AgTalk Home | ||
Metal lathe Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
oes |
iowa | What’s everyone’s opinion on this lathe? https://www.toolnut.com/jet-321360a-bdb-1340a-belt-drive-bench-lathe... Looking for a lathe for repair work, threading gun barrels, and in future making new cylinder rods. Would this work for all that? I have looked at several older lathes but don’t know enough about them currently to know a slightly worn one from a worn out junker. Would rather go new. Any input is appreciated | ||
thefarmers |
Weve had a jet that size for 25 years or so. It's been a good lathe and we've done several gun barrels and countless other projects. They sure are fun to play with. | |||
E718 |
Sac & Story county IA | If you get big enough that somebody can't borrow a pickup on Saturday and bring home, the price goes down. This one has rigidity to it https://www.bigiron.com/Lots/H.E.SHErnault-SomuaType55020MetalLathe | ||
oes |
iowa | It’s on my watch list but being in ND and spring around the corner puts a damper on it to me | ||
Merle |
Nice lathe. Perfect size for what you are wanting to do with it. | |||
E718 |
Sac & Story county IA | I know what you mean. That lathe on a trailer in sloppy weather would be corrosion plus. On a trailer behind pickup in anything less than perfect traction would be bad. .I own an item at Duluth. Serious winter there yet. There is always HGR https://hgrinc.com/?all=1&view&aisle&from&to&markdowns&newarrivals&s... https://hgrinc.com/?all=1&view&aisle&from&to&markdowns&newarrivals&s... https://hgrinc.com/?all=1&view&aisle&from&to&markdowns&newarrivals&s... https://hgrinc.com/?all=1&view&aisle&from&to&markdowns&newarrivals&s... Edited by E718 3/4/2018 08:17 | ||
jtpfarm |
mn | I have a grizzly. Grizzly, jet, shop fox, and some others are very similar. Been a good machine and has done everything I have asked. They can pay for themselves in a big hurry making repairs. http://www.grizzly.com/products/14-X-40-Gunsmithing-Gearhead-Lathe/... | ||
palennn |
North Central Kansas | I would sure take the Grizzly over the Jet. Looks like about twice the lathe for the same price. | ||
oes |
iowa | palennn - 3/3/2018 20:08 I would sure take the Grizzly over the Jet. Looks like about twice the lathe for the same price. What advantages do you see with the grizzly over the jet? | ||
jeff gordon |
Mather, Manitoba | Biggest problem with a lathe is not buying one two decades earlier. Looks to have pretty standard options. Auto feed is one of the nicest options. Get rid of that tool holder and get an AXA wedge type quick change. Milling machine matches up nicely with it. Old man bought this Advance back in 1990. Saved us tons of cash in repairs. Take a course. Lots of tutorials on youtube. (IMG_20180223_130059.jpg) Attachments ---------------- IMG_20180223_130059.jpg (149KB - 97 downloads) | ||
towman2000 |
SouthCentral WI | Well first of all the grizzly is about 350#'s heavier. It also includes a live center, that I don't find on the the jet. Just the extra weight makes me think it would be a better lathe. Towman | ||
twraska |
Wallis, TX | Personally I'd go with used 'industrial' one but that's me. | ||
65_4020 |
Central Missouri | You could buy a nice Lebonde or Clausing for that price and have twice the machine. I bought my 21" x 60" Colchester for $4500. I would never buy a lathe with less than a 2" spindle bore. | ||
oes |
iowa | 65_4020 - 3/3/2018 21:15 You could buy a nice Lebonde or Clausing for that price and have twice the machine. I bought my 21" x 60" Colchester for $4500. I would never buy a lathe with less than a 2" spindle bore. Do you know of any of those for sale? | ||
65_4020 |
Central Missouri | https://www.bidspotter.com/en-us/auction-catalogues/bscci/catalogue-... | ||
65_4020 |
Central Missouri | https://www.bidspotter.com/en-us/auction-catalogues/heath-industrial... This one is pretty nice too. | ||
farmerkirk |
SC Kansas | I have a 15"x54" Leblond Regal with 2-1/8" iirc through hole. Works great for me. Plenty cheap if you look long enough. | ||
jtpfarm |
mn | twraska - 3/3/2018 21:00 Personally I'd go with used 'industrial' one but that's me. I wanted a good old atlas, South bend, lebond, or clausing in the worst way as I know they are better machines. But everything I found was either too far away, completely wore out or just plain huge. That's why I ended up with the grizzly. That said, for a farm shop they are more than adequate unless a guy was/is a professional machinist. | ||
