AgTalk Home | ||
Ron..NE ILL..10/48![]() |
![]() Chebanse, IL..... | Some implements have terribly heavy tongue weights & are hard to jack even with a newer "bulldog" styly crank jack. Of the hydraulic hoses & electrical cords hanging in the way can make spinning the jack handle difficult. We have an Unverferth grain cart with a hydraulic jack on it that's just a dream to unhook & raise up/down. Pretty simple. We have a JD 2510H 23 row applicator that came with a side-crank bulldog style jack. It's terribly hard to lift/adjust. Has anyone built a hydraulic jack of some sorts that lifts heavy tongues & plugs into tractor outlets? If so...photos? I've googled & don't see any commercially built products. There are some that sell a self-contained electric pump, etc, but I don't see just a simple cylinder extendable type. Suggestions? Thanks | ||
4020pig![]() |
I have no picture but I worked for a neighbor in college and we took a regular 3 by 8 cylinder welded a piece of 3/8"s inch plate to the side. Actually welded the plate to the bolts that hold the cylinder together. Then welded a piece of pipe to that for the receiver piece of the jack. It went on just like a normal jack and could be used in any implement. Made a pad out of some heavy metal that bolted threw the bottom of the cylinder it could pivot on that if not on a completely level surface. | |||
Von WC Ohio![]() |
Might look into some of the electric type ones ? Don't see any of the side wind bulldog types that are electric and I don't see any that are made to be pivoted horizontally most are for trailer a frames but there are some 5th wheel types that might be made to work ? | |||
george55![]() |
South West Ontario | i have mounted a hydraulic cylinder pointing straight down on my grain buggy and welded a pad to bottom of cylinder rod works great back up to buggy plug into remote and console hitch height from tractor seat when hooking up | ||
John Smith![]() |
South Central Illinois | Oil the working parts inside of the jack. Not so easy to do on some, makes a world of difference when done. | ||
steve c-il![]() |
Central Illinois | What about the landing gear from a goose neck trailer? Seems hyd. jacks are pretty common on trailers with hyd. beaver tails. | ||
CEO![]() |
I've seen hydraulic jacks on some Lemken products. Looked for a pic on their website but didn't find one. | |||
nhermanson![]() |
Central, IA | I have one on a heavy strip till bar. It is 2 pieces of square tubing with a cylinder mounted inside. I think the outside one is 7" and the inside one is 5 or 6 with some plates welded to it to shim it tight. It works well. Wilrich has also put one on there 10k toolbars. They used smaller tubing with the cylinder mounted to the outside. (wilrich jack.jpg) Attachments ---------------- ![]() | ||
SHR4010![]() |
live in Spfd, farm located NW Macoupin county | Use the quick hitch and a small chain I keep a 5-6' piece of small chain hanging on the cylinder hooks on the back of the cab at all times for jobs like this. | ||
Gaul farm![]() |
Look at ag-bag silage baggers they have Hyd jacks on them to turn for transport I can get pics if needed because I'm not sure how good of pics they have on there site Edited by Gaul farm 6/20/2017 10:20 | |||
pointrow![]() |
Central Il Morton | How about a leveling jack off a salvage RV. Some are hyd with a spring return and some have hyd return. Electric ones are usually on 5th wheel trailer. | ||
srsu99![]() |
Central / West Texas | I have these jacks on every gooseneck trailer we own. Probably hav at least 15 jacks from these people Premium Supply. (903) 455-7777 They are near Fort Worth TX Really nice people to work with Last ones I bought were $300.00 | ||
Mike SE IL![]() |
West Union, Illinois | SHR4010 - 6/20/2017 08:56 Use the quick hitch and a small chain I keep a 5-6' piece of small chain hanging on the cylinder hooks on the back of the cab at all times for jobs like this. Quick hitch? Cylinder hooks? | ||
SHR4010![]() |
live in Spfd, farm located NW Macoupin county | zoom in on back of tractor (DSC02037.JPG) Attachments ---------------- ![]() | ||
WildBuckwheat![]() |
Middlesex County, Ontario | Mike SE IL - 6/20/2017 14:25 SHR4010 - 6/20/2017 08:56 Use the quick hitch and a small chain I keep a 5-6' piece of small chain hanging on the cylinder hooks on the back of the cab at all times for jobs like this. Quick hitch? Cylinder hooks?A quick hitch is that U shaped frame many tractors have on the 3pt to make hooking up to 3pt implements easier. Cylinder hooks - back in the day when farms had one hydraulic cylinder to share between their implements, tractors had hooks on the back of the cab to store that cylinder. Tractors don't come with them anymore. | ||
pbutler![]() |
Macon, IL | I have converted a couple of those drop legs-really nice. Weld on side permanently then jack all the way up to bottom of tongue when running in field. Had a 1600 gallon sprayer that was a real bear-put that on and was piece of cake.... | ||
nwokman![]() |
Which jack from Premium Supply are you talking about? | |||
Funacres![]() |
Texas | You can make a hydraulic jack out of a manual jack if it is a square tube style by taking the screw guts out and mounting a small cylinder inside of it on two pins. I have also made jacks by simply using two square tubes that slide inside one another that are larger enough to fit a cylinder in the middle. | ||
Z.A.Enterprises![]() |
Sw Ontario | These are used a lot in Europe but you can possibly make your own. The hydr. ram has spring return though but a double ating cylinder would work too. Pull one pin out and flip it up when machine is hooked up to tractor. https://www.kramp.com/shop-de/en/207809/755992/460408/SP65250C+Stand... (Steunpoot.jpg) Attachments ---------------- ![]() | ||
Mike SE IL![]() |
West Union, Illinois | Guys I know what they are. But my Case 9270 has neither. My 966, 7210, and MX275 do not have cylinder hooks. However my 966 does have a Fast-Hitch which makes hitching up a dream. | ||
srsu99![]() |
Central / West Texas | nwokman - 6/20/2017 15:49 Which jack from Premium Supply are you talking about? Website doesn't show it but you can buy just the Jack | ||
(Delete cookies) | |
