Search Forums | Classifieds (93) | Skins | Language
Roundup powermax 3
Ateam
Posted 1/6/2022 20:45 (#9423963)
Subject: Roundup powermax 3
Northeast IN
Bought a shuttle of power max 3. What would be the minimum use rate? All ground will be worked prior to planting. Generally I like to work a bunch early and try to get a rain on the ground before planting so it will have some grasses and possible small weeds before getting sprayed with acuron or lexar equivalent on corn and beans not sure yet for pre residual.
Lambo
Posted 1/7/2022 08:17 (#9424632 - in reply to #9423963)
Subject: RE: Roundup powermax 3
30 oz
Mind me asking what you paid per gallon.
Outdoor Dave
Posted 1/7/2022 08:49 (#9424725 - in reply to #9423963)
SE Nebraska
For grass control, the label says 19 oz
twraska
Posted 1/7/2022 08:52 (#9424736 - in reply to #9424632)
Wallis, TX
Lambo - 1/7/2022 08:17
30 oz
Did they change the rate on the 3? IIRC, that’s a 5# material.
southMN89
Posted 1/7/2022 09:03 (#9424769 - in reply to #9424736)
SC MN
Full rate is 30 oz, lower end rate is 20 oz. and if your are only after grass, I think I would feel comfortable at 20 oz
Iowaoink80
Posted 1/7/2022 10:22 (#9424979 - in reply to #9424736)
swia
twraska - 1/7/2022 08:52
30 oz
I was told its a 5.3lb
dwigg
Posted 1/7/2022 11:56 (#9425225 - in reply to #9423963)
Subject: Product comparison...
NW TX Panhandle
Product comparison:
PowerMax - 5.5# potassium salt, glyphosate (4.5# acid, glyphosate)
PowerMax 3 - 5.88# potassium salt, glyphosate (4.8# acid, glyphosate) + newer surfactant.
Edited by dwigg 1/7/2022 12:08
Ateam
Posted 1/7/2022 12:57 (#9425363 - in reply to #9425225)
Subject: RE: Product comparison...
Northeast IN
I was told for powermax 3 the rates were changed. What used to be 32 oz is now 29. Old powermax I ran 22oz for the low rate which would be 20oz with the new product. As far as cost, I paid sub $50/gallon for a shuttle. Central indiana.
dwigg
Posted 1/7/2022 13:23 (#9425416 - in reply to #9425363)
NW TX Panhandle
Running about $50ish here. Rates on the label have changed.
Ten Man
Posted 6/13/2022 17:49 (#9703672 - in reply to #9425416)
Bonnie IL
Done a search and found this thread. How much water is reccomeneded to run with Powermax 3? Just trying to do some post clean up on weeds and some small waterhemp before itgets to big. Lable is saying 5 to 20 gallon.