Beetman |
Michigan | I have a 19"x102" Leblond Regal extremely happy look for used. My experience with jet was not to good, brought a 8000 pound pallet jack received in the little manual a certificate verifying it was tested at 8000 pounds with stamp and tester number went to move my first load with the jack a know load of 5500 pound radial drill press as I was pumping jack bent bracket where cylinder was lifting at, turn jack upside down to look under somebody forgot to weld the heavy sold brace to the top bracket so without that main brace a 2000 pound load would have bent it the certified test was a joke. | ||
tech5201 |
EC NE | Maybe Smithy? https://smithy.com/gear-drive-lathes-midas | ||
WYDave |
Wyoming | Folks should understand that most of the lathes that come out of China are really "lathe kits." They have most all the parts that would make a lathe already put together, but once you know something about machining, the Chinese-made machines will drive you to distraction, because you will find X,Y and Z on the machine that need to be addressed before you can really use it. Things like burrs and casting dross on some parts (pieces of the taper attachment are famous for being barely ground before being slapped together), seals that leak because mating surfaces are not true, etc. Edited by WYDave 3/4/2018 06:25 | ||
oes |
iowa | Thanks for the input. Iowa recently allows us to acquire suppressors so I have multiple bull barreled guns that don’t have threads on the muzzle. Enjoy gunsmith work but have a lot to learn yet on it | ||
ronm |
Fruita CO | +1 on the Grizzly, I've heard good reviews on them, no first-hand experience. Grizzly has now acquired the South Bend trademark & has a line of South Bend-branded machines out. No reports on them either, other than Griz's catalog... The good old American iron is getting sort of tired, I picked up a WWII-era Sheldon lathe a couple years back just to keep it out of the scrap yard, it's usable but really needs some TLC...one more project... I tried to get a big old Lodge & Shipley a few years ago, but the guy was too proud of it & wouldn't take offers. It was a machine from the high school shop where I took machine shop class. | ||
repairman |
South Dakota | Just remember that you will spend about three quarters to 100% of that amount in tooling. | ||
oes |
iowa | Any sites you would recommend for tooling? | ||
KWinWCIL |
Vermont, IL | WYDave makes some very good points. I looked for the kind of American made lathe that he describes for YEARS. They were either a zillion miles away, missing parts, had JUST been sold, or whatever. Never found the right one. Finally bought a Jet GHB, like what the OP was looking at only geared drive. I've had it for 6 weeks and have used it almost every day trying to get some hours on it. As of now, I'd say it was an ok purchase, I'm certainly not awed by the quality and it's at the lower end of my expectations. The fit and finish are barely acceptable. I'm still in a dispute with Jet as to replacing a cable on the DRO. The crate it was boxed in was terrible and had shipping damage. I fixed most of the damage except for the broken wire. On the positive side, I'm learning a huge amount every day which was one of my goals. It does seem to cut fairly accurately, although the 3 jaw chuck does have some runout. Dave is also correct in that the purchase of the lathe is only the beginning, the tooling adds up really fast. Bottom line is that I'm going to enjoy using my Jet.....but am still in the market for the perfect American made lathe, e.g. a Monarch, Lodge & Shipley, Colchester, or Hardinge. Probably others that don't come to mind. Good luck and best wishes. | ||
KWinWCIL |
Vermont, IL | I've bought some from MSC, some from McMaster Carr, but most I find on Amazon. All Industrial tools, Accusize tools, I bought a genuine Aloris BXA toolpost and have found that the Accusize holders fit really well at a fraction of the price of Aloris. I did change out the setscrews. I have yet to order anything from Shars so I can't speak to their quality. Suburban Tool I haven't tried yet either. Added... If you haven't got an indicator holder I'd highly recommend getting a Noga. Edited by KWinWCIL 3/4/2018 08:50 | ||
