Search Forums | Classifieds (35) | Skins | Language
1985 Steiger
ckansas
Posted 3/30/2007 23:33 (#128463)
Subject: 1985 Steiger
Hoisington, KS
Looking at a 1985 Steiger Cougar KR1225 with the L10 Cummins engine. I've never been around one of these tractors before and what their pros and cons are. It has PTO which would make a good grain cart tractor. It has 8000+ hours but the transmission was recently gone through and the engine overhauled. What's a tractor like that worth? Is that the last year they were green before Case IH bought them out? It looks like it's been very well taken care of and always shedded.
Edited by ckansas 3/30/2007 23:33
Ham
Posted 3/31/2007 00:01 (#128485 - in reply to #128463)
Subject: RE: 1985 Steiger
Blvd d'Espair Bowhill, Sth Aust
We had a CR1225, which means it had the Cat engine, instead of the Cummins.
Three issues we had with with ours..
1. The "Uniball" cats-eye type bearings for the articulation joints would wear severely. For us, less than 2000 hrs life. It may be an operating conditions thing.; I dont know. i do know they were greased every 10 hrs as recommended.
2 The diffs. ( row crop axle models) and gearbox are Allis Chalmers built, and there is a gear that connects two splined shafts, high up in the gearbox. It is accessible by removing the seat and panel in the cab floor. It doesnt get enough lubrication, and will strip the splines. When it does, you lose foward and rearward motion, as well as hydraulic and steering function.
3 The air con is hopelessly inadequate for our summer conditions. Yours may or may not be as difficult.
Jon Hagen
Posted 3/31/2007 00:29 (#128500 - in reply to #128485)
Subject: RE: 1985 Steiger (pic)
Hagen Brothers farms,Goodrich ND
If it's a C/K R 1225, it has to be an 85. That's the only year it was built with the 225 HP engine. You decode the number this way.
K = Cummins engine.
C = Cat engine.
R means it has the 20 spd Allis Chalmers built semi power shift trans.
1 = 1000 series tractor with the better octagon cab,better AC and PFC hydraulics.
225 = flywheel HP.
The bar axles are listed as Steiger/Raba built .
I thought the AC was fine, but I am in the far northern US and may not have to deal with the temps Ham sees. Also, ours has a bit over 5500 hrs and is just now getting quite a bit of slack in the top articulation joint, once again, maybe different operating conditions.
Mine also has the 1000 PTO which I have used to power a 1482 IH pull type PTO powered combine for 20 years. No problem there except that the large rotating mass of the combine rotor and drive line has eaten up the PTO brake. Like all L10's it will use a gallon of oil every 30-50 hrs.
The Steiger tractors were still available in your choice of Green or red for at least the first year CIH owned them ( 87-88 ? ) The red 9150 is basically the same tractor with the Ranger trans replaced with a 10 spd ?
power shift and the engine set at 280 HP with the inter cooler added.
If any of you are interested, here is a link to my tractor and combine on the toy tractor show site.
http://www.toytractorshow.com/kr1225.htm
Edited by Jon Hagen 3/31/2007 01:42
(Steiger + combine front jpg.JPG)
Attachments Steiger + combine front jpg.JPG (22KB - 870 downloads)
ckansas
Posted 3/31/2007 00:47 (#128510 - in reply to #128500)
Hoisington, KS
Thanks for all the information. Do you know how big the fuel tank is? In the auction bill it's advertised as having a standard axle. What's that mean? Do you have yours or did you sell it? What do you think this tractor is worth? Oh, yeah, what's top road speed?
Thanks again
Jon Hagen
Posted 3/31/2007 01:04 (#128514 - in reply to #128510)
Subject: Re: 1985 Steiger
Fuel tank is right at 170 gallons. Standard axle ?? They were available with either the outboard planetary axles or inboard planetary bar axles for row crop work. Either type made by RABA.
yes, I still have the KR 1225, I use it to pull the 1482 combine as a backup harvest machine and to rescue the Panther P4 KM 325 and 750 drills out of the mud potholes in spring planting.
I have not priced them for a few years, but I would guess one in my area would bring mid to high 20's. 8000 hrs is getting high, but the engine and trans overhaul eliminates a lot of that risk and puts some value back into the tractor.
Road speed with 18.4-38 tires is 18 mph.
Edited by Jon Hagen 3/31/2007 01:40
Ham
Posted 3/31/2007 02:19 (#128522 - in reply to #128510)
Subject: I still had the sales brochure....
... but i gave it to a friend who also has one of these tractors.
I will try and get a copy scanned to send to you.
This may take a couple of days ( if it happens at all ) , but I'll let you know if it happens..
Rockhead
Posted 3/31/2007 07:12 (#128549 - in reply to #128500)
Chippewa County, MN
Jon,
You're doing really good if you can go 30-50 hours per gallon of oil. Mine burns that much in a day. I got tired of that and overhauled it at 4400 hours including sleeves, pistons, bearings and valve guides. Didn't look like turbo seals were leaking so I didn't replace that.......but it still uses a gallon a day. That's my biggest gripe.
ckansas
I had to overhaul the two speed powershift in mine. That cost $5000. A neighbor's powershift went out a couple of years later. I think the transmission is tough, but when it comes time to fix, parts get expensive.
I replaced the short shaft out of the drop box to the rear drive shaft as the splines were getting wore and vibrating a lot when turning.
