Search Forums | Classifieds (60) | Skins | Language
Case IH spx 3200 sprayer questions
CaseIH2388
Posted 11/24/2009 00:29 (#936038)
Subject: Case IH spx 3200 sprayer questions
Strasburg North Dakota
We are dealing on a 2004 Case IH SPX3200 sprayer with 1400 hours. Are they a pretty good machine. We have a 1996 854 rogator. Is it louder in the cab with the engine behind the cab than the rogator. Is there anything special to look for on these. It has the stainless tanl and 90 foot booms. It looks like a pretty nice unit. Thanks
CaseFarmer
Posted 11/24/2009 06:32 (#936104 - in reply to #936038)
Subject: RE: Case IH spx 3200 sprayer questions
Flora IL
I. Had some neighbors who ran both and I'm pretty sure remembering them saying it was the same or a bit better in the case on noise level. What motors on those? I made fun of those on here once and had 8 guys inform me while not as great as the engine in back they are damn good sprayers lol. So learned a lesson there!! Good luck
joeb
Posted 11/24/2009 07:24 (#936137 - in reply to #936104)
Subject: Re: Case IH spx 3200 sprayer questions
West TN
They are pretty good sprayers. Don't think you would be disappointed at all. We have an 01'. Only think to check is the trailing arm pivot at each wheel. If they are not greased regularly it will wear through the bushing and eventually into the cast. If they are worn, the wheel will appear to be leaning in a little. Engine is a 5.9 Cummins, so no problems there. Don't know about the noise on a rogator, but we traded in a jd6500 and the Case is much quieter.
Delmarva Ag
Posted 11/24/2009 08:10 (#936181 - in reply to #936038)
Seaford, Delaware
Lot's of them here as we have excellent dealer support. All of my customers that run them really like them.
Alan
sprayguy
Posted 11/24/2009 08:40 (#936212 - in reply to #936038)
I had a 2004 model 1000 gal stainless, 90' booms, no active suspension, 5.9 cummins. There is absolutely nothing wrong with those sprayers at all other than they are now starting to get some age on them. If the one you are looking at has been well taken care of I wouldn't be scared of it at all.
The noise in the cab is certainly loud but no louder than the 54 series rogators I've been around. The cab is small by todays standard and certainly primitive but you aren't paying Cadillac prices either. Overall they are pretty good sprayers.
Oh forgot to add, they use an odd in tank hydraulic filter, believe it is Italian and can be kind of a pain. Make damn sure you keep the oil clean...I mean CLEAN.
blue collar
Posted 11/24/2009 18:45 (#936737 - in reply to #936038)
Manitoba
We had a 2001 3200B sprayer, and it gave us enough electrical problems with the flow meter and regulating valve. Also the banjo valves on the booms all shorted out but they fixed that right away so that shouldn't be a problems. we had a dickey john monitor which was terrible. get a raven.
