Search Forums | Classifieds (107) | Skins | Language
other new idea uni system uses?
mountain_anderson
Posted 12/4/2024 22:11 (#10996045)
Subject: other new idea uni system uses?
Northampton County, PA
Hi all
I know the uni system can pick corn, harvest grain, harvest different forages, and even blow snow, but are there other uses for this machine? I know thats a lot to ask from a machine that is already universal enough but I have seen multiple mounted with planters, and even the early MM with the baler and manure spreader, from what I gathered, they arent interchangable with the new idea equipment, but if so, is it possible that they can be rigged to do with same? What other ways of using these machines have any of you come across?
CaseIH2388
Posted 12/4/2024 23:04 (#10996096 - in reply to #10996045)
Subject: RE: other new idea uni system uses?
Strasburg North Dakota
Local CHS coop has a fleet of these for cleaning up grain piles.
Edited by CaseIH2388 12/5/2024 12:36
(B7FC7272-AA08-455B-A4F5-F59CFF325C05 (full).JPG)
Attachments B7FC7272-AA08-455B-A4F5-F59CFF325C05 (full).JPG (79KB - 23 downloads)
nyjim
Posted 12/5/2024 02:54 (#10996121 - in reply to #10996045)
100 miles north of the NYC crapper
They could definitely have been used to aggravate the operator
Mark (EC,IN)
Posted 12/5/2024 05:36 (#10996153 - in reply to #10996045)
Schlegel Farms, Hagerstown Indiana
New Idea purchased the Minneapolis Moline "Mule" and turned it into the Uni-System.
Same idea but many changes and, no, the units would not interchange.
There was also a combine, and maybe other units also.
A Google search turns up several results on them:
https://www.google.com/search?q=new+idea+uni+system&rlz=1C1CHBD_enUS...
Posted 12/5/2024 05:53 (#10996160 - in reply to #10996045)
We took a 708 power unit (cold-blooded Perkins diesel, hydrostat), modified it and added a 1000 gal tank and a 45' JD front fold boom. Actually it was a rear fold boom, but we were running it backwards. We ran it for several years until switching to a Hagie. I think we actually built it in '88.
We had to make custom wheel centers for the 18.4 x 38 tires. Had to machine a drive hub that would drive a large diameter v-pulley to spin the spray pump fast enough. Modified the rear axle to fit down 30" rows. Added a hitch to the back so the sprayer could pull it's own nurse tank down the road.
Frank Lessiter wrote an article about it in No-Till Farmer back in '91. The machine in the upper RH & lower RH is ours. 2nd half of the printed article.
Also, a local grain elevator mounted a conveyor on one for loading off of a corn pile.
(Uni article (full).jpg)
Attachments Uni article (full).jpg (312KB - 26 downloads)
DBindiana
Posted 12/5/2024 06:08 (#10996171 - in reply to #10996045)
West Central Indiana
Several around here clean up ground piles of corn at the co-op elevators. They have a gathering head like a snow blower on the front and bring the corn in and on to a conveyor that's high enough for a semi to pull under. I used to haul for Cargill and have hauled a crap load of grain this way. Could load in about 2-3 minutes.
Chuck
Posted 12/5/2024 06:31 (#10996201 - in reply to #10996045)
Wolcottville,Indiana
I seen a couple of uni systems with rock pickers made out of them, Rock rake in the lead to a turning drum that cleans the dirt out to a conveyor like ear corn to a hydraulic dump wagon, they could clean a field in no time.
Pvafarm
Posted 12/5/2024 06:32 (#10996204 - in reply to #10996045)
Southeast WI
Best use - scrap pile.
hankster1966
Posted 12/5/2024 06:38 (#10996210 - in reply to #10996204)
Manola,Ab, Ca
I’m pretty certain that this peat harvester is based off the unisystem.
(IMG_0298 (full).jpeg)
(IMG_0299 (full).jpeg)
Attachments IMG_0298 (full).jpeg (111KB - 25 downloads)
Attachments IMG_0299 (full).jpeg (105KB - 23 downloads)
cardinal farms
Posted 12/5/2024 06:42 (#10996213 - in reply to #10996045)
Central Iowa
Many years ago there was a farmer in Iowa that mounted a 4 row John Deere planter on the front of a Uni and planted with it.
Dave9110
Posted 12/5/2024 06:53 (#10996230 - in reply to #10996160)
north-central Indiana west of Fulton
That’s pretty neat Ron, what happened to it…. I don’t suppose you still have it?
prmckay220
Posted 12/5/2024 07:14 (#10996259 - in reply to #10996045)
Lone Wolf Ok
Had one with home built 2 row cotton stripper - including a basket
exdairyguy
Posted 12/5/2024 07:30 (#10996286 - in reply to #10996171)
swmn
(IMG_20160322_090724812 (full).jpg)
(IMG_20160322_090718986 (full).jpg)
(IMG_20160322_090459375 (full).jpg)
Attachments IMG_20160322_090724812 (full).jpg (155KB - 23 downloads)
Attachments IMG_20160322_090718986 (full).jpg (253KB - 24 downloads)
Attachments IMG_20160322_090459375 (full).jpg (92KB - 20 downloads)
Jersey Jim
Posted 12/5/2024 07:33 (#10996294 - in reply to #10996259)
Do you have any pictures of it?
