AgTalk Home | ||
Case IH hy-tran vs. AGCO Permatran 821XL Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
agricon |
I need to fill up my bulk oil tank and have to choose between the two. Anyways, who makes the the better fluid? Lastly, does anyone know where I can find ASTM data for both fluids? | |||
ihredfarmer |
WNY | Both are high quality fluids but the hy-tran dissapates the most moisture of any hydraulic fluid on the market. | ||
mfendtguy |
SEIA | Wanna know a secret? They are the same oil or at least eerily similar. Both come from same manufacturer. At least they did not all that long ago. Gotta love private labeling. | ||
IH 5288 |
Mandan ND | I would use neither. I used to use Case IH hy-tran until I locked up a flow control valve running a orbit motor. Then I talked to a Schaeffer Oil Rep and he told me to use Simplex Supreme 315. We dropped 35 degrees on the orbit pump. | ||
ptrudolph |
Boonville, IN | Massey Ferguson® Permatran® T&H Oil SAE 10W-30 Massey Ferguson® Permatran® T&H Oil is specially formulated with the finest quality, hydrotreated, high-viscosity index, paraffinic base oils and the most advanced and rigorously-tested additive system to deliver ‘above and beyond’ protection and performance. Group II base stocks provide the added benefits of improved thermal and oxidation performance and low temperature properties. Meets or exceeds oil requirements for: AGCO: AGCO® Permatran® 821XL Allis-Chalmers 626371, Powerfluid 821XL Massey Ferguson® Permatran® M-1143, M-1141, M-1135, M-1129A, M-1127A/B, M-1110, M-2235 White Farm Equipment™ UHTF, Oliver® Type 55 fluids, Q-1826, Q-1766, Q-1722, Q-1766B ABEX/Dennison: Hydraulic Fluid HF-0 (all pumps), HF-2, HF-1 CNH: Case IH Hy-Tran Plus, Hy-Tran Ultra, 1208, MS-1209, MS-1210 (TCH Fluid), MS-1230 Ford New Holland M2C134 A/B/C/D, M2C86 A/B, M2C53 A/B, M2C41 A/B Hesston® Fiat Oilofiat Tutela Multi-F, AF-87 International Harvester Hy-Tran B6 JI Case TFD Fluid (MS-1024, JIC-185), TFDII Fluid (MS-1205, JIC-145), Powergard PTF Fluid (MS-1206, MS-1210) Poclain Equipment for High Pressure Steiger HTF SEMS 17001 Versatile Gear and Hydraulic Transmission Fluid ESN-M2C134D Caterpillar: TO-2, MTO Clark: Lift Truck Transmission Fluid TA12, TA18, HR 500, HR 600 Deutz: Hydraulic Transmission Fluid Grove Manufacturing: Hydraulic Fluid John Deere: Hy-Gard, J-20C (J-20A), J-14B/C, Hydrostatic Fluid (J-21A), Type 303 Fluid Komatsu Dresser: Transmission/Hydraulic Fluid Kubota: UDT Hydraulic Fluid, Universal Transdraulic Fluid Renk: Bus ATF Sauer-Danfoss (Sundstrand): Hydrostatic Transmission Fluid Sperry Vickers: M-2950-S Mobil Hydraulics, I-286-S Industrial Hydraulics ZF: TE-ML-03E (Torque Converter Transmission Off-Highway and Industrial) TE-ML-05F (Off-Road Axles with the exception of hybrid gears) Features Benefits SAE 10W-30 Suitable for year-round use. API Service GL-4 Mild Extreme Pressure (EP) system allows use in farm tractors or farm equipment that requires one lubricant for transmission, final drives and hydraulic systems. Meets requirements of major OEM manufacturers Universal lubricant for most tractors. Simplifies product inventory. One product for most transmission, hydraulic, axle and final drive systems. SAE Viscosity Grade 10W-30 API Service Category GL-4 API Gravity ° 28.5 Flash Point, COC, min 207° F / 224° C Viscosity, cSt (centistokes), @ 40° C 57.6 @ 100° C 9.23 Brookfield Viscosity, cP (centipoise), @ -35° C 32,593 @ -20° C 3,960 Viscosity Index, min 141 Pour Point -30° F / -33° C Pour Cycle, 203 -44° F / -42° C Pounds Per U.S. Gallon 7.3 Foam, Seq 1 Tend-Stab, ml TR-0 Foam, Seq 2 Tend-Stab, ml 10-0 Foam, Seq 3 Tend-Stab, ml TR-0 Foam, Break Time, SEC 10 Foam, Seq 1 T-S + 0.5% H2O TR-0 Foam, Seq 2 T-S + 0.5% H2O 10-0 Foam, Seq 3 T-S + 0.5% H2O TR-0 | ||
deersniper |
We use CIH Hytran, we have a 7120 with 14,xxx hours that has never been apart, so we will keep using it. -dan | |||
(Delete cookies) | |
