Search Forums | Classifieds (85) | Skins | Language
Building a strip till
Elmfarms
Posted 3/15/2010 13:04 (#1121545)
Subject: Building a strip till
I am looking into strip tilling. I like to use it for working bean and wheat stubble. Some field I have to work in the spring because of erosion. Will a ortman row crop cultivator be a good starting point to build something yourself?
Smoothlander
Posted 3/15/2010 13:07 (#1121546 - in reply to #1121545)
Subject: RE: Building a strip till
I can tell you that Hiniker makes a conversion for their cultivators.
Jim
Posted 3/15/2010 13:45 (#1121597 - in reply to #1121545)
Subject: RE: Building a (spring) strip till from a cultivator
Driftless SW Wisconsin
I think you are on the right track thinking of spring strip till for HEL ground in areas where pure notill is not a viable option.
There are a couple points to be aware of however:
1) CULTIVATORS are designed to operate ON the tractor tire spacing = between the rows, where you would be cultivating.  STRIPTILL on the other hand is done OFF of the tractor tires as a planter bar is. The pivot points and about everything else you can think of on a cultivator bar is usually welded in exactly the wrong place on the bar when trying to mount any type of strip till units. Planter toolbars are much better places to start a strip till machine than a cultivator bar.
2) For SPRING strip till, especially farther north, in many soils you are better off using a coulter-type rather than a shank-type strip till machine. I think it is interesting that Orthman, long the "deep shank" strip till people, now offer a conversion kit to convert their shank type strip till unit to coulter type units. Be aware of the risks of spring planting directly over a spring made shank-type strip with a real hot band of concentrated fertilizer right at the bottom of that often still open (below the surface) slot.
Best of luck,
Jim at Dawn
Edited by Jim 3/15/2010 13:48
hwdcne
Posted 3/15/2010 13:47 (#1121600 - in reply to #1121546)
Subject: Re: Building a strip till
Soutwest Ks.
Elmfarms: I built one using an Orthman Row Crop cultivator. I did this probably 7 or so years ago when people in my area were debating if it was a valid practice. I didn't want to spend a lot of bucks on something that potentially may have been obsolete in two years, so I did this inexpensive route. After running it for approx. 4 or 5 years I found that the individual row units were starting to twist which would effect the alignment of each row. I finally sold the rig and bought a new Orthman 1tRipper. If you look at the difference between the two, you can easily see that the row crop units are not built to heavy enough specs to last very long. On the Orthman that I put together, I mounted Martin trash whippers right behind the solid coulter, followed by a special heavy duty mole knife I purchased through Waco Industries, Enid, OK. Berm builders were made by Yetter. I used my own shank design to bolt the mole knives to with a mount for the Yetter berm builders. I could only run prob. a max. of 8" deep with that design. The 1tRipper can run 10"+ inches deep if needed. If you think you are in strip till to stay, I would probably skip the home built rig and go with a proven design. Orthman cult. probably have some of the heaviest row linkage in the business and if it won't take the stress, I don't know where you would go for a start to your own home built unit. On the other hand if you didn't need to go so deep, maybe 6" or so I think the Orthman cult. may work OK as long as you have or can purchase one with rigid, banded coulters on the front. It is hard to get the trash to flow as well with a rig like that as the newer style 1tRipper with the extended linkage. It gets real tight to get all your accessories mounted in the space that is there on the cult. rig which in turn makes for sensitivity to high residue and humidity.
Elmfarms
Posted 3/15/2010 14:02 (#1121619 - in reply to #1121600)
Thanks. I doubt if I will go that deep. I will mostly be working in the spring. Since we are not working in corn stuble I am not to worried about trash and have trash wheels on my planter. Still don't know if I should go coulter or shank.
pdt1888
Posted 3/15/2010 21:40 (#1122177 - in reply to #1121597)
Nebraska
What model of Orthman cultivator are you looking at using? Some of the cultivator models will be more apt to work in your situation, due to frame style, coulter front or tire front, etc.
