Shoup clean grain elevator chain
exdairyguy
Posted 8/18/2024 15:24 (#10856381)
Subject: Shoup clean grain elevator chain
swmn
This is for a 9660 Deere. Thinking I get to make a call in the morning. Old chain has 35 paddles new one only 34 with one missing in the middle.
(PXL_20240818_202056948 (full).jpg)
Attachments PXL_20240818_202056948 (full).jpg (274KB - 12 downloads)
Nodak63
Posted 8/18/2024 19:04 (#10856660 - in reply to #10856381)
Subject: RE: Shoup clean grain elevator chain
NE ND
I had the same thing with a 9600. Called and asked, the extra spot is for a moisture or yield sensor or something. It needs an open spot for the reading I think I don’t really know.
I put it in and it works just fine. That was probably 3-4 years ago and it’s still working fine.
silofarms
Posted 8/18/2024 19:25 (#10856686 - in reply to #10856381)
NE Iowa
Supposed to be that way for the yield sensor I was told. New chains from john deere are the same way.
GcDm2010
Posted 8/18/2024 20:01 (#10856737 - in reply to #10856381)
SOIL
I've had bad luck with Shoup elevator chains wearing out faster than Deere OEM. Lost paddles, worn chains after only two years.
SteigerSt320
Posted 8/18/2024 20:59 (#10856824 - in reply to #10856737)
Northeast Louisiana
I don’t remember having the gap in mine. Actually, I have had good luck with Shoup elevator chain/paddles. But, I think it was made in USA at the time.
Edited by SteigerSt320 8/18/2024 21:00
gbryce
Posted 8/18/2024 21:16 (#10856860 - in reply to #10856381)
West-Central Missouri
You might make sure they put locknuts on those paddles. I had one from them without and paddles started coming loose.
exdairyguy
Posted 8/18/2024 21:21 (#10856867 - in reply to #10856860)
swmn
Yes that was today's job, noticed a couple of them weren't tightened up all the way. Was going to run a ratchet over them all.
Next stop Valhalla
Posted 8/18/2024 23:34 (#10857029 - in reply to #10856860)
NE Neb
Agree just as well start with nylon lock nuts if you don't have them. I don't know where they bought thier lock nuts at but they suck.