Fuel efficiency has been very good however. I have mine turned up a bit on power and I seldom can get 10 gallons per acre through it. I usually shift up and throttle back and that saves a lot of fuel.
hillfarmer
Posted 3/31/2007 07:43 (#128561 - in reply to #128549)
"ten gallons per acre"
bet you met hour
Jon Hagen
Posted 3/31/2007 10:01 (#128613 - in reply to #128549)
My experience was that the new Steiger with the L10 used oil while the old Detroit repowered versatile it replaced would go 100 hrs before needing oil,so I was not happy. Cummins checked that the dipstick was right so it was not overfilled and checked for turbo seal leaks,found no problem, said to run it a few hundred hours which improved nothing. Cummins agreed to overhaul the thing with the "new design" sleeves and pistons, although the shop forman showed me a chart that stated that 1 qt in 4 hrs was considered normal for the L10.
That effort was a waste of Cummins time and money, as oil consumption was the same as before.
mr8850
Posted 3/31/2007 10:03 (#128616 - in reply to #128561)
Minot ND
my brother inlaw has one, last fall the hyrdolic pump drive striped out, case/stiger no longer makes parts , we had a machine make the coulpler and the pump shafts, took two months, good thing it wasn't planting time. I thing case said they only made this tractor one year.
bushton4
Posted 3/31/2007 10:35 (#128652 - in reply to #128463)
Drop me an email. I have a good friend with a Cougar 1000 that he is looking to sell. Will be more HP but the unit still has a pto and is row crop. I know the engine and transmission were both recently overhauled. Let me know
[email protected]
tommyw-5088
Posted 3/31/2007 19:32 (#128873 - in reply to #128652)
Subject: the small bore cummins all drink oil
Texas
the L-10 ,M 11 ,ISM cummins all drink oil with the L-10 being the worst . the small bore is horrible in a truck grossing 80,000# ,but they work alot better in a loader or tractor . they seem to live at least 2x longer with a lower rpm application . they are wound up tight in a truck .
ckansas
Posted 3/31/2007 23:47 (#128988 - in reply to #128613)
Hoisington, KS
Went and looked at and test drove the tractor today. The transmission would take some getting used to and the clutch is touchy but the tran was just overhauled 100 hours ago. Any problems with the air filter up in front of the radiator? Also the owner said it never used much oil and said he pulled a 7x5 undercutter with no problem. How many hours do you guys have on your Steigers? This one is at 8700.
Rosco
Posted 4/1/2007 03:15 (#129032 - in reply to #128988)
Galahad, Alberta
My brothers own a '85 CR 1280 w/ a cat 3306 motor in it. It currently has 8900 hrs on it. Much of my youth was spent on that tractor. They did the bottom end at 5000 just as preventative maintainence, which was a waste of time, as the bearings were fine. It is currently sitting because the tranny brake needs work, and it could be an very expensive fix. Make sure that you grease the bottom king pin in the center well. On this one, you had to articulate the tractor all the way to one side to expose the grease zirc (otherwise it was hidden and thus missed). Stupid design, when they redid the pins, they drilled a new hole from the side for the zirc to make it easier to grease. Trying to remember everything that we fixed in 19 years. Coolant rad, hyd. rad, water pump, electronic feul seleniod x 2, 3 axel seals, alternator x 2, lots of lights, couple of electical breakers, more batteries than I care to remember, hydraulic pressure senders x 3, air conditioning tubing in front of cab from letting hood down slightly crooked and hitting the lines, door handel x 2, throttle cable, 1 driveline bearing & pillow block,king pins, just about every damn haydraulic line under cab from the block back to the rear end! They ran them through a hole in the frame under the cab, and over time they would rub and wear holes, no matter how we tried to isolate them. Ran it on a pull type combine (JD 9501) for a number of years, which took an awful lot of electrical juice. This contributed to a lot of the alternator, battery, breaker and light problems. Finally put a much larger alternator on the motor and that solved a lot of things. I really liked the cab-great visability, but the climate controls are very poor. If you do buy the machine, make sure you read the manual very closely about how to use the clutch so as to not wear out the tranny brake prematurely. If you are at all confused about it, just post to Jon Hagen or myself. Good luck.
Rosco
ckansas
Posted 4/1/2007 12:46 (#129163 - in reply to #129032)
Hoisington, KS
Where do you get parts for yours? Is there still a business in Fargo that sells parts? This Steiger was in the shop for 3-4 months when they overhauled the transmission because it took so long to get parts from up north. Oh yeah, why do guys use pull type combines up there, I didn't know they made such a thing anymore.
Rosco
Posted 4/1/2007 19:16 (#129320 - in reply to #129163)
Galahad, Alberta
All the tractor parts came from CaseIH. Any motor stuff came from Cat. I don't think anyone does make pull type combines anymore. They were a lot cheaper than an sp and for smaller farmers doing just small grains, they were fine.
Rosco
Bluepaint
Posted 4/1/2007 19:26 (#129327 - in reply to #128873)
Subject: RE: the small bore cummins all drink oil
Manitoba canada
I've had several L10's and not one used oil nor my 855's I'd take either over a 3306 cat .
ckansas
Posted 4/2/2007 20:11 (#129854 - in reply to #128514)
Hoisington, KS
The Steiger down here in Kansas sold for $17000. 8700 hours
A Ford Versatile 876 with the same engine sold for $30500. 4000+ hours