doggone |
south central MN | I know where there are some used Clausing lathes for sale in Iowa at an excellent price. Email me for the details | ||
65_4020 |
Central Missouri | Companies like MSC, Grainger, and McMaster-Carr all sell tooling. I wouldn't buy from any of those. But they are a good place to look to decide what you want/need. My advise is to stop in a local to you machine shop and see who they buy from to get your hard tooling. Your consumables can come from anyplace. I have several local guys that come in to my work and buy inserts, taps, drill bits, endmills etc. | ||
WYDave |
Wyoming | I can not only recommend Noga, I can tell you that using just about any other indicator holder is a waste of time and money. Every other indicator holder I've used has broken, sooner or later. Noga's indicator holders just keep on working. Edited by WYDave 3/4/2018 09:59 | ||
WYDave |
Wyoming | The Cadillac of American lathes was either the American Pacemaker, or the Monarchs, and I'd lean towards the Pacemaker. These machines were built to very exacting standards, they were built from very high quality materials, with exceedingly good bearings in the headstocks. If I could find a Monarch 15" lathe, I'd be on it like stink on a cowpie. They're awesome lathes. | ||
WYDave |
Wyoming | If you have questions about doing gun work on a lathe, please just ask. | ||
ronm |
Fruita CO | I've found a lot of tooling for the lathe & mill on ebay. | ||
oes |
iowa | WYDave - 3/4/2018 10:27 If you have questions about doing gun work on a lathe, please just ask. Your last couple sentences are above my pay grade currently but I have a 20’ stick of 1” rod I was planning on starting on. I didn’t realize it was that intricate | ||
WYDave |
Wyoming | There are several books that are essential for a machinist to have in his library, foremost among these is "Machinery's Handbook." The MH contains an incredible amount of information, and the book's sections on threading, taps, dies, drills, etc are worth the price all by themselves. Edited by WYDave 3/4/2018 11:46 | ||
School Of Hard Knock |
just a tish NE of central ND | jtpfarm - 3/3/2018 21:06 twraska - 3/3/2018 21:00 Personally I'd go with used 'industrial' one but that's me. I wanted a good old atlas, South bend, lebond, or clausing in the worst way as I know they are better machines. But everything I found was either too far away, completely wore out or just plain huge. That's why I ended up with the grizzly. That said, for a farm shop they are more than adequate unless a guy was/is a professional machinist. I use my atlas...... its old, its simple and has no transmission and uses change gears. but I woudnt go looking for one.There are much better lathes and parts for the atlas is about as obsolete as can be for anything made out of zamack pot metals and aluminum. Edited by School Of Hard Knock 3/5/2018 17:36 | ||
KWinWCIL |
Vermont, IL | Totally agree on the Noga. I just got one and won't touch my others now. I'm a little afraid of a 10EE in that the drive seems really complicated. Same way with a Hydrashift. Am I wrong to be a little leary of them? Lost Creek Machine has (or at least had) a 13" South Bend but it looked like it had been used hard. I went there to look at a Cincinatti but hearing stories about how expensive the gears were to replace scared me off. | ||
KWinWCIL |
Vermont, IL | LOL. Yeah, I just got the large print version of MH a year ago, and the tables are STILL hard to see. I've been wanting to buy a Gerstner as a gift for my brother but haven't been able to part with that much money! I have the feeling I could learn LOTS from you, WYDave. | ||
WYDave |
Wyoming | The 10EE's had several generations of variable-speed drives. Edited by WYDave 3/4/2018 14:22 | ||
oes |
iowa | What’s your opinion on a variable speed lathe vs adjustable speed? Also from reading on internet some people don’t seem to care for a single phase motor vs a three phase. Some claim the three phase leaves a better finish. Any input on that? Thanks | ||
KWinWCIL |
Vermont, IL | Thanks for that great info. The vacuum tube 10EE was what I was thinking of. I didn't know you could tear all that out and replace with a 3 phase motor and VFD. | ||
