Search Forums | Classifieds (53) | Skins | Language
JD 4230 vs 4240
SlowandSteady
Posted 8/30/2022 21:37 (#9821891)
Subject: JD 4230 vs 4240
Can anyone go into detail on some of the main differences between the 30 series and 40 series John Deere’s. For example a 4230 compared to a 4240.
kggonzo
Posted 8/30/2022 21:40 (#9821899 - in reply to #9821891)
Subject: RE: JD 4230 vs 4240
Northeast Nebraska and Candelaria Philippines
Better seat and aircon
Buster 50
Posted 8/30/2022 21:42 (#9821905 - in reply to #9821891)
North West IA/western AZ
466 engine
Walton Farms
Posted 8/30/2022 21:42 (#9821906 - in reply to #9821891)
SW Indiana
Hydracushion seat is the biggest thing that comes to mind. A/C seems to work better in 40 series, not sure if it's a bigger condenser? 30 series could have syncro transmission or quad range vs 40 series quad or powershift. 404 cu in vs 466 cu in and 10 gallons more fuel in a 40
mac4440
Posted 8/30/2022 21:58 (#9821932 - in reply to #9821906)
P.S. was available on the 30 series
Walton Farms
Posted 8/30/2022 22:04 (#9821939 - in reply to #9821932)
SW Indiana
Yep you're correct, I missed that
Herbie56
Posted 8/30/2022 22:13 (#9821954 - in reply to #9821891)
Coles County, Illinois
Except for the 4040 which was basically a 4230 with a updated cab and injection pump, the 40 series had better main bearings, higher 3 pt hitch capacity, larger fuel tanks and improved cooling.
Sandcraft
Posted 8/30/2022 22:42 (#9821979 - in reply to #9821891)
South Central ND
Extra lights. Better starting engine with Bosch pump no aneroid. I always found that 40 series cabs were tighter, quieter.
Badger
Posted 8/30/2022 23:46 (#9822010 - in reply to #9821932)
Huntley Montana
Both had 8  speed power shift available  .
Both are fuel hogs without a turbo
Jorn
Posted 8/31/2022 03:59 (#9822054 - in reply to #9821979)
Denmark
The 4240 had a Roosa Master pump.
The later model, the 4240S, had a Bosch pump. Almost unbeliveable improvement.
Mark (EC,IN)
Posted 8/31/2022 05:13 (#9822065 - in reply to #9822010)
Schlegel Farms, Hagerstown Indiana
Badger - 8/30/2022 23:46
Compared to the IH 400 series engine, they were fuel hogs with a turbo also.
jdironman
Posted 8/31/2022 05:36 (#9822082 - in reply to #9821891)
Nw Iowa
40 series always started better. More solid tractor overall.
Trent2520
Posted 8/31/2022 06:22 (#9822124 - in reply to #9821906)
Statesville, NC
40 series could have synchro-range transmission.
TD15
Posted 8/31/2022 06:27 (#9822130 - in reply to #9821891)
Forty series added a hydraulic reservoir up front by the hydraulic pump.
jfg5
Posted 8/31/2022 06:52 (#9822151 - in reply to #9821906)
I had a 4240 with a synco range. Not alot built with it but there were some
Fetv
Posted 8/31/2022 07:01 (#9822168 - in reply to #9821891)
Indiana
40 series is just better
tedbear
Posted 8/31/2022 07:18 (#9822200 - in reply to #9822168)
I agree. Dad had a 4230. Later he traded it for a 4440. That was a great improvement. I'd try to get a 4440 instead.
clevepreach
Posted 8/31/2022 07:19 (#9822202 - in reply to #9821891)
Cleveland, MS. Own small farm near Booneville, MS
The “Iron Horse” series. “More horses. More iron” was the advertising slogan.
seagram
Posted 8/31/2022 07:29 (#9822218 - in reply to #9821891)
ne iowa
Much better differential in late 40 series.
Nate B.
Posted 8/31/2022 07:42 (#9822232 - in reply to #9822124)
Bremen, KS
Interestingly, the manual that came with my 4450 also mentions the Synchrorange as being available in that series as well. Must've been some made but I've not seen one.
WestMIguy
Posted 8/31/2022 07:45 (#9822236 - in reply to #9821891)
40 series had a lot of little updates to them, most of them already mentioned. In my opinion a 4240 would be the one to buy definitely. I know how things work in the real world though, the 30 series received several updates mid production run. If you were to buy a 4230 I would try to find a late production one.
jdbob8100
Posted 8/31/2022 08:35 (#9822296 - in reply to #9822236)
ND
Having a 4430 & a 4640 the Quad is much better in the 40 series, 40's start better , & chassis is beefier. I would however want a turbo vs none in these two models. Not sure what it would cost but getting the 4240 & adding a turbo would help & give you a good edge. Back in the early days farmers added a turbo to a 4010 but that was a stretch but too light a frame.
TP from Central PA
Posted 8/31/2022 09:06 (#9822346 - in reply to #9822065)
You got that right!
IADAVE
Posted 8/31/2022 09:27 (#9822369 - in reply to #9822296)
If you are still tractor shopping the best, and probably cheapest way is to buy a tractor with one.
In other words buy a 4440, since I am spending your money buy a 4450.
All the green ones like fuel.
If you can live with no 540 PTO a 4840 is the best bang for the buck.
One does not have to run it wide open.
Edited by IADAVE 8/31/2022 09:53
Rayl
Posted 8/31/2022 09:49 (#9822400 - in reply to #9821906)
Saline County, Mo
I think a synchro was available in those as well. At least it was on a 4040
Green Acres Guy
Posted 8/31/2022 10:29 (#9822457 - in reply to #9821891)
Latimer, Iowa (north central)
I will go against the usual recommendations a say a 4630, if don’t need the 540 pto, is the Best Buy in soundgaurd tractors. Nice ones will sell for half of a 4440 and definitely not enough differences to justify a paying twice as much. Have had good luck with the powershifts. Make a heck of a manure pump and batwing tractor for the price. 4840s are fine but not as nimble as a 4630.
Jrditchdigger
Posted 8/31/2022 12:46 (#9822643 - in reply to #9821891)
Southern MN
One thing that hasn’t been mentioned yet is 3pt capacity. Believe the 40 series will lift over a 1000 lbs more than it 30 series counterpart. Never thought much about the seat difference until I cultivated in both a 4430 and a 4440 for a couple days each a few years ago. Sold my 4430 for that reason, couldn’t stand a full day in it with my back issues.
Steiger Man
Posted 8/31/2022 17:16 (#9822926 - in reply to #9822065)
Sunburst Montana
Mark (EC,IN) - 8/31/2022 05:13
True but that doesn’t make up for the rest of the tractor:)
eight
Posted 8/31/2022 21:15 (#9823339 - in reply to #9822232)
South Texas
I think they went to Mexico. They also got 86 series IH with no TA.
