| Have a heater that runs great for 10 minutes or so and then the push button kicks out. Wait a minute or so , push button and it starts right up.What do think the problem is and how do I fix it? dean this heater is running on kerosine |
Windom, MN | FAN MOTOR GETTING HOT???? BAD CAD-CELL EYE??? |
Wolcottville,Indiana | Hi Dean I have an old one that has a little square air filter that plugs.
My one ct Chuck |
nw pa | Could be the fuel filter. most have a screen that goes into the tank under the siphon tube. Works till it builds up and then kicks out . old ones would just run with no heat. Pull the drain plug on the tak while your doing it and add a quarter can of dry gas to the tank when you refill. |
NESD | Is the flame going out before the reset trips or is it burning good at the point where it trips? It could be a fuel problem, the flame sensor, ignitor, fan motor, air pump, any one of these will cause the reset to trip. |
