AgTalk Home | ||
farkfamilyfarm![]() |
West Manchester Ohio | The belt on the far right-hand side flipped all the way over and put it self in a twist. This is a new one to me what on earth would cause that? uneven feeding? Big windrows mixed hay very dry. The picture is just after I took it apart (IMG_1416.JPG) Attachments ---------------- ![]() ![]() | ||
jao![]() |
you fed to much on the left. when you see it start to track over its loose and needs more hay on the right it only happens on the right | |||
Mtnfarmer![]() |
North Carolina | All you needed to do to twist it back was to fold the belt in opposite direction of twist and tie a piece of baling twine around it then run the belts slowly and it would have twist back. Some of the old Vermeer balers had 2 of the belts running in a twist so you could see the bale form as it was filling And yeah filling one side to much or quickly will cause this | ||
sandhillsam![]() |
NW Oklahoma | Dumping a bale with a high crosswind will cause that with a Deere baler. | ||
Mtnfarmer![]() |
North Carolina | LOL. Yeah it amazes me how loose they are when they dump Door closes and you have to wait to take up the slack New meaning to slackers | ||
West Manchester Ohio | Well shucks live and learn I guess | ||
drk![]() |
IA | I've had that happen on a deere 567 when I dump a bale on a pretty good sidehill. I just left the door open, locked out the hydraulics and twisted back to the correct orientation. Didn't have to take anything apart. | ||
FoamAddict![]() |
Canada | That new holland looks very similar to the case rbx461 I have. Mine would twist belts and we couldn't figure out why until we discovered on one of the 3 rollers right behind the twine box had a broken bearing mount I believe. If yours has this problem you will be able to find it with a short pry bar. | ||
(Delete cookies) | |