1680farmer
Posted 12/5/2024 07:46 (#10996320 - in reply to #10996045)
Pesotum IL
Maybe a self propelled auger cart?
hinfarm
Posted 12/5/2024 08:10 (#10996343 - in reply to #10996121)
Amherst WI
Neighbor had a couple (notice they always have more than one) said if it broke down you might as well drag it into the fence row because you’ll need parts off it next year when your back over there with the other one
gwfeederswi
Posted 12/5/2024 08:32 (#10996375 - in reply to #10996210)
What is a peat harvester? Peat moss? Or peat for potting soil? That is something not seen in Wisconsin
farmerkj
Posted 12/5/2024 08:56 (#10996419 - in reply to #10996213)
Central Wi
Not a uni but I remember reading about this when I was a kid. Planting with his combine.
(Screenshot_20241205_085451_Chrome (full).jpg)
Attachments Screenshot_20241205_085451_Chrome (full).jpg (203KB - 23 downloads)
dngrabs
Posted 12/5/2024 09:07 (#10996438 - in reply to #10996213)
CWI
You sure that isn’t from a Dr. Suess book?
junk fun
Posted 12/5/2024 09:27 (#10996463 - in reply to #10996375)
Wisconsin
Yes, peat is dried and used for potting soil, or burned for energy in some places, that's why they want to suck it up, to only get the driest stuff off the top of the deposit. It's basically the same stuff that the Irish dug and dried as "turf".
Historically at least, there was Spagnum peat moss harvested in WI, that was the live plant raked up and dried. Peat moss can be thousands of years old plant matter, of all sorts.
German Shepherd
Posted 12/5/2024 09:29 (#10996465 - in reply to #10996419)
I remember that story well.  I thought it was ridiculous to put a bunch of hours on a new combine when a $10,000 tractor at that time would work just as well.   The farmer even admitted in the story that NH would most likely not warranty the hydro because he used it for planting.
alnciowa
Posted 12/5/2024 09:31 (#10996471 - in reply to #10996045)
nw/nc iowa on the banks of West Buttrick Creek..
Local tiler has worn out several pushing a BrownBear? Tile ditch closer, probably did a million miles.
hankster1966
Posted 12/5/2024 09:33 (#10996473 - in reply to #10996375)
Manola,Ab, Ca
Yes it is used to harvest peat for sale. They work the top surface with harrows to loosen it and dry it out and then use vacuums to gather it and then dump in piles. It is then loaded onto walking floor trailers to be transported to plants that bag it and also make garden mix and potting soil. It’s actually a big business up here.
ihmanky
Posted 12/5/2024 12:30 (#10996720 - in reply to #10996419)
KY
farmerkj - 12/5/2024 08:56 Not a uni but I remember reading about this when I was a kid. Planting with his combine.
Cannot for the life of me make any sense out of this one. Maybe someone else can make a case for the advantage here, but I sure can't find one.
German Shepherd
Posted 12/5/2024 13:04 (#10996759 - in reply to #10996720)
Like I said above, I remember the story well.   The farmer was bragging about not having to get a planter tractor and that the harvesting portion of the machines always wore out before the drive parts so he was maximizing efficiency.   Plus he didn't have to look back to see the planter.
I'm sure I remember it so well because I thought too it was the dumbest idea any farmer ever came up with.   And yes it was a new  or nearly new combine.
966Hydro
Posted 12/5/2024 14:35 (#10996846 - in reply to #10996045)
Central Maryland
Not mine. Saw it at an auction.
(IMG_6344 (full).png)
(IMG_6343 (full).png)
Attachments IMG_6344 (full).png (79KB - 21 downloads)
Attachments IMG_6343 (full).png (68KB - 19 downloads)
Excalibur
Posted 12/5/2024 16:09 (#10996937 - in reply to #10996045)
SC WI
I didnt read all the replies, but there was one around the area with a snow blower on it. I heard the original use was to load corn piles into semis.
ihmanky
Posted 12/5/2024 17:31 (#10996995 - in reply to #10996759)
KY
German Shepherd - 12/5/2024 13:04
You happen to recall if he used it for awhile? If he used it one season and then switched to a tractor I’d be satisfied that he wound up thinking it as senseless as the rest of us, but if he used it for a pretty good while, well that’d be downright interesting to me.
Luckyman
Posted 12/5/2024 17:56 (#10997026 - in reply to #10996160)
Morgan Co. Illinois
Interesting that both you and the Hillerman's didn't want to tie up a $25 thousand dollar tractor and look what we spend today. Thanks for the flashback.
Posted 12/5/2024 19:33 (#10997195 - in reply to #10996230)
Dave
Thanks!
No, don't have it any longer, we sold it when we replaced it with a Hagie 254 several years ago. But, it served us well for a few years. We gained more ground clearance by going to the 38" tires, and road speed!
jdbob8100
Posted 12/6/2024 11:43 (#10998015 - in reply to #10997195)
ND
Our township bought a New one back in the past with the V6 Gas engine a real dog & had a 9' double auger snowblower on it. Pretty slow as she goes outfit.
mountain_anderson
Posted 12/6/2024 22:34 (#10998795 - in reply to #10996045)
from what it seems like online, there werent too many open station uni-systems? is this sort of a rarity?
Excalibur
Posted 12/13/2024 20:32 (#11008453 - in reply to #10996121)
SC WI
Found pic
(IMG_1654 (full).png)
Attachments IMG_1654 (full).png (34KB - 17 downloads)
