Search Forums | Classifieds (5) | Skins | Language
Powerstroke injectors 7.3
Mtnfarmer
Posted 8/28/2018 14:09 (#6955946)
Subject: Powerstroke injectors 7.3
North Carolina
Got a 99 powerstroke that needs injectors for those of you who have replaced these did you use reman or new and where did you get them at just going back with stock injectors no upgrade or high performance items
CornFed13
Posted 8/28/2018 14:34 (#6955968 - in reply to #6955946)
Subject: RE: Powerstroke injectors 7.3
Pickens
Keep in mind the break is halfway through 99, and then 99.5 up...(just a note)
I have only installed two sets so far, both from East Coast Diesel, has been long enough that everything seems OK.
There are 2 new Reliant sets on Ebay now...for each model.
(Search "99 powerstroke injectors)
Good Luck,
CF
Edited>>Its Alliant, not Reliant...its too hot here today!
Edited by CornFed13 8/28/2018 14:38
Flansky
Posted 8/28/2018 15:03 (#6955997 - in reply to #6955946)
Kenosha, WI
Rosewood Diesel is the only place I deal with. Excellent shop and great people.
Brahamfireman
Posted 8/28/2018 15:31 (#6956033 - in reply to #6955997)
Braham MN.
Flansky - 8/28/2018 15:03
+100 for Rosewood diesel.
Mtnfarmer
Posted 8/28/2018 17:30 (#6956201 - in reply to #6955968)
North Carolina
How do I tell if my truck is early 99 or late 99
Mtnfarmer
Posted 8/28/2018 17:38 (#6956217 - in reply to #6955968)
North Carolina
Just looked at build date in door it is 05/99 I assume this will indicate early 99 model Next thing I'm going to assume is this indicates whether I need ab-ae-ad injectors. So which ones do I need
sdan27
Posted 8/28/2018 18:08 (#6956284 - in reply to #6956033)
I did a set for a guy that I got through Swamps Diesel. Rosewood is more affordable but doesn't have quite as long a warranty.
CornFed13
Posted 8/28/2018 18:14 (#6956302 - in reply to #6956217)
Pickens
Using the Vin, (8th digit), and call one of the shops,...they will know instantly...
Good Luck,
CF
PS>>If you decide to use ebay, use the contact seller button>>Other>>and just email...
They will usually return your answer is a few hours or less...
Good Luck,
CF
Edited>>Since the model years start in September, it most likely will be 99.5...but always use the Vin method to be sure.
Edited by CornFed13 8/28/2018 18:26
SmallTimeFarmer
Posted 8/28/2018 19:47 (#6956549 - in reply to #6956284)
Mi
Look on the passenger side valve cover for build date. My door sticker says I have an early 99, but the motor is a late 99. Bought the truck new
Mtnfarmer
Posted 8/28/2018 20:54 (#6956766 - in reply to #6956302)
North Carolina
Thanks for the info. I forgot about the model yr starting I sept I will use the serial number to verify Iooked up rosewood they have Avery attractive price and warranty package However the turnaround time seems a little inconveinant by having to send them my injectors guess I will call them tommorow and find out all details. Your info is greatly appreciated
Mtnfarmer
Posted 8/28/2018 20:59 (#6956786 - in reply to #6956549)
North Carolina
Will look at this also tommorow and verify thanks for the info on this
CornFed13
Posted 8/28/2018 21:01 (#6956800 - in reply to #6956766)
Pickens
Hey no problem...just trying to help a neighbor...Oh, BTW...can you ship a few gallyons of that Mountain Moonshine? LOL.,
CF
Mtnfarmer
Posted 8/28/2018 21:03 (#6956809 - in reply to #6955946)
North Carolina
Thanks to all for the replies. Think I got this figured out. NATers' have a wealth of knowledge
Mtnfarmer
Posted 8/28/2018 21:21 (#6956890 - in reply to #6956800)
North Carolina
Ill see if I can come up with some gallons are hard to come by but quarts are pretty easy to obtain. I know 4 quarts =1 gallon can't ship it though it'll never leave the post office and UPS/fedex will end up in court with DUI then I have to show up there too as accessory to the fact pay a fine serve time yada yada trying to stay out jail these days I'm just about an hour and a half from you email me hope ATF doesn't read NAT
CornFed13
Posted 8/28/2018 23:39 (#6957152 - in reply to #6956890)
Pickens
Man, I appreciate that...but>>
You know I sell corn by the bag...well, sometimes, they pull up with unbelievable amounts of sugar already in the bed!
I can get the stuff locally if I wanted too...just shucking with you...good luck on the Ford,...
CF
(purp_smiley (full).jpg)
Attachments purp_smiley (full).jpg (5KB - 62 downloads)
dvswia
Posted 8/29/2018 07:26 (#6957404 - in reply to #6956809)
sw corner ia.
so what did you end up getting?
Mtnfarmer
Posted 8/29/2018 14:29 (#6958087 - in reply to #6957404)
North Carolina
I think the best bang for the buck is the 8 brand new Alliant injectors from rose wood diesel but I'm going with the $1185 rebuild with 3 yr warranty my funds are not quite up to parr for the new ones
Multi-Power
Posted 8/29/2018 19:49 (#6958566 - in reply to #6956809)
SW Ohio
Early 1999's have a build date prior to 12/16/98. Build dates after that are a 1999.5
Mtnfarmer
Posted 8/29/2018 21:16 (#6958814 - in reply to #6958566)
North Carolina
Yes that is correct mine has a build date of 5/99 so it is a later99 rather than early one
dvswia
Posted 8/30/2018 07:35 (#6959418 - in reply to #6958087)
sw corner ia.
ok.. should be running like new again. great motor.
