South Central PA | Looking to improve our snow removal capabilities. Looking for recommendations............ a power angle plow or snow blower or just stick with a 6' bucket. Would be using it on a New Holland LS185.B |
Colorado | Depends on what your plowing, all 3 attachements have their place.
I prefer a bucket for a skid, its the most versatile of the 3. When I was plowing a 1/2 mile drive I used a bucket, it required a few more passes and cleanup but it worked fine.
I have a snowblower and rarely use it, my machine is borderline on flow and it just doesnt throw the snow well enough, I dont know what the 185's had for flow but look at that closely before buying a blower. |
| My vote on lower amounts of snow falls would be a angle blade, but they don't work well with deep snow, especially if it get wind packed. A bigger material or snow bucket is my choice, but you have to choose carefully as the visiblity with some brands suck. |
| I never liked a blade on a SS.................Snow with any depth would push the machine around, atleast everything we get here except the fine powder. I like a big material bucket myself, snow pusher is fine if your travel distance isn't long. Every snowblower I seen on a SS hasn't worked that well, but have not got my hands on a high flow version with a high flow machine either. I mean they work, but nothing like one on our 200 hp tractor. |
Driftless SW Wisconsin | Lauritsenag - 12/8/2021 20:59 My vote on lower amounts of snow falls would be a angle blade, but they don't work well with deep snow, especially if it get wind packed. A bigger material or snow bucket is my choice, but you have to choose carefully as the visiblity with some brands suck. The back angle on bigger material or snow buckets is sometimes different from the standard bucket so they are not useful in many std bucket jobs. I had my dealer take it back and supply just the std bucket which I use for snow also. Just a lot of turning and dumping but it works for 2 moderately long driveways. If the snow is very deep I use a rear blade on my bigger tractor and angle it. |
NC KS | A big bucket is the best all around unless you are cleaning off a long driveways with 6-8" of snow on them or less.
I have a 8' bucket on a 6' machine. works great. Mine is actually a Gnuse 3 pt bucket that I put a skidder attachment plate on. Gives me much better piling height. |
East central Indiana | Added bolt on 1 foot extensions to each end of my 7 foot bucket Big help. |
Southeast MN | I like the 9’angle blade for typical snow “here” most winters. Started with an 8’ on a JD4475 but much better job now with a Case sv280 and the 9’ blade.
Makes quick work of 300 yard drive and around the yard in a foot of snow or less.
Couple winters back, the snowblower on the tractor got the most use though.
No we experience with a skid steer blower. |
Central MN | I'd get a snow pusher..Have to swap to a bucket to cleanup in areas but the amount of snow they hold is unreal.. takes a long push and a lot of snow before you have stripes to cleanup. Coworker had a plow loved it I convinced him to buy a pusher, he don't use the plow anymore. |
IL | Rubber tire manure scraper works for me. Similar to this pic.
(20211208_212030 (full).jpg)
Attachments ----------------
20211208_212030 (full).jpg (87KB - 92 downloads)
210 Industrial Dr., Arlington Wisconsin 53911 | I have 8' bucket on JD325. I think it's 67HP and weighs around 8000 lbs. What's neat is you can remove the snow and
pile it as high as the loader will go. I have small lot and I build a pile about 30'x30'x 12' most years.
Edited by jd7810 12/10/2021 08:46
west central ohio | I use a 8' plow with my L170 . I would think a high volume bucket would be better for in the barn lot, and around buildings . I like the blade for the long driveways though.
Edited by WAYNE0224 12/8/2021 21:46
| Get an old 8 ft scoop off a Farmand F10 loader.They were great for moving snow.Make a bracket for the skid steer.Its pretty wide an deep so be warned it might be a bit top heavy if lifting to high levels.You will have s snow moving machine. |
South Central PA | I guess I am surprised how many recommend the standard bucket. It just seems we are "pushing" lot of snow rather than "rolling" it off the side on a long driveway which creates a lot of stopping and dumping. thanks for all the replies....always helpful. |
NW IA | 8 or 10 foot snow bucket. Have a 10 footer I used on a 185 first now a cat, big snow first pass it may suck but after that can run half swath and still do more than the dirt bucket. Unless have long stretches then I would look at an angle plow of some sort.
Edited by rednwia 12/8/2021 22:17
Brandon, SD | i bought a plow for the skid steer last year, added swept forward wings to it and that thing is the ticket. Can roll off the side on the drive or push snow in lot onto pile quickly. |
Southeast Washington | I have a 7 foot snow bucket for volume. A lot better than the general purpose bucket. You can lift up and weight your skid steer versus a plow or snow pusher. The best of all worlds with one tool.
(20210217_203616 (full).jpg)
(20210217_205856 (full).jpg)
20210217_203616 (full).jpg (107KB - 248 downloads)
20210217_205856 (full).jpg (173KB - 240 downloads)
coast of Maine | We used pickups with blades for years,got a snow bucket for skids(huge only for snow and light material)made them a snow cleaning powerhouse.being in an ice area we use same achine to always sand/salt but we need to switch to smaller bucket,no big deal and then shake out sand,,,speaking of which I need to get off here and get that done this am as we have a couple inch and some ice beneath,,= falls.You should see islanders walk on snow/ice ,,falls are very common as they have not gotten used to it like here. |
Very southern Mn | Here we have blowing snow so any ridge just makes a higher drift. I use a snowblower at my house where I really don’t have room to push a lot of snow and we use a snow pusher on the farm where we do have more room. A pusher will move twice as much as a snow bucket and you can also pile it somewhat. Here at least you kind of need all three, snow bucket, pusher and snowblower. When you get bad storms with 2-3 ft of snow everywhere than for me snowblower as you can start a path and get rid of snow. I have a non hi flo skidsteer but snowblower matched pretty good. Will not throw it as far as a tractor but with some patience and letting oil get warmed up good does a decent job. Hiflo would be the ticket. |
| A Virnig V plow with the wing extensions would be my choice, able to bust through deep snow, can angle snow to either side or use it as a pusher. |
| Get the big snow bucket and match size with your machine. I tried angle blade as well as snow pusher and sold both. One thing that helps is slit a piece of pipe full width of bucket weld 3 tabs on and bolt on leading edge will help on yrs where ground is soft . |
NW iowa south of the CIty :) | https://www.denhartogindustries.com/arctic-assault/
They are fast don't have to dump bucket, push up snow and then raise loader and back up or turn around and push back other direction. |
NE of Des Moines | I have tried a snow plow on the front of my skid steer. I found that it wanted to push the skid steer to the side, then I got stuck with the snow plow-----at least with a material bucket you can dig/work your way out . I sold the snow plow and bought a snow blower for my skid steer. I usually use the material bucket but depending on the amount of snow I will get the snow blower hitched up and have at it.
I have found out that a set of chains on your skid steer really makes a difference also.
What works good for one person doesn't always work the same for someone else.
I have read where putting on truck wheels with snow tires instead of skid steer tires /wheels makes a big difference.d Better traction, sets higher and more speed because of taller tires. |
 Dahlgren, Illinois | Pretty sure i just seen this unit on facebook few days ago? |