I am assuming that you already own the Orthman cultivator as a complete machine, bar and all. If that is true then as Jim at Dawn said, you will run into problems with the spacing of the units and the hinges on the bar (if a folding bar). What size and spacing of rig are you looking at setting up and are you looking at setting up a coulter or shank style unit? If a coulter unit then the planter toolbar may suffice. If you are looking at a shank style machine, with a folding planter bar, you may want to try a non planter bar. The planter bar may not be able to handle the draft load induced by a large shank style unit. A 7" X 7" X 1/4 wall planter bar may work for a coulter unit like a Dawn setup, but not likely to hold up as well for a large shank unit.
As to the comment "Be aware of the risks of spring planting directly over a spring made shank-type strip with a real hot band of concentrated fertilizer right at the bottom of that often still open (below the surface) slot" I know many farmers that are placing fertilizer in the spring in wet, dry, and perfect planting conditions that have not had any problems with that "hot band" of fertilizer, because they understand how to set and operate their machines. All of them have been using shank style rigs (couple different brands), and love how they operate for them. I think with all of the strip till machines out there, proper knowledge and study of their operation is key to getting good results.
I saw some forums on here talking about the orthman shallow tillage tool, and I was surprised at first, but after seeing the response of other users it seems that it was wanted by some farmers out there. I am still a leaning towards a shank style strip till unit, especially when it comes to placement of the fertilizer. I am still trying to decide what machine to purchase and have been searching every forum and website with information on strip tillage.
I can tell that Jim at Dawn is very informed and knowledgeable when it comes to strip till, but you can almost feel the salesman undertone for his product in some of his posts. Especially when you catch things like the shot across the bow he took at Orthman in this thread.
Greywolf
Posted 3/16/2010 07:47 (#1122641 - in reply to #1122177)
Aberdeen MS
I'm not sure where you are, but Jim did mention "further north".
It's not quite a shot across the bow at Orthman, a shot across the bow against all the rest of the shank/knife type units (about 15 or 16 of them), yes.
In heavier clay soils in northern Ia, Mn, SD, ND, (for examples), doing any tillage of any sort deeper than about 4" in the spring is setting up a scenario that may be disastrous if certain weather conditions follows after stripping. If a person would ask conventional tillage guys if they would go out with their "ripper" in the spring, the answer would probably be NO. So why do it in a narrow band? But that is "here" not sure what it is "there".
The soils that are prevalent "up here" sometimes will still have frost deep when the top 3-4" are fit to go. Using a knife/shank unit in heavier clay type soils MAY end up with a smeared, compacted side wall that when dried out becomes quite "brick" like which only lead to the plant doing what it does naturally when putting roots down. That's taking the path of least resistance which takes them down the trench first into the concentrated nutrient band before attempting to branch out.
Why are those that direct seed/plant so concerned with side wall compaction in wetter conditions?? A knife/shank type set up accomplishes it's designed action by compression of the soil structure. That eliminates the air in the mix leaving only soil and water, which as you know, when the water evaporates out, clay only becomes quite a brick. A vertical tillage type coulter set up doesn't not compress the structure, actually injects a bit more air into the zone keeping the seed zone closer to the 50/25/25 ideal mix (in wetter spring time conditions).
It is all so very dependent on soil type, internal drainage capability, and local climate conditions as to what degree of possible failure that MAY take place using a knife/shank unit in the spring.
Past agronomic practice comes into play as well. A very well structured soil profile basically only needs a strip worked 3" deep to provide a bit of drying with a residue free surface to give a better guarantee of seed to soil contact (basically the only reason spring tillage is done in the first place). That structure is not achieved in one year when converting from conventional/mulch till to conservation type tillage.
Nutrients place to the side of the band, complimented with a small amount placed right below the seed zone, followed with a side dress of N (for corn) at the time closer to when the plant needs it gives one the best bang for the buck of nutrient applied in that crop year than just about any other system on the market today.
Each strip till tool does what it is designed to do and they all do it well. When applied into the conditions they were designed for. Knife/shank type units were not designed to operate in wet high clay type soils in the spring, a coulter type unit is however more suited to that type of operation.
Jim
Posted 3/16/2010 13:25 (#1122975 - in reply to #1122177)
Ryan,
Thanks for your detailed post. It is especially interesting considering it is your first post. We have been working on various forms of strip till since at least 1993, beginning with adding row cleaners to a DMI-type mole knife anhydrous bars.
Over the years it became clear that this type setup, as originally invented by Jim Kinsella, is basically a fall strip system.  Some years you can get away with it in the spring, some years you will have significant fertilizer burn or delayed plant development because of an open drying slot made in wet soils directly under the seed.
