| Hauling wheat with new to me IHC 9100 tandem truck.
good airflow, engine is 180 on the gauge but i am freezing aroend 5 F outside.
TIA Nik |
Jeffersonville, OH | Heater valve shut off at the lines on the engine?
Sometimes has 2 on the engine in trucks, sleeper trucks can have more. Some of ours have 1 at each port on the block, inlet and outlet both.
Chris |
| Heater Core Stopped Up? Line Frozen? What C Meyer Said! |
 southwest Missouri | Heater hoses warm to bare hands back @ Firewall?
That’s problem w these ol farm trucks. No Winter heat. I have Ford 9000 same way. No heat in winter |
| Heater box is under passenger seat. Remove seat and cover might have a cable not actually moving a blend door. Definitely check the valves like others have said. I believe there is a cable operated valve inside that heater box.
Edited by Paystar5000 1/7/2025 12:20
NW Iowa | Heater core full of wheat chaff? |
WCIL | That would be my first check |
northwest IL Lee Co | I had this problem. Cable was bent right at the gate valve. |
ND | Put a weather front on the outside radiator grill. I did that on my Freightliner & it helped much or radiator fluid is too low. |
WC mn | Start with the heater valves on the engine and then remove passenger seat to be able to watch the blend door actually move. |
NC Indiana | My 9600 and 9700 has the heater under the passenger seat. My problem ended up being the valve the control cable hooked to. It is down at the bottom of the compartment. The cable moved the arm but the crimp holding the arm to the valve shaft slipped. Need a helper to run the control while you watch to see if the valve shaft turns with the arm. Had to replace the valve assembly. |
| Doors are moving freely,tomorrow things will warm up so
i will dig further into it.
Thanks for the reply's
Nik |
