Search Forums | Classifieds (5) | Skins | Language
Ideas for a pump to drain a fuel tank
1586
Posted 11/13/2018 19:36 (#7104112)
Subject: Ideas for a pump to drain a fuel tank
I need something small like a drill pump but self powered. I had something that had bad diesel and we were able to siphon but it was slow. My air compressor needs the fuel drained and refilled with fresh. It sat for 2 years with an electrical issue we finally got fixed. Now I need to change the sight gauge tubing on another unit. Seems to like I could use something at lest once a year. Ideas?
SWKS
Posted 11/13/2018 19:50 (#7104147 - in reply to #7104112)
Subject: RE: Ideas for a pump to drain a fuel tank
Southwest Kansas
12v Inline electric fuel pump.
4WD
Posted 11/13/2018 19:53 (#7104153 - in reply to #7104112)
Between Omaha and Des Moines, 7 miles South of I80
I've watch a video, where a guy used to fill his off-grid generator, by lift 5 gallon jugs (to refill), for a couple years, then he tried one of these battery-powered hand pumps, and mentioned it was a "life-changer". (I don't remember the brand, he had)
Would something like this, work for your situation?
https://www.amazon.com/Sierra-Tools-Battery-Operated-Liquid-Transfer/dp/B000HEBR3I
(pump (full).jpg)
Attachments pump (full).jpg (78KB - 113 downloads)
redfarmer72
Posted 11/13/2018 19:55 (#7104161 - in reply to #7104147)
Southern IL.
Can you siphon it?
Rod Maker
Posted 11/13/2018 20:01 (#7104172 - in reply to #7104112)
Westport, IN
If you have a tank in your truck, remove the nozzle and drop the hose in the tank. Hook the motor leads backwards and the pump will suck out the hose.
Edited by Rod Maker 11/13/2018 20:02
SWND
Posted 11/13/2018 20:06 (#7104188 - in reply to #7104112)
Southwest ND
https://www.ebay.com/itm/Carbole-Self-Priming-Pump-Shake-To-Start-Ga...
thorfarms
Posted 11/13/2018 20:08 (#7104192 - in reply to #7104188)
Lincoln, North Dakota
Just use a service tank pump if you have one around.
Edited by thorfarms 11/13/2018 20:08
ryan elias
Posted 11/13/2018 20:19 (#7104221 - in reply to #7104112)
chortitz, manitoba
I made one with a old dodge lift pump and a broken Milwaukee cordless drill. Works like a dream.
49deere
Posted 11/13/2018 20:31 (#7104252 - in reply to #7104188)
Maryland
+1
slow but works well
WildBuckwheat
Posted 11/13/2018 20:36 (#7104264 - in reply to #7104112)
Middlesex County, Ontario
"I need something small like a drill pump but self powered."
Do you have a cordless drill?
1586
Posted 11/13/2018 21:19 (#7104359 - in reply to #7104153)
4WD - 11/13/2018 18:53
Looks like it would work for 2 out of 3. Be nice to have a hose for the next one for a deep tank. I like the idea though for most of the time.
1586
Posted 11/13/2018 21:21 (#7104362 - in reply to #7104172)
Rod Maker - 11/13/2018 19:01
Might be an idea. Have filters on all of the so not sure how that would work.
joe63johnston
Posted 11/13/2018 21:30 (#7104381 - in reply to #7104112)
https://www.princessauto.com/en/b/proven-pumps/N-die5ub;jsessionid=u...
Ben D, N CA
Posted 11/13/2018 21:51 (#7104427 - in reply to #7104112)
Whiskey, Tango, Foxtrot
There's lots of small 12v fuel pumps out there. I bought one very similar to this for a similar project, worked great for $40
https://www.amazon.com/Goplus-Electric-Kerosene-Transfer-Extractor/d...
reedfarmer
Posted 11/13/2018 22:21 (#7104474 - in reply to #7104112)
Eastern Arkansas
To change the sight glass, take a shop vac and stick the nozzle in the fuel fill but not in he fuel. Have someone seal it off best they can with a rag. Then turn it on and replace the sight glass, it won’t spill a drop. I have done it many times to replace the crossover tube that’s on the bottom of an 8420 fuel tank.
Ron Mahoney
Posted 11/13/2018 22:34 (#7104487 - in reply to #7104112)
Take a 12 volt transfer pump and stick the suction pipe into the fuel tank and pump it out. Works great. I've done it multiple times when selling or trading in equipment that had more fuel in them than i wanted to give away.
Edited by Ron Mahoney 11/13/2018 22:38
countryman
Posted 11/14/2018 02:48 (#7104601 - in reply to #7104474)
Germany
just don't try this with a gasoline tank. Vapors will combust in the vac motor and turn it into a jet turbine - well, almost.
nebfarmer
Posted 11/14/2018 04:49 (#7104624 - in reply to #7104147)
SE Nebraska, Near Misery and Cans Ass!
X2!
Everybody ought to have a couple of these cheap ones laying around you can use them for so many things. And you can get some of the really cheap ones and just use them for a nasty job like paint transfer from a 50 gallon barrel to smaller containers one time and throw them away yeah it may cost you 25 or 30 bucks but it'll sure be worth it. Have you use them to transfer chemicals out of a mini bulk in a pinch when I transfer pump wouldn't run and I had nothing else I could use at the moment.
Posted 11/14/2018 05:40 (#7104651 - in reply to #7104427)
BenD
That looks like a nifty pump for $40. It claims up to 10 gpm!!
I realize the OP is talking about pumping diesel fuel, but make sure if anyone buys the pump in the link they realize it is NOT for gasoline per the mfg!
nebfarmer
Posted 11/14/2018 05:44 (#7104660 - in reply to #7104172)
Rod Maker - 11/13/2018 20:01 If you have a tank in your truck, remove the nozzle and drop the hose in the tank. Hook the motor leads backwards and the pump will suck out the hose.
Not if your check valve is working! LOL
cropsta
Posted 11/14/2018 07:15 (#7104809 - in reply to #7104112)
Nagambie
I have used a small boat bilge pump many times.
cropsta
Posted 11/14/2018 07:17 (#7104815 - in reply to #7104112)
Nagambie
1586
Posted 11/14/2018 07:21 (#7104821 - in reply to #7104651)
Ron..NE ILL..10/48 - 11/14/2018 04:40
BenD
That does look like the ticket. I think I may try one and see how it does.
Rob D
Posted 11/14/2018 07:34 (#7104843 - in reply to #7104147)
s.c. north dakota
Harbor Freight has a little pump with garden hose fittings on both sides, I use it to transfer used oil.
Hay Hud Ohio
Posted 11/14/2018 19:27 (#7105940 - in reply to #7104112)
SW Ohio
Get one of these and pump anything you want, anywhere, just need the air.
https://www.youtube.com/watch?v=0cpCEg19euc
We have used one to pump out a tile ditch, drain fuel tanks, clean out fertilizer tanks, waste oil, etc....
Posted 11/14/2018 19:50 (#7106010 - in reply to #7105940)
OK...you sold me. Where do we get them....affordably?
Hay Hud Ohio
Posted 11/15/2018 07:02 (#7106669 - in reply to #7106010)
SW Ohio
Mr Lukow, I try to contribute here, but sometimes NAT asks too much of me......
Here are a few under $500, but the bigger ones sure get pricey.
https://www.bing.com/shop?q=air+powered+diaphragm+pump&FORM=SHOPTB