As Bruce mentions this becomes more of a concern the farther north you are and the wetter heavy soils tend to be in the spring. Soils dry from the top down - the fittest soil you have in the spring is near the surface, not down deep.
Strip till in the south is a whole different process altogether. Folks there have been basically deep ripping just ahead of the planter for years. This is also done in many of the drier areas of the southern plains. This spring ripping/planting directly over it type strip till is not generally done from about the central cornbelt on north - the mud belt.
Take a look at some of the mud pictures on the Stock Talk page right now. Picture pulling a deep ripper through that stuff any time in the near future. When it does start to dry, from the top down, doing a bit or row cleaning and light working/aeration of the soil followed by planting as it grays off can work very well. Fertilizer can also be precisely placed at the same time either mixed in or a safe distance away depending on the product and amount being used.
Many agronomists are saying the most efficient use of fertilizer is about 1/3 of your N and maybe all of a reduced rate of P & K in the strip just ahead of planting followed by side dressing about 2/3 of your N, maybe even on 60" centers.  There are a wide range of fertilizer placement systems which will "work" and that is a much longer discussion.
I applaud manufacturers such as Orthman that build quality products in the US and are flexible enough to provide adaptations, such as their new all coulter system, to meet some of their customers needs.
As far as the logic of trying to turn a larger cultivator bar into a strip till bar, many folks that try it soon find they would have been time and money ahead just to purchase a planter-style bar, such as a Moore-Built or any one of a number of other bar manufacturers we have worked with, from the start.
Even a used planter bar such as the JD 1780, with wheels on the front, makes a good strip till bar. There is one in the video here. Bauer makes large planter type bars that are ideal for wide strip till. Cultivator bars just never seem to work out.
I am on this board, often at all hours, for the same reasons most of us are here - we love ag equipment and farming. I am not on here at 3 am to take shots at any other manufacturer. I am a believer in what we are doing but it is not the only way - never said that and never will.
Regards,
Jim at Dawn
coyfarms88
Posted 3/16/2010 20:32 (#1123342 - in reply to #1122975)
Southern Illinois
Thanks jim for all the information that you provide us on here. I find that the information you put on this website is very informative. I have learned a lot on this website from your posts and others. It has made me become very interested in strip till.
pdt1888
Posted 3/17/2010 14:29 (#1124510 - in reply to #1123342)
Nebraska
Jim,
I am glad that you did the background check on my AgTalk account, my “especially interesting” post may be my first, but I have been reading this and many other farming forums for quite a while now. This post interested me as I am trying to convince my uncle and grandfather who I work with that strip till is the way to go. Being unable to convince them to purchase a complete machine, I have been looking into the route of building my own similar to Elmfarms situation. My idea was to start with an Orthman cultivator that we currently own on the farm as it seems to be pretty heavy built compared to a lot of other older cultivators. In my situation it has been very hard to persuade my grandfather and uncles 80 + years of experience in conventional tillage practices to take a look at strip tillage. One of the few things that is still appealing to them about strip till is the ability to have a shank style unit that will be able to reach into the “hard pan” and work at breaking that up in the root zone in their words. That is why most of my searching has been into those style of units. If I am able to convince them to try strip tilling it will be done in the fall, God willing.
Greywolf brought up the point of spring deep ripping. Which I would agree is a huge NO from anyone that I know. My only question to Greywolf would be what strip till machines are offering up 18” “ripping” depths, (which seems to be a frequent deep ripping depth for many producers in our area)? Oh and for Greywolf “there” is Hall county Nebraska. From what I have seen there aren’t any companies promoting deep ripping. They all seem to promoting a depth of anywhere from 7-11” depending on your soils characteristics.
Greywolf had said
Past agronomic practice comes into play as well. A very well structured soil profile basically only needs a strip worked 3” deep to provide a bit of drying with a residue free surface to give a better guarantee of seed to soil contact (basically the only reason spring tillage is done in the first place). That structure is not achieved in one year when converting from conventional/mulch till to conservation type tillage.
