Search Forums | Classifieds (115) | Skins | Language
International 140 plows ?
Lawrence505
Posted 11/16/2022 07:30 (#9934374)
Subject: International 140 plows ?
I am thinking of purchasing some plows. A neighbor has IH 140 plows is good condition ? He has a 3 and a 4 bottom. My tractor is 120 hp 4x4. I was thinking Of getting the 4 bottom and if my tractor can’t pull it take the last plow section off? $1300 for either set. Opinions ?
Edited by Lawrence505 11/16/2022 07:43
(6084CBF2-4667-401A-94EB-300AF5F92213 (full).jpeg)
(1CF3AC4C-2286-4F5D-8C27-1F5547A3E8F8 (full).jpeg)
Attachments 6084CBF2-4667-401A-94EB-300AF5F92213 (full).jpeg (285KB - 255 downloads)
Attachments 1CF3AC4C-2286-4F5D-8C27-1F5547A3E8F8 (full).jpeg (175KB - 234 downloads)
johnny skeptical
Posted 11/16/2022 07:31 (#9934378 - in reply to #9934374)
Subject: RE: International plows ?
n.c.iowa
Plow model?
Lawrence505
Posted 11/16/2022 07:43 (#9934414 - in reply to #9934378)
140
BBfarms
Posted 11/16/2022 07:45 (#9934419 - in reply to #9934374)
SE Michigan
120hp should easly handle a 4 bottom. Just a quick look at Tractorhouse, $1300 is about 1/3 of the asking price for a 140 4 bottom. I was going to post that sounded a bit high ($1300) but seems like a good deal now
Lawrence505
Posted 11/16/2022 07:47 (#9934425 - in reply to #9934419)
I just saw that also. I am gonna jump on it. I don’t know if they are good plows though
Edited by Lawrence505 11/16/2022 07:47
AR Plowboy
Posted 11/16/2022 08:00 (#9934459 - in reply to #9934374)
Subject: RE: International 140 plows ?
East Central Arkansas
I don't know the model number of our IH plow that looks real similar to that 4 bottom. Ours has 16 inch bottoms and we used a old JD 4520 or a IH 1066.
pointrow
Posted 11/16/2022 08:10 (#9934481 - in reply to #9934374)
Central Il Morton
Don’t know anything about a 140 plow but don’t plows in your area use coulters?
Looks like it has good clearance.
take care
pointrow
KFLAgri
Posted 11/16/2022 08:17 (#9934490 - in reply to #9934374)
I have nothing to add but man I wish we could get away with a plow without spring reset here. With our stones and boulders that plow would be in pieces before you even got to the back of the field.
Badger
Posted 11/16/2022 08:19 (#9934495 - in reply to #9934374)
Huntley Montana
The value is about right . they were good plows,  4 bottom will pull as easy as the 3.  You can make a 3 out of the 4, bit you can not make the 3 into a 4.
Only problem is they were not quick hitchable.
watched a lot of acres go through
Edited by Badger 11/16/2022 08:22
BBfarms
Posted 11/16/2022 08:40 (#9934541 - in reply to #9934425)
SE Michigan
Offer $2000 for both. Not sure about parts availability(?) In my part of the world, roll over plows are very rare
cah
Posted 11/16/2022 09:09 (#9934605 - in reply to #9934374)
Western Nebraska
Excellent plows. Grew up using them. Good trash clearance.
Efberry
Posted 11/16/2022 09:18 (#9934618 - in reply to #9934374)
Hp isn’t an issue but you’ll need weight. Our 6715 never has power issues but drop our 3/18 Massey in as deep as it’ll go and it’ll slip a lot. Course most people only plow 8-10” deep
high crop
Posted 11/17/2022 10:18 (#9936400 - in reply to #9934374)
VT
You'll have no problem with the 4 bottom, unless your dry soils pull unbelievably hard and you insist on trying to plow too fast and too deep. I believe those are Super Chief bottoms so parts are readily available, even for the LH shares.
As someone above said, I'm also jealous that you can plow without trip bottoms!
WCWI
Posted 11/17/2022 19:36 (#9937206 - in reply to #9936400)
If that tractor will not pull the 4 bottom, better be looking for a different tractor!
