Search Forums | Classifieds (35) | Skins | Language
Looking at Kubota M7-151
BlkDmdFrms
Posted 6/6/2026 21:05 (#11667331)
Subject: Looking at Kubota M7-151
Southeastern Indiana
Anybody have any experience with these tractors? Looking at one with around 1600 hrs and didn’t know how they were holding up. Would be pulling a planter and a 500 bu grain cart, replacing a JD 4440
redblooded
Posted 6/6/2026 21:12 (#11667346 - in reply to #11667331)
Subject: RE: Looking at Kubota M7-151
Shelburne Ontario Canada
Around here they have proved not so faithful. Many have bin switched out to something else again. Love to burn, cab fan/wiring burning issues, pto /4wd soleniods for 1500$ , powershift bang and jerk around, cvts the shaft to the diff pot something lets go. Now lately heard few broke eng cranks wat ever that means
Dirtman1
Posted 6/6/2026 21:19 (#11667356 - in reply to #11667331)
Have had one for about 6 years. Mostly an auger tractor for us. Over 2000 hrs now, has had a few electrical problems. When compared to large frame tractor it is quite a bit rougher in ride quality. It replaced a 4430 for me. Nothing fancy and it does exactly what we were looking for but as I said it was bought to be a higher horsepower auger tractor. We’re mostly red and I would have preferred a Case IH Maxxum 150 but at the time the Maxxum was $40 higher than the Kubota.
Fingers77
Posted 6/6/2026 22:12 (#11667406 - in reply to #11667331)
We have an M6-131 with north of 4k hours as a mower tractor.
It was not loved it's first 4k hours, but we've nursed it back, it was in a Florida orchard. You can imagine the pristine condition it was in.
Parts are expensive vs other brands and NEVER in stock locally because there just aren't many around.
January a year ago Kubota shut off world wide parts for iirc 2 weeks for inventory.
Now it's sitting with milk in the trans waiting til Monday for a fluid change.
Need to figure out how water is getting in now, a new problem.
The trans and steering started to act up as our first sign.
It's most likely (justified or not) the first AND last Kubota here.
Its nice enough, just a bit of a problem child.
Angus8335
Posted 6/6/2026 22:56 (#11667433 - in reply to #11667331)
Galena IL
A 4440 is around 160 pto hp so you need to be about 195 flywheel hp to be the same…. Dennis
Fawazhay
Posted 6/7/2026 01:45 (#11667466 - in reply to #11667331)
Northern CA
We bought an M7-172 with 400 hours last year because the price was very right. We had to put a DEF injector in it last month. If it had happened last year, warranty would have covered it. It probably has the best a/c of any tractor we have, and that counts two R series tractors as well. I think it will work fine for what we ask of it. I wouldn’t want to over work it. Ours is power shift and manual hydraulic levers. I think the first series was one to avoid.
thefarmers
Posted 6/7/2026 02:27 (#11667470 - in reply to #11667433)
4440 is 130 pto hp.
Jschnur79
Posted 6/7/2026 06:49 (#11667512 - in reply to #11667331)
We have the 171 it works well for planting and pulling a 750 grain cart. Been good ours is a standard model powershift. Rides rough on the road ,doesn't use much def. I feel they are a good tractor for the price range. They did update the circuit board a little in the cab because if water gets on it gets fried. We had a little water get in the cab where wires go in from planter while pressure washing meaning only a few drops. Don't let that scare you i make sure I lay a towel in the cab and around the wires to prevent it now.
Lauritsenag
Posted 6/7/2026 07:27 (#11667548 - in reply to #11667331)
I have an M-7-171 bought with 40 hours on it. Loaded, KVT, suspension, etc. Had a couple recalls and the def header was replaced when I got under recall, replaced again at almost 5 years, still under warranty. Supposedly they have an improved one as all the Kubota's (tractors, skidsteers) use the same def header. I'm at 1800 hours. would I buy another, yes, it was $45K cheaper than a stripped down NH T7. There are quite a few in my area as we do have a fantastic dealer. A good friend has a 172 Deluxe with over 4000 hours, spending its life on a baler. According to neighbors with the electrical and def problems with their R series Deeres, I'll take the Kubota.
(20240418_143820 (full).jpg)
Attachments 20240418_143820 (full).jpg (115KB - 19 downloads)
BlkDmdFrms
Posted 6/7/2026 10:17 (#11667756 - in reply to #11667548)
Thanks for the replies!