If the switch from conventional tillage is made to strip tillage, would it not be a benefit to have a shank style machine to use in the fall to begin creating that well structured profile deeper than the 3” depth that he refers to made using a coulter style system? This is assuming that the soil structure or lack thereof in these converted fields is basically still liquefied from the previous maximum tillage practices. This will likely be less of a problem for those who have been intelligently and successfully no tilling for a period of time.
As to my salesman comment Jim, I may have hastily written something that I should have rephrased. Initially looking at many of your posts I can’t help to notice the promotion of your product. But you are also quick to tell people that it will not work in some situations, which helps me to believe that you are definitely on here also to try and help educate others. I do look at some of that promotion as advertising, but advertising that is strategically placed… which is the best kind! You are the only mfg. that I have noticed that is actively using such a great place to inject that knowledge you have been collecting about strip till since 1993. What better way is there to have daily interaction with possible customers around the world? I have also viewed almost every video if not all that Dawn has put on youtube as well. I think you have been a pioneer in the ag industry when it comes to very effectively utilizing many different areas on the internet for getting some of your products out in the worlds view. I think eventually these forums and youtube will be filled with mfg’s that will try to do what you have so effectively done. Hopefully they will try to be as objective and truthful as it seems many of your posts are. I also do not think you are solely on here to promote anything. I have read many of your posts on here that are nowhere near related to strip till or planter attachments. I found your article on vacuum planter history very interesting, as well as many other.
Back to the home built strip till machine that this thread started with. What type of tooling are you looking at using if you are to build your own strip till machine?
Jim
Posted 3/17/2010 18:24 (#1124688 - in reply to #1124510)
a "7-11 inch" deep slot directly under the seed in the spring may not be "deep ripping" but in heavy wet northern soils in the spring just ahead of planting there are many soils and conditions where that will still be a smeared open slot down under the seed regardless of what rolling baskets etc are used.
We were working with a mole knife in the spring at just 5-6" deep and in some conditions there was crop damage from fertilizer burn or drying from and open smeared slot below the surface.
It may work in some times and some places but there is a risk to spring planting directly over a spring made knife slot of about any normal depth.  Shank type strip till, in the north, is usually best done in the fall.
For building your own strip till machine, depending on the width and fold vs rigid, I would start with a good sturdy, heavy duty often "ridge till" type planter toolbar.
A point to keep in mind is that the success or lack of  in strip till by many of our customers is largely determined by the toolbar they mount our row units to.  I think this also applies to many other manufacturer's  strip till units also.
Jim at Dawn
PS - I have been on this board and its predecessor since about 1995 or maybe 1994 - I didn't write it down. I'm glad you approve.
Edited by Jim 3/17/2010 21:12
strip_tiller
Posted 3/17/2010 19:50 (#1124764 - in reply to #1122177)
To clear any confusion the Orthman coulter attachment was intended to replace the shank for spring tillage when said shank is not appropriate. And yes we do preach deep tillage in the fall but an option for spring strips was necessary. A lot of farmers in our area (central Illinois) did not get a chance to do our fall strips. It's about options.
strip_tiller
Posted 3/17/2010 20:16 (#1124809 - in reply to #1121600)
To answer your question Elmfarms, yes I have heard of it being done but have never seen one. How deep would you be running the shanks?
Jim
Posted 3/17/2010 21:21 (#1124948 - in reply to #1124510)
Ryan, an idea of a way to address your family issues:
"...In my situation it has been very hard to persuade my grandfather and uncles 80 + years of experience in conventional tillage practices to take a look at strip tillage..."
Rather than trying to change their deep seated feelings about the necessity of full tillage and also for economic reasons, I suggest you ask them to let you try strip till on maybe 20 or 40 acres somewhere.  This is a time for you to experiment with different types of strip till and learn about it without trying to convince them to risk turning the whole farm over. They feel there is too much risk and they are probably right.
Maybe try a couple different systems - coulter, deep shank, fall, spring, fall and spring, etc. Make up a 4, 6 or 8 row mounted bar from an old mounted planter frame and give strip till a try. You will learn a lot and be in a much better place to make a decision on which way to go before risking an entire crop. And you will have their support when you do it.
By the way even on a small mounted bar we find it is very important to have gage wheels on the front of the toolbar and put the three point in the slots to float - let the bar line itself up to the ground and you MUST have a top link.
Best of luck.
Jim at Dawn
Edited by Jim 3/17/2010 21:23