Hay Hud Ohio |
SW Ohio | Something I learned about LeBlonds, soon after getting this pre-WWII model (weighs 6200#!!), the company, that started in Norwood Ohio is still around, now on the East side of Cincy. They can get any piece for any machine they ever made since day one. Another shop much closer to me actually makes it for them, owner told me a few weeks ago they made a part for a 1918 lathe from the original drawings. If I ever get this one going on some serious jobs I might need Mr. Stine to help me out, I am a self taught tinker'er....... (leblond 02.jpeg) Attachments ---------------- leblond 02.jpeg (133KB - 86 downloads) | ||
WYDave |
Wyoming | Yes. I won't delve into the electrical theory on single vs. three phase motors here. | ||
Davy Krockett |
CO WI TX | I don’t know how close to a bigger city you are. Craigslist is were me and my fil found a nice older lathe it is a table top took about nine months of looking. Pretty much it’s like anything use if the price is to good to be true it’s not true and if it looks like it has been rode hard and put up wet don’t buy it. Now we’re looking for a knee mill. Times your friend when looking for used iron I found my snap on box on Craigslist for a good price took me a few months to find what I wanted. | ||
ronm |
Fruita CO | Took me 10 years to find a Bridgeport, here in the howling machine tool wilderness... | ||
Bret (OH) |
Blanchester, OH | Another thing to consider on most if not all of those small import lathes is that to produce different thread pitches you must physically change out the gears behind the cover on the drive end of the headstock along with setting the transmission to the proper speeds and feeds. That's a major hassle! I have a Royal 1360 (made in Taiwan) that is a really nice lathe, but I avoid threading because of the hassle of changing gearsets. Most of my threading work is snuck in to work to thread on my LeBlond Makino 18" Regal. For most thread pitches just a setting of the operator control levers gets you almost any thread you could need. For smaller threaded production parts, they would be produced on my Hardinge HC with a CNC Accuslide toolplate that uses a Fagor control, but that would only be used for multiple piece jobs. Most of the better older industrial lathes mentioned in this thread will give you that feature, and for me worth considering, especially if it was my only lathe. Another point already mentioned here in this thread is a spindle bore large enough to do the work you will want from the lathe. I would not even consider a lathe, especially for farm shop work, that could not pass a 2" plus workpiece. | ||
Davy Krockett |
CO WI TX | Ronm your on the wrong side of the mountains for good deals. | ||
SDFMEnterprises |
KS/ NENE | A buddy of mine bought a Grizzly 14x40 lathe a few months back for his small fab shop. The lathe itself works well for what he does with it, but he bought the DRO after the fact and it was a nightmare to install, he had to machine parts of the bed to accept the read rods, I think he told me it took 8+ hours to install. The other problem he had was the motor already went out. Grizzly sent him, in a timely manner, a new capacitor and relay for it which fixed it, but the service guy told him it was a common problem and that there's some sort of adjustment you need to regularly do inside the motor contacts to keep it from happening.... he will be replacing the motor with a reputable supplier when he gets a chance. He was in the same boat as you, would like a nice, quality older machine, but availability and price drove him to Grizzly. Someday he will step up and spend the money for a quality CNC and be done with it. | ||
thefarmers |
Our jet lathe will cut pretty much any American thread I believe without changing any gears. I believe for metric you have to swap a couple of the drive gears. | |||
thefarmers |
WYDave - 3/4/2018 10:27 If you have questions about doing gun work on a lathe, please just ask. How do you taper a barrel? Ive seen jigs made on YouTube to do it where the cross slide nut is removed and basicly follows along an adjustable track mounted to the lathe. Was tempted to make one but hadn't tried it yet. | |||
(Delete cookies) | |
