Horse drawn or gas powered hay baler?
Ceasar
Posted 7/3/2009 13:21 (#764417)
Subject: Horse drawn or gas powered hay baler?
Is there such an implement, if so, are they still manufactured? I want to bale square bales with draft horses. Thanks!
ohoh
Posted 7/3/2009 13:28 (#764419 - in reply to #764417)
Subject: RE: Horse drawn or gas powered hay baler?
lot of asmish run them. just need power cart.
Ceasar
Posted 7/3/2009 13:30 (#764420 - in reply to #764419)
Would you know where I could buy one?
Joel Harman
Posted 7/3/2009 13:39 (#764434 - in reply to #764420)
Subject: Re: Horse drawn or gas powered hay baler?
N.C. Oregon
Get a baler with a motor. Be aware that when the baler is running without moving foward you are going to hammer their necks. You can use a forecart or extend the tongue of the baler. Most use a forecart.
Gerald J.
Posted 7/3/2009 14:30 (#764491 - in reply to #764417)
Summer before last at a draft horse gathering near Sebeka MN I saw a couple ways to do that. One was a WD Allis with no engine, and shortened. The horses pulled that, and with the transmission in gear their forward motion turned the PTO shaft. I didn't see it in operation. The other scheme at that show was the standard horsepower with the horses going in a circle with a tumbling rod running the parked baler. There it was catching straw from a threshing machine (run by a vintage tractor).
That was Sunday of the weekend of the power show at Lake Itasca.
Gerald J.
Ceasar
Posted 7/3/2009 14:46 (#764500 - in reply to #764434)
Thanks for the info, who manufactures a baler with a motor?
Plow79
Posted 7/3/2009 14:50 (#764506 - in reply to #764417)
Chilliwack BC
If you can get an issue of the Draft Horse Journal, they have adds for all sorts of stuff like this.
Gerald J.
Posted 7/3/2009 14:56 (#764508 - in reply to #764500)
Most every baler used to be available with that option. Typically it was a 2 or 4 cylinder engine, if 4 often a Wisconsin V-4 belted to the flywheel. Usually three or four V belts. No grooves on the flywheel. JD two cylinder engines were from the 320 or 420 tractors, I think. A small car engine, like a flat VW or VW Rabbit 4 cylinder inline would work, I think. Even diesel. Probably needs less that 20 hp, Northern tool has a selection of horizontal shaft engines as does Burden's Surplus Center at Lincoln, both gas an diesel.
Gerald J.
Joel Harman
Posted 7/3/2009 15:09 (#764518 - in reply to #764491)
N.C. Oregon
Hate to try & back that.
I always wanted to bale with my horses but the 14T needed too much futzing to ask 4 horses to stand & not try to eat.
http://www.youtube.com/watch?v=vE-_i6aDc4s This was fun. Did it for 4 or 5 yr. Pulled the bundle wagon for yrs before running the binder.
Gerald J.
Posted 7/3/2009 16:35 (#764550 - in reply to #764518)
Not eat? You gotta fuel your prime movers somehow. I saw a riding horse in town waiting for a parade doing a number on the city hall lawn. Each bite was a big chunk of bluegrass practically eaten to the roots and probably pulled out by the roots sometimes.
As for backing, you have to plan your work I suppose, and not plan to back or to plug the baler. Likely you wouldn't want to roll several mower conditioner windrows together with just a few horses out front. The sudden loads of a slug might cause muscle damage.
I saw a matched 8 black horse hitch that day pulling a field cultivator (in very dry sandy soil) and the first time the driver dropped the field cultivator into the ground 7 of the horses were stalled instantly. The 8th didn't have the traces tight so hardly noticed, but stopped too. Two ranks of four abreast. One up front was along for the walk, until a helper noticed and twitched about its rump after they lifted the field cultivator shovels a bit. The main driver rode on a dolly with a seat. That wouldn't back well either, but I doubt backing that 8 horse hitch without lots of room would worked well either on any implement or long tongued wagon. Not a chance of backing the field cultivator through a door 1 foot wider than the cultivator!
