Adding air conditioning to a truck
harleyrider24
Posted 5/19/2024 13:04 (#10744749)
Subject: Adding air conditioning to a truck
mn
Has anyone had good luck adding ac to a vehicle. I've got a ford f800 that I built into a hotbatch spray tender that I'd really like to add it to. Looking online theres kits from 500 to over 2500. Just wondering if anyone has any practical experience before I go too far down this rabbit hole.
Thanks
tommyw-5088
Posted 5/19/2024 13:14 (#10744756 - in reply to #10744749)
Subject: RE: Adding air conditioning to a truck
Texas
Get on dtac.com
Look around a little bit .
IHC 1470
Posted 5/19/2024 15:08 (#10744823 - in reply to #10744749)
Idaho
I did it several years ago on a couple Loadstar 1600 truck. The evaporators I got off EBay something like use on hot rod cars. Compressor mounts were from Scouts. The condensers I just went to the local wrecking yard and pulled a couple that were the right size for the radiator. York compressors and they came from the wrecking yard too.
Sure I had to fab up brackets to mount the evaporators and condensers but not a big deal. New hoses custom made to fit. Systems have been trouble free and have been going for at least 24 years now. Biggest cost was the evaporators. I might of had $300.00 total into the systems and doubt it was that much.
Or you couple mount a unit on top of the cab. I still have a couple those kicking around they contained everything in the unit all you would need to do is run hoses to the compressor.
farmwithjunkrrv
Posted 5/19/2024 16:03 (#10744852 - in reply to #10744823)
South west of Winnipeg MB
https://www.dtac.com/
ccjersey
Posted 5/19/2024 16:38 (#10744877 - in reply to #10744749)
Faunsdale, AL
Red Dot units are a simple install vs disassembling the air box and dash to install an evaporator
You do have to cut the cab to install so I guess you have to pick your poison!
https://www.reddotcorp.com/
SteigerSt320
Posted 5/19/2024 17:36 (#10744917 - in reply to #10744877)
Northeast Louisiana
Depends on how redneck you want to go. I have talked to guys that have done this, they said it actually works great. Either put on a larger converter to run off truck battery when working or use a harbor freight generator when parked.
(IMG_1412 (full).png)
Attachments IMG_1412 (full).png (48KB - 60 downloads)
1972RedNeck
Posted 5/19/2024 19:33 (#10745008 - in reply to #10744749)
Townsend, Montana
Red Dot roof top all in one unit. Mount the unit on top of the cab, add a compressor to the engine, run 2 lines and a couple wires and you're good to go.
farmwithjunkrrv
Posted 5/19/2024 22:02 (#10745178 - in reply to #10744917)
SteigerSt320 - 5/19/2024 17:36
I did that on my sprayer truck. Ran it with a polaris inverter it only run as fast as need to to keep the a/c working didn't use much gas.
5105
Posted 5/19/2024 22:03 (#10745181 - in reply to #10744749)
We put some Red Dot kits on our manure trucks, mounted to the back wall of the cabs. Kits had new condensors, compressors, mounts for given engine, coil of hose, and fittings. Had my hyd hose guy crimp the ends. One power wire, one ground wire was it. Super simple, would freeze guys out of the cab on 100 degree day, was very happy with them.
