Search Forums | Classifieds (26) | Skins | Language
feed bunks
GREEN FARMER
Posted 12/24/2009 18:14 (#984107)
Subject: feed bunks
central mn
Looking to build some fenceline feed bunks, wanna use them from weaned calves on up to yearlings, possibly alittle older too. Anyone have what they think works the best, have to keep the calves from escaping but also be able to feed older ones. Interested in any ideas or pics u guys have. thanks
rocknkcattleinc
Posted 12/24/2009 19:11 (#984199 - in reply to #984107)
Subject: RE: feed bunks
NW Iowa
These are sonething i built quick to wean calves and a spot that i move cows to be calved. I was running out of time to pour cement and have bunks set in so this is what i did. I Have 8 foot 3.5 heavy pipe shoved in the ground every 12 feet, the bunks are 24 foot a piece, there is 50 foot there. Then i put 6x6 boards for the bunks to sit on, then used two 3x12's for the bottom, two 2x12's for the back side and one piece of 4x16 bridge plank for the cattle side. To keep the cattle from shoving them out i built straps that go around the inside poles to hold them and some 4 foot 3.5 poles shoved in the feed wagon side for extra strength. I Put guard rail up top, then welded pipe to flat iron then shoved oil field pipe through the pipe so they can reach the backside of the bunk. Built them real fast and they are handy for the moment. They might stay longer than intended. These calves are 650-750 lbs and i've feed some 1600 lb cows there and it worked great for them too. Any more questions just ask.
Edited by rocknkcattleinc 12/25/2009 14:15
(0916091857.jpg)
(0916091857a.jpg)
(0916091909.jpg)
(0919091529.jpg)
(0919091532.jpg)
(0919091757.jpg)
(1222091507.jpg)
(1222091510.jpg)
(1222091510a.jpg)
Attachments 0916091857.jpg (54KB - 1909 downloads)
Attachments 0916091857a.jpg (56KB - 1759 downloads)
Attachments 0916091909.jpg (38KB - 1581 downloads)
Attachments 0919091529.jpg (48KB - 1671 downloads)
Attachments 0919091532.jpg (48KB - 1690 downloads)
Attachments 0919091757.jpg (41KB - 1669 downloads)
Attachments 1222091507.jpg (44KB - 1638 downloads)
Attachments 1222091510.jpg (44KB - 1699 downloads)
Attachments 1222091510a.jpg (50KB - 1689 downloads)
Jim
Posted 12/24/2009 20:50 (#984297 - in reply to #984199)
Driftless SW Wisconsin
Kevin, Those look good! I have a similar fenceline/guardrail setup with concrete bunks except a 1/2" cable for the neck rail where you have pipe. One thing I have found is that calves will scoot under the neck cable/pipe and end up inside the bunk, then out where they shouldn't be!
I put a couple wire cattle panels and tee posts behind the bunk but they would still get in the bunk. Finally went to plan B and put some scrap 1/4" plywood sheets (almost free at the lumber yard) and put them down between the rear of the bunk and the cattle panels so it cut the sight line out.  Calves now stay in and everyone stays calmer when they can't see out past the bunk.
Not a problem with the yearlings and over but 200-300 lb calves seem to be able to squeeze thru about any (non-electrified) opening with something interesting on the other side!
Bunk looks good. I like guardrail on those pipe posts.
Jim at Dawn
Edited by Jim 12/24/2009 20:51
rocknkcattleinc
Posted 12/24/2009 21:32 (#984326 - in reply to #984297)
Subject: Re: feed bunks
NW Iowa
Thanks Jim and Happy Holidays! Can you still feed with a feed wagon with the setup of ply wood and panels? I've had a friend put in short round steel posts along the feed wagon side just a few inches above the bunk and put a hot wire up but they have the cables. Mostly everyone has gone to the pipe around here and they don't sneek through cause nothing gives to be able to get legs and necks through. I delivered a bunch of calves from the sale barn for a neighbor of mine last week that averaged 255 lbs and he has a 2 pipe setup with the bottom pipe the same height as mine. Calves never reach our feedlots under 550 lbs. This yard of mine is mainly set up for cows about to calve January-April. About 35 head at a time rotation as they calve, then they move to single pens with their calves for 1-3 days, and new momma's come in to take their place. But this year its an over flow yard for extra calves untill i'm ready to calve in 2 weeks. Hope the weather shapes up by then!
