Search Forums | Classifieds (167) | Skins | Language
9rx Cummins 15l
ilikegolfguy
Posted 5/9/2024 16:33 (#10734734)
Subject: 9rx Cummins 15l
Velva, ND
Has anybody gotten this warning? Deere replaced internal injector, checked pressures and sensors, capped new injector and are saying the dpf is still getting too much fuel which leads to full engine injector replacement and lines. Wondering if anybody out there has had similar.
Edited by ilikegolfguy 5/9/2024 16:35
(73638405491__DB5D380C-2272-45F0-81C6-738019AEB560 (full).jpeg)
Attachments 73638405491__DB5D380C-2272-45F0-81C6-738019AEB560 (full).jpeg (106KB - 32 downloads)
John.jr
Posted 5/9/2024 23:33 (#10735178 - in reply to #10734734)
Subject: RE: 9rx Cummins 15l
Fancy prairie, Illinois
I'm not familiar with that code in trucks, I would make sure all of the temp sensors in the aftertreatment give a close relative temperature to each other after sitting overnight. Biased temp sensors are far more common than bad injectors.
c_mayer
Posted 5/10/2024 07:10 (#10735305 - in reply to #10734734)
Jeffersonville, OH
Saw that on a QSX12 in a 405 Versatile, the SCR catalyst had plugged up with crusty DEF at the bottom of the inlet.
We took everything apart before that at one time or another, cleaned the DPF, changed the turbo valve actuator thinking it was going closed under load, etc. Thing sounded like it was under load all the time, and the exhaust sounded "off." We finally had enough, and realized that it didn't seem like it had enough exhaust coming out the top of the stack...on the Versatile, there's a pipe that comes off in about 2 minutes from the the DPF under hood out to the SCR/muffler on the fender, so popped that off, our noise went away, and our tractor had full power again with no codes.
Our fix probably wasn't Cummins or Versatile approved, but the tractor hasn't been back in the shop for 500 hours so far.
Took the pipe off the inlet to the SCR, and wedged a 32oz paint mixing cup in there, which was the perfect plug. Then I took the wand off the hot water pressure, cranked it to steam, and stuck it in the SCR outlet at the top of the stack. Once it filled to about halfway, we pulled the plug and flushed out the bottom. Did that twice, stuck the exhaust back on it fast, and put it on the dyno to cook the water out.
That was last spring, finished spring, ran fall, and another spring now without issue.
Chris
Edited by c_mayer 5/10/2024 07:14
