not cleaned once every week.
Stairs folds up, windows are too high, rest of machine depends on height of crop.
Turning around is different, you better be lined up straight when you enter the row.   Corners are better on front mounts (unless your like Chad and use your guidance to back into them)...... Again, no head turning, eyes squinting, brain wondering. (me liky)
Front mounts not for everyone, rear mount or trailer sprayer is not for me.  Hagie has more power to weight because its lighter than the competition.
Hagie 2100  from years 1999 to 2002.
Front mount boom on Cat mt735 from 03 to 10  (Tractor still looks good after 3000 hrs, though not as good as the year older 765 that never sprayed)
Patriot XL from 07 to 10
STS 12 is comming in March.
NoPointRow
Posted 12/8/2010 17:38 (#1474950 - in reply to #1474690)
Central Illinois
Love my Hagie and front boom.... Never had "Hagie Tracks"..... and a quick wash with a pressure washer at the end of the day takes care of the minimal amount of chemical on the machine.....
CaseFarmer
Posted 12/8/2010 18:08 (#1474992 - in reply to #1474744)
Flora IL
driving on 30's is fine...not sure how you would do 22's.... u wouldn't be stareing down your other sprayers machines all the time to see if you were on track..u would have to have something to focus on im guessing..
CaseFarmer
Posted 12/8/2010 18:11 (#1474997 - in reply to #1474908)
Flora IL
the only thing ive noticed on front boom is the motor compartment covered in chemcial.... the dealer with it like the machine tho... haven't had many issues..
Newguy
Posted 12/8/2010 18:32 (#1475028 - in reply to #1474992)
WC MN
Many thousands of acres in this part of the world are sprayed with big new SPX machines in 22" rows........  They do a good job..... Most are dualed up all around.
EastIowaMatt
Posted 12/8/2010 18:53 (#1475066 - in reply to #1474908)
I've sat in them, and I've always wondered how you guys can see where the heck you are going with the Hagies. You can't see the wheels from up in the cab.
MMiller
Posted 12/8/2010 18:59 (#1475080 - in reply to #1474690)
SW Iowa
I like the Miller Nitro we have, its a 2000 model 200HT(I think). We get very little chemical residue on it at all. I would not enjoy looking over my shoulder along fence rows, tree lines, intakes, and everything else I miss with the booms. The one thing that I notice is coming to the end row, if you drive out to your wheel tracks, then turn down them, you will swing the end of the boom out over the fence and sometimes close to the road. You just have to drive it a little differnt. I've never backed the booms into a tree in a corner, just pull up to the edge of the crop and back around a little and head out.
I've even sprayed corn after tassle(I hated every minute of it), but the machine got the job done, and even without a hood, I have no troubles staying on the row. I put an old CB antenna on the boom, and use it at a guide down the row.
Very rarely have we had weeds in the wheel tracks, then again our weed control program is differnt then most in our area. We don't trust RU to get everything.
Michael
maninblack
Posted 12/8/2010 19:51 (#1475185 - in reply to #1474690)
Subject: Hagie tracks???
So Illinois
Lots more Rogater and Case tracks around here than Hagie ones. Not sure if they have tips behind wheels or not.
To answer how you drive,,,a little piece of 1 inch wide flat steel welded directly in the center of the boom acts like a hood ornament on the old 560!!. Just line it up.
averagejoe
Posted 12/8/2010 20:25 (#1475254 - in reply to #1474696)
Minnesota
How many hours do you guys with Hagie sprayers have on them? Which model?
How about case guys, would 3000-3800 hours concern you?
averagejoe
Posted 12/8/2010 20:35 (#1475269 - in reply to #1475185)
Minnesota
agboy
Posted 12/8/2010 21:21 (#1475378 - in reply to #1475066)
Flandreau, SD
do you look at the wheels on a combine?
boog
Posted 12/8/2010 23:52 (#1475767 - in reply to #1475269)
I would be more concerned with who previously owned the sprayer and how they maintained it than the hrs. As for your question, we just traded a 2,000 hr JD 6500 for a 3500 hr 3185. The sprayer was farmer owned & in immaculate condition. If it had been owned by a fertilizer company I don't know if we would have traded for it.
We're on 20" corn & beans. We always sprayed with the rows with the 6500 but we could see our front wheels. I'm hoping to run with thr corn rows but if I find that too hard to do I'll spray crossways which is how most guys around here spray ultra narrow rows with bigger sprayers. I also owned a front boom sprayer before the 6500. There's advantages & disadvantages to both. Worst, IMO, is not being able to see when a nozzle plugs on a rear boom. Getting chemicals on the machine is the biggest drawback I encountered with the front mount.