Gerald J.
Iowa Quality Hay
Posted 7/3/2009 17:03 (#764572 - in reply to #764417)
Grabill, Indiana
The Amish Blacksmiths in our area mount a 20 hp Honda motor on balers to run them. If I get a chance I will shoot a few photos of some for you.
Jim
Joel Harman
Posted 7/3/2009 17:09 (#764579 - in reply to #764550)
N.C. Oregon
When they were in harness they were on my time. Eating was bad juju & they knew that.
If I had a baler I did not have to baby so much I would have baled. I did mow & rake with 2. My horses only weighed around 1000# each so it would have taken 4 on the baler.
I backed a 2 way JD plow into my trailer with horses configured 4-up. Does that count?
95h
Posted 7/3/2009 17:35 (#764608 - in reply to #764417)
Kittitas Co. Wa. State
Engine powered balers are all over the place 'here',, yes they're still made. The old wisconson 4 cylinder's are not popular at all.  90% of the engines are Dutcz diesel engines.
WillB
Posted 7/3/2009 17:42 (#764615 - in reply to #764500)
Subject: Massey Ferguson - Diesel powered hay baler
Ontario Canada
http://www.masseyferguson.com/agco/MF/NA/HayForage/1800SRB.htm
Edited by WillB 7/3/2009 17:43
JohnW
Posted 7/3/2009 17:50 (#764621 - in reply to #764608)
Subject: Freeman balers
NW Washington
Freeman balers made in Oregon still use auxiliary engines to power them, but they are not cheap. And as mentioned the Amish have been using engine driven pull type balers for many years.
http://www.alliedsystems.com/Freeman/370pt.htm
Topshot
Posted 7/3/2009 18:19 (#764639 - in reply to #764417)
Near Richmond, IN
They're all around us--all the Amish have them. Some are pretty new too.
FrankTopMO
Posted 7/3/2009 19:11 (#764684 - in reply to #764417)
I just sold a NH 68 to an Amish and he is converting it to ground drive. They already have a JD 14T in the neighborhood.
Jon Hagen
Posted 7/3/2009 19:28 (#764699 - in reply to #764491)
Hagen Brothers farms,Goodrich ND
We had a NH 68 baler with the 2 cyl Wisconsin engine. It worked well in heavy rows, as the tractor could be run in first gear at idle.
I would also be concerned about the balers front to rear surging beating heck out of the horses necks.
ohoh
Posted 7/3/2009 19:48 (#764716 - in reply to #764417)
look in classified on the farmers exchange an indiana farm paper, usually have motor power equopment lot of amish in area.
School Of Hard Knock
Posted 7/4/2009 05:52 (#765056 - in reply to #764417)
just a tish NE of central ND
Id reccomend a tractor for the baler...... use the drafts to pull the wagon loaded with bales and to rake the hay.Maybe use them tom cut it also..
dirtpofarmboy
Posted 7/4/2009 16:59 (#765597 - in reply to #765056)
Good buddy of mine mows and round bales with tractor and the rake with two teams of draft mules one team resting and one team raking. they rake just as fast with the mules as they do with the tractor on problem is the mules wear out hence the two teams where as a tractor just needs fuel. they as bale hay with a pto cart and regular farm implements. pto cart is the way they recommend. they also log with the mules and drafts depending on conditions use a forecart. thats how they pull the rake as well with a forecart.
Redman
Posted 7/4/2009 21:40 (#765817 - in reply to #765056)
Subject: RE: Horse mower
SW Saskatchewan
Is probably the hardest job on the farm for horses. The load isn't heavy but for the sickle to move rapidly and for the cutter bar to be "lively" and windrow the hay with the swath board, the horses have to be traveling faster than a comfortable gait.
This was the reason the JD No.5 mower was so popular, even a little one row tractor (or a big wheatland model, if that was all that was available) could amble along at a nice hay sickling speed. And do it for hour after hour without breaking a sweat those horse killing days in July. Mules could take, but they knew when to quit.