Jim
Posted 12/24/2009 23:06 (#984455 - in reply to #984326)
I onlĂ˝ use my bunks for a sweet feed treat once a week or so to get them coming into the corral when I call. I just pour a couple 5 gal pails of feed in. over the top by hand. I would think you could load it over the toP with a feed wagon but might be tough to see level. Jim at Dawn
wade4545
Posted 12/25/2009 00:10 (#984559 - in reply to #984107)
bunksbunks2
jackND
Posted 12/25/2009 08:37 (#984756 - in reply to #984107)
Subject: RE Cable
I would avoid cable if at all posible. Been there, done that. Cable can wear and deposit thin wires in the feed. Changed ours out to 7/8 sucker rod within 2 years and it works great. Hardly any escapes anymore, and easy to adjust with our bracket system. Will try to find some pics. Shortly after this was taken we changed out the cable. This system is easy to clean and works well for us. 850 lb hfrs here. we just turned them in for the day. If we were feeding we would have the cable (or now sucker rod) up higher. We finish steers with this line.
Edited by jackND 12/25/2009 08:56
(Drills & Calves 093.jpg)
Attachments Drills & Calves 093.jpg (61KB - 1770 downloads)
CATGUY
Posted 12/25/2009 11:06 (#984984 - in reply to #984756)
Subject: RE: RE Cable
Iowa
You probably already know this, but I will mention it anyways.
There is a difference between "fenceline feedbunk cable" and wire rope(cable) that is used for towing or overhead lifting.
 The fenceline feedbunk cable uses fat wire and only about 7 strands or so. Dad and I had to go to a concrete place that sold feedbunks to find the actual fenceline feedbunk cable, you just can't go to the hardware store and buy this style of cable off of their shelves.
rocknkcattleinc
Posted 12/25/2009 11:55 (#985082 - in reply to #984756)
NW Iowa
Looks like they need that cable rasied a few there Jack? Just by the look in 542's eyes anyway lol. I like the sucker rod idea, has alitte flex yet strong and lasts forever.
Jim
Posted 12/25/2009 13:02 (#985220 - in reply to #984107)
Subject: RE: feed bunks - dimensions
This is a good clear publication on feedbunk dimensions and neck rail (H) height I used with mine:
http://www.agriculture.gov.sk.ca/1633a
Jim at Dawn
rocknkcattleinc
Posted 12/25/2009 14:11 (#985317 - in reply to #985220)
NW Iowa
Here's another site that gives alot of options and specs on bunks. This is also the place we all buy feed bunks from in our area.
http://www.allianceconcreteinc.com/precast/fence_bunks.htm
SOILcattleman
Posted 12/25/2009 22:36 (#985859 - in reply to #984559)
West Salem, Illinois
Hey wade, In the bottom pic you have a bunk made out of what looks like a piece of large diameter pipe? Do you like that bunk or would you rather it be concrete? What dimension is the pipe, and it looks like you also have a 2x6 around the back so the calves don't slope the feed out of the bunk?
wade4545
Posted 12/25/2009 23:00 (#985888 - in reply to #985859)
SOILcattleman - 12/25/2009 21:36
Its just sheet metal curved and welded, not sure who made them. Id rather have concrete( concrete ones are a little bigger and easier to shovel out with a flat bottom ) Theres just boards around the front i guess to get a little more feed in them and so they dont push it out the front.
