Search Forums | Classifieds (153) | Skins | Language
Rapidan Dam Breached
greenandyellow
Posted 6/24/2024 08:37 (#10785527)
Subject: Rapidan Dam Breached
South Central Minnesota
Blue Earth County MN. Downstream being evacuated.
(Screenshot_20240624_083423_Snapchat (full).jpg)
Attachments Screenshot_20240624_083423_Snapchat (full).jpg (140KB - 171 downloads)
tmrand
Posted 6/24/2024 08:58 (#10785551 - in reply to #10785527)
Subject: RE: Rapidan Dam Breached
Southeast Colorado
I googled that dam to get an idea of the location.
Ironically a January 2023 story popped up about how the dam had no threat of giving away.
white shadow
Posted 6/24/2024 10:34 (#10785667 - in reply to #10785527)
East Central South Dakota
More acres of river bottom land on the Minnesota river from Mankato to the twin cities will be lost. Sure hope the traders don't get wind of it, corn will drop another nickel.
Working in the city
Posted 6/24/2024 11:12 (#10785701 - in reply to #10785527)
S MN
Just heard the dam partially gave way now!
jd8850
Posted 6/24/2024 11:18 (#10785713 - in reply to #10785667)
Roseglen, North Dakota
Only a nickel?
paul the original
Posted 6/24/2024 11:35 (#10785731 - in reply to #10785701)
southern MN
Oh no. That’s pretty close.
Paul
junk fun
Posted 6/24/2024 11:38 (#10785737 - in reply to #10785701)
Wisconsin
There's helicopter footage on youtube from the last half hour, looks like the spillway cut down to bedrock. Or maybe there was no spillway? there is one now! The concrete dam itself was intact in the footage, with sunny weather. This has been going on since last night, if it was going to fail it probably would have by now.
MattNWOH
Posted 6/24/2024 11:54 (#10785757 - in reply to #10785737)
Water cutting around a dam is still definitely a dam failure.
CMN
Posted 6/24/2024 11:55 (#10785760 - in reply to #10785701)
West of Mpls MN about 50 miles on Hwy 12
https://www.youtube.com/watch?v=3ySM1CvogFg
https://www.youtube.com/watch?v=Llrsb3yWvQg
Edited by CMN 6/24/2024 12:04
junk fun
Posted 6/24/2024 12:09 (#10785777 - in reply to #10785757)
Wisconsin
Yes, it's a failure, and the "spillway" was the substation, so probably the end of the dam, but that will be a political decision, not a collapse or failure of the dam structure itself. Looks like a built up earth approach to the dam that went.
D6Joe
Posted 6/24/2024 12:35 (#10785815 - in reply to #10785527)
east central ND
I wonder how much flow, threw the dam “gatesl, was blocked by the trees and other debris?
J.Rabbit
Posted 6/24/2024 13:07 (#10785861 - in reply to #10785527)
https://www.youtube.com/watch?v=D3MM6o2lUZI
The power of water amazes me, watch as the bank erodes. A tree falls in at the 3:30 a house is in jeopardy.
paul the original
Posted 6/24/2024 13:09 (#10785863 - in reply to #10785815)
southern MN
It’s a bit of an oddity, as there is no lake behind it. The rivers here were formed by glaciers melting off, these rivers near the Minnesota River are cut down into mini versions of the Grand Canyon, very narrow.
So they walled off a canyon area to make electricity in the very early 1900s. Give enough fall for the turbines. But it didn’t create much of a body of water behind it, stacked the water up vertically.
The good news if the dam fails, or just continues to wash out the side, there isn’t such a huge volume of water behind it as a normal dam that creates a large lake.
The bad news is that the dam has had lots of trouble over the past years because it needs to react immediately to any river flow changes. There is no real buffer behind it. What comes in needs to flow out.
They have been pondering a study upon study since 2019 whether to repair/ restore the dam for $18 million or remove it for $82 million.
Looks like they might not need to continue the study.
Paul
Crophugger2.0
Posted 6/24/2024 13:35 (#10785892 - in reply to #10785861)
Keep pouring concrete it’ll get worse
junk fun
Posted 6/24/2024 15:18 (#10785965 - in reply to #10785861)
Wisconsin
The video says the dam failure, assuming complete failure, would raise downstream water levels only 2'. Didn't specify how far downstream, assuming the next large city. Looking at the flood footage and the before pics of the dam, the downstream water is up 20-40' compared to normal flow.
paul the original
Posted 6/24/2024 17:18 (#10786081 - in reply to #10785965)
southern MN
Mankato, 12 miles downstream, had terrible flooding in the 60s. They built a pretty expensive levee in the 70s. It has been tested in the past decade to about 30 feet. Which it probably will get to now.
They are comfortable holding back a flood of 32 feet. They should be fine within that unless something else happens here. There was a thunderstorm just went over them again.
There are provisions with a wall on top of the levee to handle 39 feet of river, but there is some head scratching if that will all work as planned. It looks good on paper, but I’d not want to be on the back side of that thin wall on that tall levee with that much water pressure on it. At the least they need to shore up a lot of bits here and there if the river ever got that high.
More and more roads are closing in southern Minnesota, under water, as the rain water moves into the streams and rivers. State roads, 4 lanes, big roads. This isn’t so much the dam, it is the widespread rain we got for several weeks.
Paul
