Search Forums | Classifieds (5) | Skins | Language
pros and cons of 996 new holland corn head
sonn
Posted 4/6/2010 21:26 (#1152647)
Subject: pros and cons of 996 new holland corn head
I am looking for a 6 row 996 new holland corn head. I noticed they were only made only a few years. Any common problems with these heads. i noticed some were available with hyd deck plates. TIA
illinidirtfarmer
Posted 4/7/2010 09:12 (#1153283 - in reply to #1152647)
Subject: Re: pros and cons of 996 new holland corn head
WC IL
I think this series head will only work on the newer series combines- won't work on TR series, only CR. Can't convert to the narrower feederhouse on the TR's. I'll take that back, you can, but only by cutting and welding. I think they are a good head, though.
Edited by illinidirtfarmer 4/7/2010 09:13
Cross Country
Posted 4/7/2010 16:51 (#1153733 - in reply to #1153283)
Ottawa, Ontario
illinidirtfarmer - 4/7/2010 09:12
Actually these heads will fit a TR without any tinkering.
I have one on my TR86 and haven't had a moment of troubles with it. The poly on the outside rows will wear thin, beyond that I haven't seen any weakness to this cornhead. I have the hydraulic deck plates...very nice indeed.
Ltfire
Posted 4/7/2010 21:33 (#1154081 - in reply to #1152647)
Subject: RE: pros and cons of 996 new holland corn head
North Central Iowa
Basically the same head as the Case 2200 series.  The 996 is very close to the newer 96c and 98c heads, but I can't tell you what exactly has been changed between the models.  They are a much better head than the 974 NH corn heads.  I was looking for one last year for my TR97, but then ended up finding a Drago in my price range and that's what I really wanted.  There are heads out there for both the CR and TR machines, but the cost to convert between the two is pretty high according to the dealers I talked to - in the $3000 range to change a head for a CR to fit a TR.
Good Luck,
Mike
illinidirtfarmer
Posted 4/8/2010 08:10 (#1154585 - in reply to #1152647)
WC IL
I guess I was wrong on the series the 996 will fit. I guess it might be the other way around, it won't fit the CR's without cutting and welding in a different center. I have a 96c on my TR86 that I got last year. Can't see how the conversion kiy could cost $3000, all it is is a couple of filler plates for the feederhouse opening, the different lower anchors, and hoses for the deck plates. Mine came off a CR, and the dealer included the kit when I bought it. He might have said the conversion kit is no longer available.
Ltfire
Posted 4/8/2010 18:09 (#1155132 - in reply to #1154585)
North Central Iowa
That's the price a dealer with a CR head gave me when I asked about putting his head on my TR.  Maybe he was including shop time in that, but that wasn't the discussion.  I agree it seems ridiculous for what is involved, but then Drago wanted more than $1700 for the adapter for their head to fit my combine.  That was just the adapter, installed by me.  I built my own.
Mike
